| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
Nice. What do you fly? John
| | #3 | |
http://www.youtube.com/watch?v=JdKUl...eature=related | ||
| | #4 | |
I would like to start flying model airplanes, though. I got a simple foam one for my birthday a few years back, but i crashed it (i totally forgot to put batteries in the remote ) and it never flew again...
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | ||
You do have a nice set of hardware and at a good price. You do realize it is PCM, not PPM, right? A lot of the PCM transmitters I know about can also do PPM. The difference is only important (for your uses), if you start to design receivers for it. Also, the 72 MHz band is not approved for surface control. Probably the only risk that you run is if you go to some sort of sanctioned AMA event or similar (like organized RC clubs). You aren't going to go to jail for it; they just won't let you use it and may warn you. Almost all modern transmitters can be changed by simply getting a different frequency module for surface control. Have fun. John | |
| | #6 |
Yeah, i saw a list that shows frequencies and their uses. I think it was 75MHz that is for surface... Do you think the 8 channel can be changed easily? I am not worried about the 4 channel one, as that will just be used for random stuff, but the 8 will be used for some more important things (maybe some competitions if i make anything fun...) Also, what do you think the range is (line of site, unobstructed).
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. Last edited by Marks256; 18th March 2008 at 12:32 AM. | |
| | #7 | |
Range is line of sight plus it will reach around reasonable obstructions for both 72 and 75 MHz. The GHz is strictly line of sight. In the air, range is at least a mile. On the ground it should be at least a few hundred yards, based on what we get with our range checks with the antenna removed. Range is definitely less on the ground, but I have no experience with surface radios to give you a better idea of what it should be. John | ||
| | #8 |
Ok. Thanks for answering some of my questions, John. ![]() I have another question. The outputs on the receiver are for servos, but what if i wanted to simply say "on" or "off" (without hooking a servo up to a toggle switch), or what if i wanted to control something analog? Would i have to make something, or are there modules out there? I just looked on tower hobbies. They don't have the Futuba T8UAF. I guess i will have to wait and see when i comes. I can't find the manual on google, either. thanks
| | #9 |
A simple on/off can be constructed from a microswitch with the servo arm actuating it. Most people I know have gone to electronic versions, however. Here are some references: http://www.uoguelph.ca/~antoon/gadgets/rc-sw.htm http://www.welwyn.demon.co.uk/rcsw/rcsw.htm I have attached an image of the Guelph schematic. The Welwyn schematic is pdf and too big, but I have attached the explanation that downloads with it. It is really quite simple. You just set up your flip-flops to determine whether the pulse is longer or shorter than what you set the switch point to be. Remember, the receiver does all of the decoding. If you have an oscilloscope, it is kind of fun to circuit trace the signals and see what the composite looks like when you wiggle the sticks. I have done that to show mixing to other fliers. Where the servos plug in, however, it is simply a single channel of PWM. There is a variety of commercial switches made and many of the hobby sites have them. John Oh, and thanks. | |
| | #10 | |
Getting an old car with a lot of former, powered comforts is a good idea, because you won't need a lot of them since there'll be no driver. Seats, mirrors, vent fans, wipers, and even lock solenoids are expendable if you have an exterior driver. Recycle! Economise! | ||
| | #11 | |
http://manuals.hobbico.com/fut/8uafs-8uaps-manual.pdf | ||
| | #12 | |||
We also have one with a good transmission, but the engine has been parted out (very nice car, too...) Since we got them for junk, i don't think either would be worth putting any money into them. Although it wouldn't hurt to see what a used transmission would cost for the one that runs...I tore an electric motor out of a power window, and that gave me some great ideas for a few projects as well. Quote:
So the receiver actually consists of two separate parts? The radio decoder, and then the signal from the decoder is sent to the PWM circuit? So in theory, i could just intercept the signal from the decoder before it is sent to the PWM to control my own stuff, instead of just having a PWM output? Oh, and thanks for the link to the 8UAF manual.
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | ||||
| | #13 | |
The Futaba color code is black-red-white. Black and red are the + and - supply; white is the signal. On the pinout from the receiver, red is center and white is on the side with the key tab. The signal pin will be the PWM to the servo. In PPM, the receiver consists of the RF section/demodulator and a PPM decoder. The latter determines to which pin (i.e., servo) each signal goes. A commonly used chip for that purpose is the HEF 4015. Each of the eight output pins goes to one channel. Here's the datasheet for that chip: http://pdf1.alldatasheet.com/datashe...HEF4015BT.html I have never looked at a PCM receiver that carefully. I suspect the older ones were similar, except there needed to be a decoder for the pulse code instead of position. Your receiver may be newer and more highly integrated. None of the new stuff I have uses that chip. It is all microcontroller. I keep the old receiver as an easy way to check some things on the Tx. John | ||
| | #14 |
Yay! It came today! They both work awesome. Pictures tomorrow (if i get time) The 8 channel one is really sexy! The four channel one looks like something you would find in a Happy Meal... , but it works great.
| | #15 |
What a coincidence. I just went out and bought a JR 9303 2.4GHz radio and a chopper to go with it the other day.
| bought, lookie |
| I bought a useless infra red lamp from China. | Brian Hoskins | Chit-Chat | 36 | 7th September 2008 02:20 AM |
| Lookie what i just got! (also need some info) | Marks256 | Chit-Chat | 16 | 7th January 2008 02:40 AM |
| Bought a Radio Shack Sun & Sky Monotoring Station on ebay | blueroomelectronics | General Electronics Chat | 2 | 6th December 2007 08:17 PM |
| Bought a AT89s51 first time..help | aryyy | Micro Controllers | 0 | 14th June 2006 09:36 AM |
| Need help powering a sub bass processor kit i bought. | dazzbo | Electronic Projects Design/Ideas/Reviews | 1 | 26th November 2003 02:46 PM |
