Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 3rd February 2008, 02:19 PM   (permalink)
Default Ubuntu question
I hope you guys don't mind but i have a feeling that i'm going to be asking a lot of questions as a try to learn linux. I have ubuntu loaded on my hard drive as the only operation system. Can it read a hard drive partioned with ntfs? And what file system does linux use?
Gaston is offline   Reply With Quote
Old 3rd February 2008, 03:12 PM   (permalink)
Yes Linux can write to NTFS (a more detailed answer would be x86,amd64,ARM can)
The package you need todo it is ntfs-3g
from a command line sudo apt-get ntfs-3g
You can do it from the GUI installer util and search for ntfs, but the command-line is handy for posting on forums
What filesystem does linux use? it uses quite a few
The most common is ext3 (with ext2 used where journalling isn't needed)
but the kernel source speaks enough
         <*> Second extended fs support                                                          │ │
  │ │                  [*]   Ext2 extended attributes                                                          │ │
  │ │                  [*]     Ext2 POSIX Access Control Lists                                                 │ │
  │ │                  [*]     Ext2 Security Labels                                                            │ │
  │ │                  [*]   Ext2 execute in place support                                                     │ │
  │ │                  <*> Ext3 journalling file system support                                                │ │
  │ │                  [*]   Ext3 extended attributes                                                          │ │
  │ │                  [*]     Ext3 POSIX Access Control Lists                                                 │ │
  │ │                  [*]     Ext3 Security Labels                                                            │ │
  │ │                  < > Ext4dev/ext4 extended fs support development (EXPERIMENTAL)                         │ │
  │ │                  < > Reiserfs support        │ │
  │ │                  < > JFS filesystem support                                                              │ │
  │ │                  < > XFS filesystem support                                                              │ │
  │ │                  < > GFS2 file system support                                                            │ │
  │ │                  < > OCFS2 file system support                                                           │ │
  │ │                  < > Minix fs support        │ │
  │ │                  < > ROM file system support                                                             │ │
  │ │                  [*] Inotify file change notification support                                            │ │
  │ │                  [*]   Inotify support for userspace                                                     │ │
  │ │                  [ ] Quota support        │ │
  │ │                  [*] Dnotify support        │ │
  │ │                  < > Kernel automounter support                                                          │ │
  │ │                  < > Kernel automounter version 4 support (also supports v3)                             │ │
  │ │                  <M> Filesystem in Userspace support                                                     │ │
  │ │                      CD-ROM/DVD Filesystems  --->                                                        │ │
  │ │                      DOS/FAT/NT Filesystems  --->                                                        │ │
  │ │                      Pseudo filesystems  --->                                                            │ │
  │ │                      Miscellaneous filesystems  --->                                                     │ │
  │ │                  [*] Network File Systems  --->                                                          │ │
  │ │                      Partition Types  --->                                                               │ │
  │ │                  {M} Native language support  --->                                                       │ │
  │ │                  < > Distributed Lock Manager (DLM)  --->
Nothing is impossible.
Styx is offline   Reply With Quote
Old 3rd February 2008, 04:45 PM   (permalink)
You can also read the ext2 filesystem from Winwoes with the freeware Ext2fs dirver.
http://www.fs-driver.org/
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
Capacitor Charge/Discharge question ThermalRunaway General Electronics Chat 25 12th August 2008 04:48 PM
Basic Transmission question CamNuge General Electronics Chat 2 8th March 2006 10:08 PM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 11:54 AM
Data Logging question with high speed!!!! cubdh23 General Electronics Chat 4 16th August 2004 06:33 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 06:21 PM
