Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 19th March 2008, 09:30 PM   (permalink)
Originally Posted by UTMonkey
Thanks Bill.
As an update I have taken the advice on board and had another crack today.
I am pleased to say that there has been a definite improvement, nowhere near professional but a million times better than a few days ago.
I would suggest Antex irons Mark, I've been using them for years - and temperature control is well worth it.
Old 19th March 2008, 09:37 PM   (permalink)
I have used a temperature controlled Weller soldering iron all my career. Then I needed to solder some things on a job site using their el-cheapo soldering iron.
It was way too hot! The tip was burnt and not tinned due to the high heat and the rosin flux in the solder instantly vapourized and did not do its wetting and cleaning job. It made very poor solder joints.
Old 20th March 2008, 04:15 PM   (permalink)
Default avoid lead free
hi all
just my 2 penneth. i have just got back into the hobby
and equipped myself with a pen tip 25W iron, solder sucker
and a helping hands. so what was my problem???????
that awful rohs leadless solder its absolutely pants.
i got a 500Kg reel of 22swg. Solder content: 50% tin,
1.4% copper, 48.6% lead. ahhhhhh havent had a dry joint,
or delamination since. probably all in the technique but
the new stuff is just screaming 'LET ME HELP FRY YOUR
COMPONENTS' so as far as im concerned avoid it!
im with the chaps here; clean the tip, tin the tip, and solder.
regards
Fenris
Fenris is offline   Reply With Quote
Old 20th March 2008, 04:30 PM   (permalink)
That half a tonne of solder should last you a long time.
Pommie is offline   Reply With Quote
Old 20th March 2008, 06:10 PM   (permalink)
Wasn't 50:50 solder for plumbing?
With an acid core?
It needs a blow torch to melt it?
Old 20th March 2008, 06:20 PM   (permalink)
After Pb free ruling has come out, perhaps it may be difficult to get 60/40 resin cored solder unless one has in stock with his hobby kit. We are yet to experience this problem. I am rather interested to know how our members fared with lead free soldering at home front.
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Old 20th March 2008, 06:57 PM   (permalink)
I'm uber OCD paranoid about lead. (ie. I wash my tools and my hands, as well as anything they have touched. I also wash the things that those things have touched and the things that those other things have touched, etc.). But I switched back because I destroyed more PCBs with Lead-free solder. It's also way harder to work with and even harder to fix mistakes on. I have much better equipment now, but haven't tried it with lead-free.
If you are on mass production levels where lots of toxic waste is generated, but also have the resources for repeatable, fine tuned process control then sure it's great. But I've found that at home, I make more waste (and waste more time and money) from destroyed boards of Lead-free solder than if I just used leaded solder.
Old 20th March 2008, 07:03 PM   (permalink)
Thanks for the info. I was told that it is a difficult task and getting cofirmed by experts with 1st hand experience.
thanks, Dknguyen.
Regards,
Sarma.
Old 20th March 2008, 07:06 PM   (permalink)
I still use lead-free though on big things large wires to contacts (just not on tiny PCB things) because there is a lot more exposed solder there, lead-free can take higher temperatures, heat damage does not matter as much, and it's larger so it's much easier to just go overboard on the heat to get it to work.
Old 21st March 2008, 10:56 AM   (permalink)
Hi All,
After loads of tinkering with my JuneBug and my breadboard I decided to do have a go at soldering a project together.
Let's just say soldering is definitely a skill which I definitely don't have.
This is one aspect of electronics I am NOT enjoying.
Any tips? (not soldering irons!!)
Mark
Usually doesn't take long to gain experience in solding and become good at it, and when you do, you probably find that it's the easiest thing in Electronics work. whether in design or trouble shooting.
May the force be with you.
My project: Simple White Line Follower
http://au.youtube.com/watch?v=8Z_MmrdH4oc
http://i271.photobucket.com/albums/j...nefollower.jpg
Wingmax is offline   Reply With Quote
Old 21st March 2008, 03:49 PM   (permalink)
I enjoy soldering too, it's not difficult when you get the hang of it.
Bill
Smart Kits build Smart People
Old 21st March 2008, 04:52 PM   (permalink)
Yep, me too. I enjoy the design phase but I also look forward to building. Although I'm glad I only do one-offs since I'm not a big fan of drilling the holes (although the drill press helps).
Now I'm also learning to weld. Makes soldering seem like cake.
Torben
Torben is offline   Reply With Quote
Old 21st March 2008, 09:36 PM   (permalink)
Torben
Yeah...I'm sometimes afraid to step into the building phase because that's when you start spending money and the mistakes you make are "hard" mistakes and not "soft" mistakes.
Old 23rd March 2008, 07:27 PM   (permalink)
Nigel, It's an Antex iron I am using (18w).
No temperature contol on this one. I think I definitely need that one for my next iron as I have already melted the plastic casings of some components.
UTMonkey is offline   Reply With Quote
Old 23rd March 2008, 08:24 PM   (permalink)
Torben
I saw in the Canadian Tire here they have a Haynes manual on welding. Anyone used it? It looked pretty handy, I'm thinking about picking it up.
I've heard welding aluminum is a pain (low melting point, oxidizes easily). Anyone had any experiences along those lines?
Hank Fletcher is offline   Reply With Quote
Basic Soldering & Desoldering Guide ElectroMaster Electronic Theory 13 3rd October 2007 04:54 PM
hot air soldering patroclus General Electronics Chat 18 24th October 2006 11:57 PM
How to properly take care of soldering tips? rvk2 General Electronics Chat 11 28th August 2005 09:41 PM
Soldering Station Confusion TekNoir General Electronics Chat 16 1st May 2005 04:48 AM
Soldering (beginners) doblenine Electronic Projects Design/Ideas/Reviews 2 19th January 2005 06:38 AM
