| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
Here's the problem.. I have two bags, one of Salt and one of Sugar and then pour both into a single container and shake well so that both are evenly mixed together. The question.. How do I separate them from each other.. because I don't want sugar on chips or salt in my coffee ![]() Don't ya just hate real world problems... PS: for those that do know the answer please bite your tongues, for those that don't.. Think! don't Google.. because internet access during a written exam is not allowed. | |
Pull the sugar from the water by stickin in a piece of metal and letting it crystalize? Or was it salt that crystalizes like that? Or do both makes crystals? I don't remember. EDIT: Oh wait, is the salt just mixed in with sugar in solid form? I suppose if that was the case you could take a torch to it but then you'd be left with a bunch of dirty salt and no sugar. I had assumed it was in a water mixture for some reason.
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 31st October 2009 at 09:47 PM. | |
I can think of at least two ways to do the separation: 1) Separate based on differential solubility in water, i.e., fractional crystallization. Glucose is much more soluble that salt, so the salt will crystallize first. In fact, carbohydrates can be quite difficult to crystallize, and you will eventually end up with a syrup that with seeding will give you almost pure sugar. That approach would apply best, if you had a solution of the mixture. However, you have a solid mixture; so, 2) My preferred method would be to separate the crystals based simply on their density. You need a liquid that is less dense than NaCl crystals and more dense than sucrose crystals, and in which neither dissolves. A mixture of hexane or any hydrocarbon with chloroform or carbon tetrachloride would work. There are numerous other non-aqueous mixtures one could use. I did look up the relative densities of the two crystals (who can remember those data anyway), and you need a liquid with a density between 1.59 and 2.16 g/mL. A mixture with a specific gravity of 1,7 or so would be great, which is easily done with hydrocarbons and halocarbons. Finally, one could get quite complicated and separate the mixture based on differential solubility in dextran solutions or use specific ligands, such as boric acid. Melting the mixture probably cannot be used, because sucrose decomposes upon melting. But that would give you a way to recover the salt. John Edit: A quick check this morning shows that tetrachloroethylene (cleaning fluid) has a S.G. of 1.623, so it should work. Carbon tetrachloride and chloroform are not quite dense enough. Last edited by jpanhalt; 1st November 2009 at 10:12 AM. | |
Would you be willing to put that sugar in your coffee, or salt on your chips after it has been in those chemicals?
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ | |
Of course, I've been drinking Lake Erie water for years. Besides, hexane and chloroform are quite volatile and relatively non-toxic. I suspect there may be some trick solvent that has a specific gravity greater than 1.6, but I didn't bother checking. I believe the key is the difference in specific gravity of the two crystals in the mixture and recognition that it is a mixture of solids, not a solution. One could even use differential centrifugation up an incline, etc. John | |
| | #6 |
i work in a lab, i'd use a centrifuge.
| | #7 |
I'm in the solubility camp, though I'd have to use google to find the relative solubilityes. Maybe there is also different melting points, but then we're back to google.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
| | #8 |
I know that a centrifuge isn't the answer being fished for, but I know it would work without damage to either the salt or sugar so it IS the best answer (just not practical for a home experiment)
| | #9 | |
The problem I see with simple centrifugation is the friction between particles and packing of the crystals. I think you need something that will ensure free movement of the crystals, which is why I suggested an incline (like panning gold). You could also consider a vibratory table. John | ||
| | #10 |
I'm not sure about solubility issues, but you could heat it. The sugar will melt significantly sooner than the salt will, you'll need to use a double boiler or carefully control the heat to keep the sugar from caramelizing. I think sugar melts at just bellow 100C and will start caramelizing around 110 So a double boiler with an copper or aluminum inner bowl should work. You'll need a lid to keep moisture from getting in. You could alternatively try different solvents, there has to be something that will dissolve one but not the other, I'm a real chemistry newb though so I have no idea what to use, I'd start with household stuff
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 1st November 2009 at 11:20 AM. | |
| | #11 | |
| | #12 |
Hello there, The answer is quite simple my friends :-) I was going to post this as a joke, but then realized that it would really work... Go outside and collect a bunch of ants, put them in a nice size container with the mixture...they will collect the sugar and leave the salt behind. | |
| | #13 | |
__________________ Pay it forward. | ||
| | #14 |
Pure grain alcohol. Won't hurt either it will dissolve the sugar not the salt, heat the sugar/alcohol mixture in a double boiler the sugar will melt and the alcohol will vaporize, you'll end up with pure sugar salt and that's it..
| | #15 |
What a waste of good alcohol.
| masterclass, problem, solving |
| Need help solving simple problem | cannibal | Electronic Projects Design/Ideas/Reviews | 11 | 12th December 2007 03:27 AM |
| Need help to learn concepts and problem solving... | thebigbasicq | General Electronics Chat | 4 | 31st July 2004 05:23 AM |
| Need Help In Solving Math | shermaine | General Electronics Chat | 10 | 19th May 2004 04:58 AM |
| Solving Question (1) | shermaine | General Electronics Chat | 6 | 18th February 2004 08:11 PM |
| n00b questions (1) circuit analysis/problem solving | Super Mario | General Electronics Chat | 2 | 1st October 2003 12:46 PM |
