| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
This thread is for cool projects that would be nearly impossible to build.
The project that i thought up of was a Soul Detector. This is going to be funny with all the retarded projects. |
2kW inverter running from a car battery.
2kW single driver audio amplifier. Hydrogen powered hybrid car.
Nuclear power too cheap to be worth metering!
There is also trying to duplicate the famous Acoustic Research speaker with a frequency response fron DC to blue light. |
R/C Helicopter from scratch, before having actually atempting to fly one...
VCR that records memories, dreams, thoughts... Engine fueled entirely by water... |
Everlasting solar powered torch; the solar pannel is powered by an LED which is run from the solar panel.
An IMU...a GOOD IMU.
Wasn't there also that machine that used magnetic fields to melt sand and then suck the iron out of it from a distance of several feet? Last edited by dknguyen; 10th June 2007 at 12:05 AM. |
A solar pannel that outputs 12v at 1amp under 10$
A nuclear AA battery A computer made completely out of potatoes and lemons A flying toaster using computer fans |
Self effacing intelligence.
Ego-less genius. Smart people. Human beings without human drives. Understanding for the good of all, not necessarily the 'betterment' Altruism, only real. It's only a dream, can never be possible as is always the case with altruism. I'm a solipsist, there is only ever self, but it's a very nice dream to have.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
Brian
--------------------------------- Electronics Test Development Engineer --------------------------------- Last edited by ThermalRunaway; 10th June 2007 at 03:39 AM. |
I'd like an immensely powerful telescope, so powerful that we could see the surface of planets in other systems. In a way, this would also be a time machine because of course we'd be seeing events that took place years or even hundreds, thousands of years ago.
Brian
--------------------------------- Electronics Test Development Engineer --------------------------------- |
I think I must have mis-read this thread at first, I thought it said. "The project that i thought up of was an 'ar*e Soul Detector." Now one one these I could make,,,, for FREE!
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Portable generator based on nuclear metastable states. Theoretically possible, but as of yet completely beyond the reach of current technology.
Muon Catalyzed Fusion. Already been demonstrated to work... only catch: finding a cheap source of muons. Cheap Muon Generator. Now here is a project that will earn you trillions and a nobel prize. Planetary Core remote measurement robot. A robot that can burrow into a planet's core and take measurements. A more difficult project than going into space as no one has figured out a way to make something withstand that much pressure and still function. Orbital tower. A tower that goes from the surface of the earth into space, would reduce space travel costs from billions down to a couple of dollars per ride. The Ultimate Particle Accelerator. If you thought the Large Hadron Collider was big then you have not seen the Ultimate Particle Acelerator. The UPA would be built around our solar system and have a circumference greater than the orbit of pluto. You're going to need plenty of free weekends to build one of these babies. Cyberneural interface. I'm tired of learning things the hard way, i want to download it. Free Neutron Extinguisher field generator. Basically this handy dandy device nullifies free neutron movement outside of an atomic nucleus. application: would render nuclear weapons inoperative while the field was running. Now we can let all those rogue countries build as many nukes as they want. If they ever launch em, we just turn on the field and the warheads would stop working. Unfortunately this device would also shut off our nuclear power plants. Ozone layer fixer. Some high altitude craft that would suck up all those bad chemicals that are killing the ozone layer and replace the layer with fresh ozone. Greenhouse nullifier. A series of HUGE floating islands set afloat in our oceans that would suck the excess carbon dioxide in our atmosphere and convert it into calcium carbonate that could be dropped on ocean floor. The ocean floor already has gigatons of the stuff so the dropping of more would not have adverse environmental impacts. Cure for all diseases. preferably should be cheap too. too bad stupidity isn't a disease. Fountain of youth. build one of these babies and now you and your spouse can get on each others nerves for all eternity.... on second thought this might not be such a great project. Time Machine. Enough said |
perpetual motion
The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. |
Any idea why we call a discharged battery 'a flat battery'. I said to my tutor, many years ago 'perhaps it was a flat battery' he chewed my n*ts off, saying there's no such thing as a flat battery.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 10th June 2007 at 02:54 PM. |
Windows that never crashes.
Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. |
| IMPORTANT!!!! PLEASE READ BEFORE POSTING!!!! | ElectroMaster | Electronic Projects | 0 | 7th June 2005 11:33 PM |
| max232 projects | reverendm | Micro Controllers | 5 | 5th March 2005 08:22 AM |
| the best of all kind of projects | cool-agent | General Electronics Chat | 4 | 30th December 2003 04:28 AM |
| Cool Car Projects | Clyd3 | Electronic Projects Design/Ideas/Reviews | 7 | 1st October 2003 02:20 PM |
