Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Thread Tools Search this Thread Display Modes
Old 1st May 2008, 09:39 PM
Experienced Member
arhi has a spectacular aura about
Question How to attach cooler to chip?
struggling for some time where to place this question so here is as good as place as any...
To get to the point, I want to attach a metal (aluminum or copper) cooler to the chip but there are no brackets, no mounting points etc.
For this type of work earlier I used to use some termal paste adhesive that I got with some memory coolers but the stock is gone and in this "3rd world country" local stores do not have the paste (or donno how to call it).
I see only 2 solutions to my problem:
1. You guys tell me the proper English term for the paste (thermal glue or something) and point me to the online shop where I can order some (or I'll google the shop myself when I get the actual name of the product I'm looking for)
2. I heard that I can "make" the paste by mixing some thermal paste (normal thermal paste used for CPU's, for e.g. as5 http://www.arcticsilver.com/as5.htm ) and 2 component glue. I have not tried this (I heard it should work) so I would like to know if it actually work before I try (as I need to attach a new cooler to the gw cpu - and would not like for that cpu to overheat).
thanks in advance
http://www.it4um.com
arhi is offline   Reply With Quote
Old 1st May 2008, 09:54 PM
Experienced Member
Glyph is on a distinguished road
"Thermal Epoxy" and "Thermal adhesive" are terms you're looking for.
I got my stuff from here:
http://www.newegg.com/Product/Produc...82E16835100005
Glyph is offline   Reply With Quote
Old 1st May 2008, 11:52 PM
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
What is the shape of the chip? Does it have a metal tab so it can be bolted to a heatsink ?
What is the shape of the heatsink?
Does it have many fins?
Old 2nd May 2008, 01:25 AM
Experienced Member
@glyph
Thanks. This looks like what I need.
@audioguru
Approx size is 4x4cm, the chip is a via i386 compatible CPU, no metal tabs, no place on the board where I can drill holes to attach some "pressure wires" to hold the heatsink, the cpu is afaic soldered directly to the board. The heatsink I want to attach is 4x4x4cm, there was heatsink on that cpu that was 4x4x1cm with a fan, and I replaced that fan 10-15 times (heat + dust kill it) so now I want to put there bigger heatsink that can be fanless.
The previous heatsink was also "glued" to the CPU
Old 2nd May 2008, 01:41 AM
Experienced Member
My 486-66 didn't have a heatsink.
My 486-100 was surface mount on a daughter board with a 3.3V regulator so it plugged into where the old 486 was. It also didn't have a heatsink.
I think a slow 386 processor needs a heater so it can stay warm.
Old 2nd May 2008, 01:47 AM
Experienced Member
it is VIA i386 "compatible" ... not 80386 intel cpu (that does not need heatsink) ... This one does need a heatsink ...
processor : 0 vendor_id : CentaurHauls cpu family : 6 model : 7 model name : VIA Samuel 2 stepping : 3 cpu MHz : 798.974 cache size : 64 KB fdiv_bug : no hlt_bug : no f00f_bug : no coma_bug : no fpu : yes fpu_exception : yes cpuid level : 1 wp : yes flags : fpu de tsc msr cx8 mtrr pge mmx 3dnow bogomips : 1592.52
Old 2nd May 2008, 09:28 AM
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
An alternative to consider is Loctite 384 adhesive, part number 21087. That version is thermally but not electrically conductive. It sets hard, so is considered non-repairable. Loctite makes other versions that are electrically conductive and/or are repairable/removable.
Loctite was bought by Henkel several years ago, so it may now be more readily available worldwide. John
jpanhalt is offline   Reply With Quote
Old 2nd May 2008, 11:58 AM
Experienced Member
They are selling loctite (or locktite not sure) by Henkel locally in hw stores for some time now (together with tv commercial with guy hanging from the ceiling) but there is no part number there .. just a 3g superglue metal tube, and they sell it as superglue, so I'm not sure if the one they are selling here is good choice, I believe arctic silver might be the better choice, and as my bro is sending me a package from the states in few days (I also need few attyny45 that are also not available here for some strange reason, you can get all sort of pic's but from atmel on 5-6 different models) I'll just tell him to order few arctic silver termal adhesive and be done with it .. I believe 2 packs will last for a year as I do not need them often... (and internet order from europe can be a tricky thing as most of the online shops that sell hw parts ship to usa/canada only )
Old 2nd May 2008, 12:58 PM
Experienced Member
For your use, the silver-filled material is probably a good choice.
I found the Loctite 384 for a project that needed a non-conductive, hard-setting agent. Henkel is like the American 3M Company. It has a huge number of products and sometimes the same product will have different numbers associated with it, depending on the market to which it is sold. It can be confusing and frustrating, because neither Henkel nor 3M will tell you what the equivalent consumer products are. 384 is described as a cyanoacrylic adhesive, which as a class is often referred to as "superglue." A noticeable difference between 384 and typical hardware store super glue is that the superglues are usually clear and not great for gap filling. 384 has a non-conductive filler in it that improves its thermal properties.
I give that as just background information in case you have a future project that needs that property. John
Old 2nd May 2008, 01:19 PM
Experienced Member
@jpanhalt
thanks for the hint mate, I'll definitely go trough a few stores here and check the supplies ... henkel acquired few factories in this messed up country of mine so we have load of henkel product's in our stores .. might be that I'm able to find the appropriate one
Search this Thread:
Advanced Search
Are chip makers building electronic trapdoors in key military hardware? Analog Chit-Chat 5 2nd May 2008 10:09 AM
Simple I2C interface chip? oeginc General Electronics Chat 20 29th March 2008 12:52 AM
Digital to analog converter chip vuchris Electronic Projects Design/Ideas/Reviews 6 16th October 2007 09:02 AM
WRT54G Power Supply Chip ParkingLotLust Datasheet/Parts Requests 32 5th January 2007 09:26 PM
AVR Dragon: My first chip HarveyH42 Micro Controllers 4 3rd December 2006 01:35 AM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
