Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 6th July 2008, 03:27 PM   (permalink)
Default Supplier of millable aluminum?
A friend and i are going to be working on a really cool (and expensive) project.
We need to mill out a LOT of parts, and we need to make it out of aluminum. The chunks need to be about 1 foot x 1 foot (maybe a few inches less)
I was just wondering if anyone knows of any suppliers of millable aluminum (i think the stuff is called bailet, or something like that)
Thanks.
[edit: any thickness should be fine.]
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 6th July 2008, 03:46 PM   (permalink)
Are you very close to McNeilius in Dodge Center? The company is now sold, but used to have a great scrap yard with tons of cut-offs at great prices. When I couldn't find something there, I went to Lynn's scrap (who was McNeilius's dad) and could usually find it. Best part, they were open on Sunday and closed on Saturday. There are also other scrap/cut-off metal places in Dodge Center (Dickie Steel is one).
Second choice is McMaster Carr (much more expensive). As for which alloys to use, pure aluminum (1001) and even half-hard (3003) are hard to machine, as they get gummy. Use lots of cutting fluid with them (kerosene works). A harder aluminum , like 6063, 6061, 2017, 2024, etc. is much easier to machine. McMaster is good, even if you don't buy from it, because it has a convenient table of machinability. John
Edit: I forgot 2011 and MIC6 are also easy to machine. MIC6 is something you will find in large plates.
jpanhalt is offline
Old 6th July 2008, 04:22 PM   (permalink)
Hmm... Ok...
Yeah, i am pretty close to McNeilius'. One of my friends is pretty good friends with the people there.
This project is going to take some precision, so i think i will have someone mill them for me...
Maybe Fastenal would do it? I don't want to spend for than a grand ($1000) on this device.
Marks256 is offline
Old 6th July 2008, 04:24 PM   (permalink)
Try emachineshop.com.
speakerguy79 is offline
Old 6th July 2008, 04:40 PM   (permalink)
It is hard to say what the cost will be for "a lot." You would need to be specific. I have never used a job shop but suspect you are going to see something like $80 to $100 per hour on the low side. $1000 can be spent pretty quickly making different parts. The expense is all in set-up.
I doubt McNeilius will do custom work. A vo-tech might do it for a low fee or consider adult extension classes. I used to enroll just to get access to machines I didn't have, such as horizontal mills and grinders. John
jpanhalt is offline
Old 6th July 2008, 05:03 PM   (permalink)
I know it is going to be spendy. really spendy.
I have heard of emachineshop before... i will check that out.
Marks256 is offline
Old 6th July 2008, 05:17 PM   (permalink)
This is very good advice. Not only do you get the parts made but you learn how to work the tools. If you pay to have it done you can not afford to be wrong. Which is apt to happen. Take the money you do not spend on machining and buy some extra blanks.
3v0 is online now
Old 6th July 2008, 05:26 PM   (permalink)
yeah. i like this idea, too.
Hmm....
How do you "shine" up the aluminum when you are done machining it? like, getting it really smooth and shiny?
Marks256 is offline
Old 6th July 2008, 05:38 PM   (permalink)
Hmm....
I am not a machinist. But as I understand it you machine to a fine finish and after that a rag and some polish makes it shine.
3v0 is online now
Old 6th July 2008, 05:40 PM   (permalink)
That is what i was thinking. My dad is good friends with a very talented machinist. I am sure he would be more than delighted to help me out, just as long as i get the stock.
Marks256 is offline
Old 6th July 2008, 05:49 PM   (permalink)
If you get a good machinist, it will be shiny anyway.
Pommie is online now
You've not mentioned what you're trying to do, but isn't milling parts out of a solid block a very expensive way to make components?.
Old 6th July 2008, 05:53 PM   (permalink)
What'cha building Marks?
straight answer, har har."
Sceadwian is offline
Old 6th July 2008, 06:33 PM   (permalink)
Hmm....
Shine and surface finish are somewhat separable concepts. You can shine aluminum that is quite rough, even an unmachined casting. One common procedure for that is electropolishing. It is done for alloy wheels and such. There is also roll/vat polishing, like is done
with stones.
As for surface finish, machining is part of the answer. The Mic6 and other plate aluminum comes in various surface finishes, from rough mill (rolled), to surface ground. The surface ground plate is not that expensive, gives you a good reference point (the tolerance on aluminum extrusions is pretty big), and is quite attractive. Light bead blasting with glass or walnut shells also gives a nice finish.
Finally, I would suggest you look into home DIY anodizing. This is, after all, an electronics forum. It is really quite easy to do with a battery or battery charger, a little sulfuric acid, and regular old fabric dyes. First, you make the anodic surface, dye it, then fix/seal over steam. There are many step-by-step procedures for the DIY. I have seen some beautiful results too done by a local hobbyist. The best part about anodizing is it gives a protective finish as well.
As for hand polishing, I would avoid it. It is messy, dirty work and does not impart any protection. My first choice is to start with a decent surface, such as the ground material, do decent machining, and finish with anodizing.
John
jpanhalt is offline
Old 6th July 2008, 06:55 PM   (permalink)
Hi, I'm 3Vo's significant other.
I studied mechanical and industrial engineering and was trained to be a machinist.
The part when designed will have a specified 'surface finish', that is specified in 'microinches' by the designer. The smaller that number, the smoother the surface will be finished to. The machinist will produce the part to the size, shape, and within the tolerances specified by the designer (engineer) including SURFACE FINISH. The 'smoother' the finish, the more work it takes on the shop floor. So usually only as flat and "shiny" a finish as will suffice will be specified because of the additional work involved to get a flatter smoother finish. Which adds to the cost of manufacturing that part.
Bottom line, the cheaper the part is to make the better.
So a shiny smooth part was specified that way, otherwise that machinist will probably be fired for wasting the time to put that finish on.
Once in awhile for a display or promo rollout, extra work will be taken to smooth, buff, plate, and polish, but that is the exception for the showpiece.
[example, only the very first shuttle sent to orbit had painted white fuel tanks. That added a LOT to the cost PLUS the weight of the paint. All the rest have looked rusty or tan/yellow of the insulating foam....]
Even in our highly automated age, it still costs to do additional work to produce a smoother finish and the bottom line is they will only do what is necessary. Rather than machine from a solid block at a certain point, a part will be cast or pre-formed then the fine machining to tolerance is done after.
A good machinist is economical in work and TIME expended and does hold tolerance as required and specified.
3v0 is online now
calc Tr of aluminum object? justDIY General Electronics Chat 2 9th January 2008 07:40 PM
Supplier! epilot Electronic Projects Design/Ideas/Reviews 16 6th September 2006 05:01 PM
UK Supplier holdit Micro Controllers 4 16th October 2005 03:12 PM
vaporize aluminum wire George L. General Electronics Chat 3 14th June 2005 05:15 AM
Need Help etching Aluminum TheDesignShop Electronic Projects Design/Ideas/Reviews 4 28th April 2004 02:48 PM
