| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
I didn't read the whole tread, so...
In short. YES!!!! GET LINUX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! If you REALLY need to run a winwoes program, there is always wine, or as a last resort, you could dual boot.
There is no "I" in "team", unless Apple makes it... Then it would be iTeam. |
Torben |
If we were over 100 times the size we are now, then wouldn't what we already have be nanotechnology!!! |
Torben |
well i tried it again, and still no luck, it just gets to the linux desktop and when i click on install, the install window opens up only with a white screen?
i might try to re burn it to another CD?
i had the same problem. i had to download it again. i guess a bit or two got messed up i the download
I have had really bad luck with KUBUNTU. That is why i went with ubuntu. Kubuntu kept fussing about this and that, when in ubuntu, i was able to do things that kubuntu wouldn't!
oh well. I like the simplicity of gnome (now). KDE is a BIT over kill. I still like it, too, though...
Torben |
I tried running it again and no luck i clicked on the install and walk away because it was taking forever?
after about 20 minutes the first WELCOME screen was available and i had to choose my country, but i couldnt do anything whenever i moved my mouse it was really slow and the CD drive sounded like it was trying to find a particular part of the CD, but it never worked? is there a way to install/convert the original ISO file to my spare hard drive without a reboot using the CD drive???
after about 20 minutes the first WELCOME screen was available and i had to choose my country, but i couldnt do anything whenever i moved my mouse it was really slow and the CD drive sounded like it was trying to find a particular part of the CD, but it never worked? is there a way to install/convert the original ISO file to my spare hard drive without a reboot using the CD drive??? [edit] when i downloaded it there were two download options one was for computers with sempron and ohers, and the other one was for computers with 64bit AMD and Intel computers. well i dont know what mine really was, on my computer it says AMD Sempron so i chose the first one that said sempron? i dont understand what that means.
(permalink) | |||
And on a Sempron, it is possible that running the Live CD might be quite (read: painfully) choppy. Quote:
You should probably check the downloaded ISO's MP5 checksum to make sure it's OK before you burn it. Use a tool like http://www.pc-tools.net/win32/md5sums/. Get the MD5 checksum from http://mirror.csclub.uwaterloo.ca/ub...s/7.10/MD5SUMS and open it. It has a few lines of text. Each line is an MD5 checksum followed by the name of the image file which it is for. Check that against the output of the md5sums.exe program. That said, if you're dead-set on getting the ISO you have onto a hard drive and trying to install from that, (brief) instructions are here: http://ubuntuguide.org/wiki/Ubuntu:G...e_or_USB_stick There is a catch, however--you will need a bootable Linux of some description, since you need to be able to boot via a bootloader where you can tell the kernel where to find the ISO you've copied onto the hard drive. More trouble than it's worth. If your PC can boot from a USB stick, and you have one that you can wipe and fit the ISO image on, you could try this: https://help.ubuntu.com/community/In...n/FromUSBStick But I'd consider both options to be last resorts (and even then, I'd try the second one first). Quote:
Torben |
ok i have XP Home edition
version 2002 service pack 2 mobile AMD sempron processor 2800+ 1.60Ghz and 192mb of ram do you think it should work ok?
But: get more RAM. Especially if you don't run Linux. 1 GB is just about good, 2 GB is fine for just about anything you'd want to do at home (for Windows). Linux doesn't need quite as much just to run, but RAM is cheap and it makes things much faster no matter what OS you're running. 192 MB may well be the reason things are running so slow for you. Torben |
[edit] is the Alternate version the server addition???
If we were over 100 times the size we are now, then wouldn't what we already have be nanotechnology!!! Last edited by shaneshane1; 1st February 2008 at 09:45 AM. |
Good luck! Post if you hit a speedbump, or if you succeed wildly. Torben |
| Linux And Electronics | arnieswap | General Electronics Chat | 4 | 23rd November 2007 10:23 PM |
| To Try Linux? | Styx | Chit-Chat | 48 | 4th October 2007 01:03 PM |
| Linux schematic/simulator | ukeee | General Electronics Chat | 11 | 8th October 2006 01:23 AM |
| linux picaxe serial programmer proggy?help...! | loqtius | Micro Controllers | 4 | 25th May 2006 11:17 AM |
| PIC-PG2 JDM programmer & Linux | Kane2oo2 | Micro Controllers | 1 | 20th February 2004 09:55 AM |
