Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 17th April 2008, 02:41 AM   (permalink)
Experienced Member
killivolt is a glorious beacon of lightkillivolt is a glorious beacon of lightkillivolt is a glorious beacon of lightkillivolt is a glorious beacon of light
Default New Metal Detectors Design Features ?
I just wanted to know about something. I had someone tell me that a newer design Metal detectors can create an Image of what it found as well as tell the value the image produced. Copper,Gold, Ect ?
True or False ?
Truthiness Monkeys : Obedience, Ignorance, Fear.
killivolt is online now   Reply With Quote
Old 17th April 2008, 02:45 AM   (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
I suppose it's possible (think of what an MRI is), but an MRI costs millions and millions (hundreds of millions? tens of millions? I'm not sure), and for that alone I don't think they would exist.
Are you sure they weren't talking about X-rays in baggage scanners?
Disclaimer: Avatar for entertainment purposes only.
Old 17th April 2008, 05:02 AM   (permalink)
Experienced Member
ronsimpson is just really niceronsimpson is just really niceronsimpson is just really nice
1)“tell the value of image Copper, Gold, Etc” NO! It can tell magnetic metal (iron) verses Copper. Gold & Copper look the same.
2)”create an Image” Ground penetrating radar makes a good image. There are systems that measure magnetic fields that can see pretty good. With a magnetic field sensor or a metal detector is hooked up to a data recorder you can get a image by walking across a field, stepping over two feet and walking back across the field many many times. The data is fed into a computer that makes a map of all the data. I have seen pictures on the internet of people that fine 1000 year old graves this way. I use something like this to find water pipes. The resolution is not good. If I cross the field every 2 feet then that is the resolution. If your metal detector has a 2 foot head then the resolution is only 2 feet. This is only a 2D image. The radar is the only way I know if getting a 3D image. Also low resolution.
I hope this helps.
ronsimpson is offline   Reply With Quote
Old 17th April 2008, 12:30 PM   (permalink)
Experienced Member
Yep Thanks. I thought something was wrong somewhere. I knew there was probably an ability to get resolution but to actually know the metal type ? nah.
Old 17th April 2008, 01:13 PM   (permalink)
Experienced Member
Send me $5,000.00 and you to can find fabulous buried treasure. (Gold)
The new and improved black box that finds gold, silver and diamonds at any depth.
Carol for Jamestown writes us: I found this huge gold nugget in my back yard.
Call 1-800-RIP-OFFS. Operators are standing by now. Easy time payments.
Having said that;… I have looked at some of the “detectors”. Some are non functioning! Some almost work. And some can fine objects. I built a couple. I have one that finds buried pipes and wires. There is a spot where I usually park the big tractor. Months after I moved the tractor it can still find the outline of the tractor. It can find the spot where the plastic water line is but it cannot fine a 10 inch metal gas line under the back pasture. I have another that screams for the 10 inch metal pipe but can not find the water line. There is some black magic and a big load of faith in this.
Old 17th April 2008, 02:25 PM   (permalink)
Experienced Member
ha ha ha, lol I want to say might be better to cut a twig and go for it huh.
Old 17th April 2008, 02:26 PM   (permalink)
Experienced Member
Hey, Let's make the first metal detector with a twig attachment ? Maybe we could use a lemon tree twig he he
Old 17th April 2008, 02:37 PM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Do you think the shadow/outline was rust, oil, other debris? Have you any links/information on the couple that you built?
Pommie is offline   Reply With Quote
Old 17th April 2008, 03:23 PM   (permalink)
Experienced Member
As far as finding where cars and tractors have been, I was measuring the magnetic fields in the earth. The flux lines twist around the car and trucks. When the tractor was removed the flux lines distorted for months. Look up “Magnetometer” “T-Coil Magnetometer” “Fluxgate magnetometer” “3 axis Fluxgate magnetometer”. I have video of people using ‘differential magnetometers’ to find twist in the earths flux. It is very revealing.
Below is a map of 2000 year old building remains in a field. He walked across the field every two feed and recorded the flux lines. It does not mater that the field was plowed hundreds of times. I know people that can find the same walls by walking with a piece of metal in their hands.
Last time the phone men came to repair the buried line, one man had a wire tracer machine and the other had a copper wire in each hand. They both said they could not get the other method to work.
Old 17th April 2008, 03:33 PM   (permalink)
Experienced Member
That's interesting. I'll look into that tomorrow. Bedtime now.
Old 17th April 2008, 06:20 PM   (permalink)
Experienced Member
HiTech is a glorious beacon of lightHiTech is a glorious beacon of lightHiTech is a glorious beacon of lightHiTech is a glorious beacon of light
Perhaps that someone is confusing the feature of some detectors LCD displays that will show an ICON of a coin, or jewelry and such once that specific type of metal has been located. I've seen those types of detectors on the market. It's nothing more than bells and whistles for novice hunters.
HiTech is offline   Reply With Quote
Old 17th April 2008, 06:22 PM   (permalink)
Experienced Member
aah I'm thinking this is more what probably happened.
Old 17th April 2008, 09:25 PM   (permalink)
xl5
xl5 will become famous soon enough
I first started metal detecting circa 1973 using a bfo with wooden search head. utilised a small AM transistor radio nulled & clipped to the shaft as one of the oscillators. the other one being built on top the search head in a small wooden enclosure complete with variable capacitor ctl knob mounted on top.
Now this basic bfo system could detect a coin at more than 3 inches, and i literally found hundreds of coins and objects with this method.
Other machines i have bought through the years (always second hand) have been IB. TRF. BFO. all relatively cheap to buy even when new. and all have the capability to find that elusive treasure. spending serious money on one of these all singing dancing machines makes little sense in my opinion. (most) coins etc are found near the surface ie: between 2 & 5 inches.
The downside of the bfo the banshee like wail rising on locating metal.
xl5 is offline   Reply With Quote
Old 18th April 2008, 12:11 AM   (permalink)
Experienced Member
Can't you just stick fire a bullet into the ground and graph the echo? (LIke in at the beginning of the first Jurassic Park )
Is it possible to make an image like that? Or was that just for movie purposes?
Old 18th April 2008, 02:03 AM   (permalink)
Don Wilson will become famous soon enough
I have done some study on metal detectors, as I am looking to buy one.
I beleive the image is determined by the strength or weakness of the change in the magnetic field. If ab=34khz which is the coil signal, c=copper g=gold,I=iron,etc Each will change the singal, to what degree I have no clue.
these signals are sent to micro-processor, where the changes are processed,and it makes an educated guess. Also most of them say dig every signal.
Don Wilson is offline   Reply With Quote
MP Lab Program Help bamafan54 Micro Controllers 3 19th October 2007 02:53 AM
help understanding this hbridge design.... jaydag71 Electronic Projects Design/Ideas/Reviews 2 5th June 2007 10:37 PM
Texas Instruments New Design Center. chemelec General Electronics Chat 0 18th May 2006 10:33 PM
Analog design: Some things to remember Roff General Electronics Chat 18 8th November 2005 01:38 PM
Metal Detectors! Rehal General Electronics Chat 2 24th October 2003 10:43 PM
