+ Reply to Thread
Results 1 to 6 of 6
Thread: A question about Windows Virtual Memory
  1. #1
    HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent
    Join Date
    Jun 2006
    Location
    Penna. USA
    Posts
    2,503
    Default A question about Windows Virtual Memory
    Here are the details of the situation:
    "PC game on start-up shows message: Not enough memory in Virtual Memory Swap File, minimum 149MB required for this game."
    I set the Virtual Memory to: 1034Mb min. and 3000Mb max.
    I still get the same pop-up message regardless and the game is getting interrupted often as well as hanging up. Hitting the ENTER key seems to continue the game until it happens again.
    The game's system requirements are as follows:
    VIDEO CARD:
    Direct 3D compatible video card required. 3dfx Voodoo 3 or NVIDIA TNT2 recommended. Supported 3D cards include: 3dfx Voodoo2, 3, 5; NVIDIA TNT, TNT2, GeForce, GeForce2, ATI Rage Fury Max, Matrox G400.
    OPERATING SYSTEM:
    PC CD-ROM, Windows 95, 98, ME, 2000 (DirectX 7.0 or greater)
    CPU TYPE & SPEED:
    Minimum - Pentium II, Celeron 400, or equivalent required Pentium II 400 MHz or equivalent recommended
    HARD DRIVE SPACE:
    200 MB available
    SYSTEM MEMORY:
    64 MB required (with AGP video card: 128 MB recommend)
    CD-ROM SPEED:
    4x CD-ROM Drive
    DIRECTX:
    DirectX 7.0 or greater required (included on CD)
    SOUND CARDS:
    Windows compatible. Voice-Over-Net [VON] requires full duplex sound card
    Now the PC I have it installed on has:
    Pent.4 1.7Ghz
    1Gig RAM
    Windows XP Pro
    Direct X 9.0
    nVIDIA Quadro2 Pro 64MB (I even switched to a ATI Radeon 128MB card)
    Creative SB 5.1 processor audio
    Could it be the XP environment that the game doesn't like? IThe one thing I didn't do yet was to change that "environment " setting so it somewhat mimics Win98.
  2. #2
    theinfamousbob Okay
    Join Date
    Apr 2005
    Location
    Cleveland, Ohio, USA
    Posts
    546
    Blog Entries
    2
    I'd say try Win98 compatibility mode -- I've had a few games before from right around that time that will randomly crash/quit under XP. Compatibility mode usually solves it. I'm guessing you tried to restart after adjusting the virtual memory/swap stuff. It could also be a DirectX thing/video driver thing -- Call of Duty (the first one) runs at about 9 frames per second on my computer since about two nVidia driver updates ago. Used to run at 200+ frames per second.
    I'd try running compatibility mode first, then downgrading video drivers/directx. If you want to run the game that badly.
    What game is it? I'll obtain it and see if I can replicate the problem.
    -Ian
  3. #3
    UTMonkey Good UTMonkey Good UTMonkey Good
    Join Date
    Oct 2007
    Location
    Chesterfield, Derbyshire - UK
    Posts
    428
    The recommendation from M$ is to let the OS manage the virtual memory, do you get the same problem if you do this?
  4. #4
    Marks256 Excellent Marks256 Excellent Marks256 Excellent Marks256 Excellent Marks256 Excellent
    Join Date
    Jul 2006
    Location
    Minnesota, USA
    Posts
    2,390
    It should work under Wine...
    Anyways, what game is it?
    There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
  5. #5
    Join Date
    Jun 2006
    Location
    Penna. USA
    Posts
    2,503
    Quote Originally Posted by UTMonkey
    I tried both settings, auto and selective with the same negative results. The game is Delta Force Land Warrior, old by today's standards, but something my son wants to play. I've thought of loading Win98SE onto a second HD in his PC to handle older games like this one. I never thought about downgrading the video drivers and Direct X versions... that may screw it up for other games on his PC, esp. those that require Direct 9. The more I think about this Compability mode, the more I'm thinking of installing a 3rd HD in my PC loaded with Win98SE for such issues.
  6. #6
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,775
    With a game that old you will probably find that the programmer never expected anyone to have 256 meg of ram never mind 1 gig. He probably assumes that the higher bytes are zero and does a word check instead of a double word. Try setting the VM to 255 meg and see what happens. If this works then setting it to 511 or 767 should also work.
+ Reply to Thread
  1. Question about Inchworm+
    By Quan in forum Micro Controllers
    Latest: 28th October 2007, 12:21 AM
  2. Anyone tried Windows Vista? What do you think?
    By ThermalRunaway in forum Chit-Chat
    Latest: 6th July 2006, 07:46 PM
  3. memory addressing
    By samcheetah in forum General Electronics Chat
    Latest: 29th September 2004, 06:33 PM
  4. Networking Harddrives
    By crazymonkey in forum General Electronics Chat
    Latest: 9th March 2004, 04:55 PM
  5. Memory upgrades
    By electrogeek in forum General Electronics Chat
    Latest: 19th January 2003, 03:33 PM
Tags for this Thread
