+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 26 of 26
Thread: Antennas- Multiple/Simultaneous Frequencies
  1. #16
    Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,922
    Blog Entries
    2
    Quote Originally Posted by Tesla23 View Post
    Most radio manufacturers would know how to drive multiple receivers from a single antenna (it's basically what Mike says). Are you sure it isn't a diversity receiver.
    A diversity system requires two antenna's. Dk is talking about just one antenna and two receivers.
    Pay it forward.
    www.geoepicenter.com
  2. #17
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    Please see my previous post which should answer this. It is a diversity system, but each "module" often has two parallel antennas right beside each other on the receiver. Between the two antennas on each module, they are providing neither diversity from orientation or blocking. The diversity is provided by using multiple modules (though one module actually has two antennas that are mounted 90 degrees to each other and this was the one that made me start to wonder whether it was receiving two signals at two different polarities each, or two signals at only one polarity each which is dependent on whether the antenna is able to simultaneously receive multiple signals).
  3. #18
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,922
    Blog Entries
    2
    Quote Originally Posted by dknguyen View Post
    Please see my previous post which should answer this. It is a diversity system, but each "module" often has two parallel antennas right beside each other on the receiver. They are providing neither diversity from orientation or blocking between themselves. Multiple modules are used to provide diversity.
    Gadzooks, make up yer mind.
    Okay, so I know that a single antenna can be designed to transmit/receive multiple frequencies.
    So is it a single antenna or multiple?
    Pay it forward.
  4. #19
    Tesla23 Newbie
    Join Date
    Jul 2008
    Location
    Australia
    Posts
    98
    Well for a diversity system you do need parallel receive channels up to the point where the signals are combined. It is possible to get some benefit simply using a switch at the antennas, but you generally gain more using parallel receive channels.
    So the answer is no, you can't implement a spatial diversity system with one antenna. You can often get a similar performance using polarization diversity which may have a dual polarized antenna (may be more compact than separate antennas), but apart from that the system is similar.
    Depending on the propagation conditions, diversity can give you many dBs of gain.
  5. #20
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    I think they didn't bother to add extra circuitry to use the same antenna to simultaenously receive two signals (now that I know it is possible and from looking at some of the receiver PCBs). They needed to have 2 radio modules anyways for dual frequency redundancy, and they either had the choice of extra circuitry (so they could use just one antenna), or extra wire (an extra antenna). I guess they went with the piece of wire.
    Oh yeah, I've been talking about wire antennas the whole time. None of those special dual polarity ones.
    What initially sparked this question (in case it's gotten lost), was the receiver had two antennas- each oriented 90 degrees to each other. I knew it transmitted on two frequencies, but I was not sure whether it was receiving one frequency per antenna (Channel A at Polarity X and CHannel B at Polarity Y) or if it was receiving two frequencies per antenna (Channel A at Polarity X&Y and Channel B at Polarity X&Y).
  6. #21
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,922
    Blog Entries
    2
    Maybe you can post the advertisement, and allow us to evaluate it.
    Pay it forward.
  7. #22
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    It's kind of every page for all their air receivers:
    Spektrum RC
  8. #23
    Tesla23 Newbie
    Join Date
    Jul 2008
    Location
    Australia
    Posts
    98
    ?? Are you sure it mightn't be a dual polarity antenna ??
  9. #24
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    Pretty sure. THe antennas are just straight pieces of wire- no fancy coiling or anything. Is that what you mean?
    The spatial and polarity diversity is supposed to come from placing the base units and satellite units at different locations in different orientations (except for the odd unit where the antennas are mounted in different directions which provide polarity diversity in the same unit).
    THe two smallest units have just one antenna- I know these ones do not transmit on dual frequencies.
  10. #25
    Tesla23 Newbie
    Join Date
    Jul 2008
    Location
    Australia
    Posts
    98
    Two antennas at 90 deg is typically a dual polarisation antenna. You might be thinking helical antennas and circular polarisation.
    Look it's impossible to say what the system does, but I did have a quick look at the claims of US patent 7,391,320, they claim to use a combination of transmit diversity (that's an interesting one), along with frequency diversity, path diversity, time diversity, antenna diversity and polarization diversity (orig claims 24-26). If you downloaded the patent it is likely that they will give you lots of details of how the system might work.
  11. #26
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,922
    Blog Entries
    2
    Those guys are using CDMA/GSM type technology... So it is like like FDMA.
    Pay it forward.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Simultaneous equations with 3 variables
    By Overclocked in forum Math and Physics
    Latest: 16th September 2009, 01:24 AM
  2. Simultaneous PIC reset
    By Krumlink in forum Micro Controllers
    Latest: 5th May 2009, 09:10 PM
  3. Replies: 3
    Latest: 4th April 2007, 03:53 AM
  4. RF antennas
    By Asjad in forum General Electronics Chat
    Latest: 28th October 2004, 05:06 AM
Tags for this Thread
