Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 25th May 2008, 12:12 PM   (permalink)
Actually, I think it might disable the edit button, after another member has viewed your post.
Also, I know that too has two 'o's in it, it was a typographical error and the forum won't allow me to correct it.
Screen name: Aloone_Jonez
Hero999 is offline
Old 25th May 2008, 12:27 PM   (permalink)
Less errors -- more freedom!
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 25th May 2008, 02:08 PM   (permalink)
Originally Posted by blueroomelectronics View Post
I think it's a 15 minute edit timer. IMO it's a good idea.
You're right, there is a 15 miniute timer.
I created an edit link for a post I typed over 15 miniutes ago, in the hope I could get round this limitation but I was presented with the following error:
The administrator has specified that you can only edit messages for 15 minutes after you have posted. This limit has expired, so you must contact the administrator to make alterations on your message.
Hero999 is offline
Old 25th May 2008, 02:14 PM   (permalink)
Thumbs down
hi hero,
There is now a 15min limit on editing.
Its a pain, especially if you are trying correct an error, so it dosn't get misread in the future.
Also when you are working with a OP and he asks another question relating your previous post, you just cant go back and add an update.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 25th May 2008, 04:46 PM   (permalink)
I don't see any need for this time limt.
The forum software keep a log of all the changes to a post, so if someone replaced the first post in thier thread with gibberish a moderator could revert it back to the origional.
To see this, create a post and edit it several times. You'll notice that there's a link saying "Lasted edited by X at date and time", click it and it'll take you to a screen where you can compare different versions.
Hero999 is offline
Old 25th May 2008, 05:20 PM   (permalink)
I don't know, but does the 15 minute edit window begin the second you start a new thread? I sense that maybe it does, which is unfortunate, because some of my posts can be quite wordy. I try to be careful, but the more words, the greater chance of making a typo.
The kinds of typo are usually things that would otherwise confuse or misdirect the intent of the post, such as dropping a negative qualifier (e.g. "I did do this" instead of "I didn't do this") or using plural instead of singular nouns or vice versa.
I can understand there being some limits on the edit function, for instance, in the interest of maintaining the integrity of the forum. The value in the forum is the people who help - it's not fair for their hard work to be effectively nullified because an OP decides to remove or distort their original inquiry and consequent discussion. I think the basic idea of the forum is to build a body of knowledge where successive people can learn from a constantly growing, mutable, and collective understanding. That can't happen if there's excessive retro-censorship. The cost of asking a question here is submitting yourself to a public display of your learning process. Given the aforementioned philanthropic nature of the supposed purpose of this forum, you should be proud to be stupid, as long as you're asking questions here, and learning from the experience.
On the otherhand, I think there's virtue in putting the onus of clarity on the OP (or even responders). I can only remember seeing one instance of a member, who I don't think is even on this forum anymore, who chose to interfere with the intent of the forum by deleting the content of his posts. I'm not convinced that that in itself is enough reason to limit the editing window to 15 minutes.
Perhaps something on the order of 24 hours might work better? That would allow enough time for someone to respond to the OP, realize or have pointed out to them where their typo was, correct the typo, and avoid situations where the OP or responder might have to duplicate an entire post or get into editorial discussions (which might distract from discussing electronics).
The idea is that, at a glance, the forum should be an easy-to-read electronics forum, as oppose to a reflection of electronics enthusiasts constantly tripping over typos. I don't want to view the process of people working to correct trivial typos every time I click on a thread I thought I'd be interested in. I'd rather just presume that they'd take the responsibility for that process themselves, and not be distracted from reading the real electonics details of their posts.
Hank Fletcher is offline
Old 25th May 2008, 09:21 PM   (permalink)
I think 15 minutes editing time is enough.
Normally I read the post after submitting it and correct typo's immidiately.
Some other forums I'm participating in only allowe 3 minutes.
As other members already mention is that the original poster can modify posts so comments don't make any sense anymore.
If you make a mistake in a post so what, post a reply on it and correct the latter.
It should be mandatory to fill in the reason why the post was editted, so a track record is kept on file.
My $0.02 worth
Raymond
RODALCO is offline
Old 26th May 2008, 01:01 AM   (permalink)
Originally Posted by RODALCO View Post
anymore.
Because you have the lazy people who just read one of the wrong versions, believe it, then move on because they don't bother reading the entire thread. So that.
Also, if that were the case I would end up with 3 large consecutive posts that look *almost* identical, except the wording in some of them is potentially ambiguous and open to multiple interpretations in the most subtle, but important, of ways. Then you have confusion about which paragraph is which, or some people might think they are identical posts, or some people might get a certain wrong idea and then you have to backtrack explaining to them that it is not so. It's much easier to tell the right thing the first time around then to try and undo a learning of the wrong thing.
dknguyen is offline
Old 26th May 2008, 02:54 AM   (permalink)
Good luck updating bad links after the 15 minutes. Do we at least get to edit attachments?
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 5th June 2008, 07:37 AM   (permalink)
Well, after living with it for a while, I have to eat my words and say that I do prefer the way it worked before. The new way is livable but there really wasn't that much pollution before the change. I support bringing back the old way.
Torben
Torben is offline
Old 5th June 2008, 07:49 AM   (permalink)
Torben
I believe there is now a lot more pollution than there ever was before. I have today reluctantly posted a thread that is almost identical to a previous thread due to the lack of edit facilities.
Also, the fact that a complete copy of any edit is kept and can be viewed by anyone makes it completely unnecessary.
Edit, click on the link below to see what I mean.
Pommie is offline
Old 5th June 2008, 07:55 AM   (permalink)
Yep, I saw that thread. I think maybe I still fall into the trap of sticking to the Usenet mindset, where editing is prohibited altogether--so even 15 minutes of edit time seems a lot. In a forum like this one, though, time-unlimited editable posts just work better, especially for the more experienced posters. The polluted threads before mostly weren't anything terribly important or worth archiving for posterity anyway.
Torben
Torben is offline
Old 5th June 2008, 08:21 AM   (permalink)
It appears that the ability to view edits is also on a timer, how bizarre.
Edit, I'd stopped putting the reason for edits as I thought the ability to view edits was permanent.
Pommie is offline
Old 6th June 2008, 05:06 PM   (permalink)
I thought that you had to either be a modertor or the poster to view edits.
If this is true, I dissigree with it, I think anyone should be able to view the old versions of posts.
Hero999 is offline
Old 7th June 2008, 07:43 AM   (permalink)
Hi Pommie I agree completly with you
I am not oposing a time limit but 15 minutes is a little on the short side in my opinion 1 hour is more apropriat
the internet conection here at my place is not that good so several times it drops out and you don't have the chance to correct your mail
but put a limit on the time for editing also is just crazy
Robert-Jan
rjvh is offline
need to edit 2 VERY large files Marks256 Chit-Chat 9 14th January 2008 11:02 PM
Can some one help me to edit this CLOCK ASM ? pasanlaksiri Micro Controllers 0 4th January 2008 04:21 PM
odd project, 1 button adds a light 1 button takes a light away with sound. KevinAlaska Electronic Projects Design/Ideas/Reviews 15 6th June 2007 05:38 AM
Can a PIC edit it's own code? Peepsalot Micro Controllers 20 27th March 2006 12:01 AM
need help, urgent! ...........{edit}............. rancid rock Electronic Projects Design/Ideas/Reviews 18 9th January 2006 04:23 AM
