Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Thread Tools Search this Thread Display Modes
Old 8th May 2008, 01:18 AM
Experienced Member
magician13134 is on a distinguished road
Default Designing a webpage in Photoshop?!
Hi, I found a great template for a site I'm making and it was in a .PSD file, so I opened it and edited it to be the way I wanted, and tried to save. I did file>save for web, but that's as far as I can get... When I save it, everything is an image... I don't want that, I want text, links, etc. I know it's possible because the original PSD came with the index.html when it was saved properly... Any ideas? Thanks
magician13134 is offline   Reply With Quote
Old 8th May 2008, 04:03 AM
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Photoshop is a photo editor, not an HTML editor.
Try KompoZer instead.
http://kompozer.net/features.php
Bill
Smart Kits build Smart People
Old 8th May 2008, 04:54 AM
Experienced Member
lexter is on a distinguished road
Send a message via ICQ to lexter
I believe that all the links are/were in html file. It might be so, that there was a image map in it. Check for other image files there, i doubt that any browser is able to open psd.
lexter is offline   Reply With Quote
Old 8th May 2008, 06:01 AM
Experienced Member
Gayan Soyza is just really niceGayan Soyza is just really niceGayan Soyza is just really nice
If you have Macromedia Dreamveawer you can download many HTML templates from google & work out with that.It has lots of alignment support.
Save for web feature is there to save your edited images to fit into your web page with light weight & web image size.
Gayan
Forum Supporter
Gayan Soyza is online now   Reply With Quote
Old 8th May 2008, 10:23 AM
Experienced Member
Hmm.... thanks for the responses, but that's not quite what I need.
@blueroomelectronics - actually, it does do webpages, movies too
@lexter - I know they're in HTML, Photoshop has a function to export into HTML, the links weren't maps, though, they were actually text... Like selectable text
@Gayan Soyza - Dave for web also generates HTML, but I can't figure out how to make the text appear as text instead of sliced images.
Here's the original template I found. (It's free, not illegal, don't worry) That includes the PSD and rendered HTML. All I want is to be able to edit the PSD and save it like that again... Thanks
http://ufalt.com/?oz8w7
Old 8th May 2008, 10:50 AM
Experienced Member
I Tried to edited your PSD format it can edit nicely.
To change text I point to Text tool & select the text & edited.
To change the image I point to select tool & select the image & delete it.
It works for me fine.
Gayan
Forum Supporter
Old 8th May 2008, 11:14 AM
3v0
Moderator
3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all
magician13134,
Sorry but I agree with the others. PSD is Photo Shop Document. You are not the first person to be confused by this. There are sites that talk about photoshop templates, they provide the graphics for a site not code.
Read this thread on another site. Then checkout the tutorial it points to.
To control the world from your PC with USB I suggest USB Bit Wacker
3v0's Tutorials for ABSOLUTE BEGINNER
C, PIC 18F, MPLABŪ and MCC18 Compiler
3v0 is offline   Reply With Quote
Old 8th May 2008, 02:21 PM
Experienced Member
Right, I can edit it, but I can't save it as HTML again...
@3v0 - I disagree with that. Photoshop is capable of slicing which in turn can be exported into HTML. Here's from Adobe stating it is possible: http://livedocs.adobe.com/en_US/Phot...ABBDCDB6A.html
Old 8th May 2008, 07:04 PM
Experienced Member
Torben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of light
Hm...I have to agree with the others. Photoshop has a slice tool which is handy for what it does (so does the GIMP, and Adobe FireWorks, etc) but I wouldn't suggest using it for page handling. Normally I would use it to slice up the basis for a graphically complex layout and then populate the text areas later using an HTML or text editor or a template system.
Sure, you probably *could* use it for page handling but you can also cut the lawn with hedge trimmers--it's just not the right tool for the job. I've been doing web programming and design professionally for 10+ years and have tried a lot of different tools, believe me.
Anyway, I couldn't find a lot of information but perhaps the following will help you out if you haven't already tried it: http://livedocs.adobe.com/en_US/Phot...ABBDCDB6A.html
Good luck,
Torben
Torben is offline   Reply With Quote
Old 8th May 2008, 07:09 PM
Experienced Member
Heh, I linked to that in my last post... it doesn't really explain too much though. So... are you saying that the best solution would be to edit the images in Photoshop, then manually merge them with the index included in the original index.html that came with it? Also, how did they (the template site) get that index then? (Not contradicting you, I'm curious)
Old 8th May 2008, 07:16 PM
Experienced Member
Rats! Wrong link. Try this one: http://livedocs.adobe.com/en_US/Phot...ab64-7535.html
But generally, yes. I haven't used the Photoshop slicer but with the GIMP or Fireworks, I would set up my layout, maybe include any rollovers/effects, slice it, and save/export the result. Normally I would get an .html file and a directory with the image slices. Then I just open the resulting .html file and copy what I want into my final page design (or template).
Torben
Old 8th May 2008, 07:20 PM
Experienced Member
Ok, thanks, one more thing, how do I make images backgrounds by default? Thanks
Old 8th May 2008, 07:28 PM
Experienced Member
http://livedocs.adobe.com/en_US/Phot...814F20A95.html
That what you're after?
Usually I would set it using "body { background-image: url( <imgfile.ext> ); }" in the stylesheet but again, I code most of my HTML by hand.
Torben
Old 8th May 2008, 07:36 PM
Experienced Member
Yeah that looks helpful, thanks.
I usually code by "hand" too, as I'm sure you can see by my total lack of... anything to do with this whole template business. I'm just not very good at coding myself, so I figured I'd take the easy way this time
Old 8th May 2008, 10:17 PM
3v0
Moderator
And it looks like you would be right. Old dog new tricks sort of thing
Search this Thread:
Advanced Search
circut designing rahe_wafa20 Chit-Chat 36 3rd March 2008 10:53 AM
designing fm transmitter sheng_james General Electronics Chat 2 11th November 2007 04:51 PM
Designing Software savage General Electronics Chat 0 15th April 2006 10:33 AM
can any one tell me the designing steps of digital ic vaibhavi General Electronics Chat 1 12th March 2004 10:50 PM
Question on designing close loop DC brushless motor control swear_swear Electronic Projects Design/Ideas/Reviews 7 14th June 2003 06:17 AM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
