Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 26th May 2007, 04:23 AM   #1
Default ISA bus in Eagle
I haven't played around with Eagle for a while now, and yes, i did Google this question...
How would one go about making an ISA bus connector in eagle? Sure, i could buy an ISA development kit, but i do not want to spend $50+ on it when i already have access to a laser printer, copper clad, and etching solution.
I do not need the 16 bit right away, so i should be fine with the 8 bit part right now.
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 26th May 2007, 04:25 AM   #2
Oh, and for those who are wondering what i want to do, don't worry, i am wondering the same thing!
Actually i just want to make a simple adapter so i can interface the ISA bus to a breadboard (like i said before, i cannot afford the big development kits... )
Marks256 is offline
Old 26th May 2007, 04:46 AM   #3
Soggy yet?
Did not find a ready made part. CON-AMP has PCI card edge patterns but did not see ISA. Must be there somewhere?
If you are up to making the Eagle part try.
https://www.amphenolcanada.com/Produ...df/PCB_CAT.pdf
Look for "2.54mm Card Edge Connector Including ISA"
Then look for "Recommended PCB Layouts"
Should be enough detail to create the part.
BCHS/3v0's Tutorials
3v0 is offline
Old 26th May 2007, 01:37 PM   #4
maybe this will help you:
http://www.web-tronics.com/breadboar...ng-boards.html
they've got one for under $20, with the 16 bit connector
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 26th May 2007, 02:20 PM   #5
Soggy yet?
Thanks for the link. I have that saved now as a reference!
Thanks. I will look into that if i cannot find anything else.
I had my eye on something like this: http://www.jameco.com/webapp/wcs/sto...roductId=28206
But the one i wanted had a breadboard built right on the board. That would have been awesome! For some reason it just disappeared from jameco. I looked on ebay, but found nothing as well.
Marks256 is offline
bus, eagle, isa
Microchip library for eagle nclark Micro Controllers 5 12th February 2009 06:27 AM
How to properly do PCB edge connections in Eagle? toodles Electronic Projects Design/Ideas/Reviews 2 10th April 2007 11:36 PM
Eagle import/export -> Protel SE midnitrcr Electronic Projects Design/Ideas/Reviews 0 10th November 2006 09:54 PM
smd's in Eagle justDIY Electronic Projects Design/Ideas/Reviews 1 31st July 2005 09:22 PM
Help using Eagle. krunk General Electronics Chat 2 23rd January 2004 03:56 PM
