| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
| Hi guys! I just bought a new pc hoping to have some fun with it but it is making a fun of me! The problem is that the system doesn't boot up at first integration and it wont at second.It will boot at the third!Once it boots than if u restart the computer or even if shut down it and then press the on/off button it will boot. But when I put the main power supply cable off or just pull it out from mains and then again insert it in to the mains it wont boot at all.I have to shut it down and the try again and it will boot at third time! The processor fan spins the power supply light on's but no output at monitor. I have tried hard to figur out the problem but I can't so I need you help! I have the following hardware: Intel D965RYCK mainboard Intel Pentium D processor 3.40 Ghz 800 Mhz FSB 2*2Mb Cashe Kingston 512 MB Ram Seagate Hard Disk SATA 180 GB ASUS DVD-RW Conexant 56k Modem TV tuner card Alfa Digital PH7130 | |
| Take it back to the shop and they should either refund you, replace it or repair it.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 21st April 2007 at 12:18 PM. | |
| hi raiz, When you have powered the PC up and its working. Check your standby and sleep mode settings for the PC and Display monitor. Use the 'help' to find the correct dialog boxes.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| Check your BIOS (power management setup) try changing this *Soft off by PBTN *System after AC back | |
| I just solved the problem by updating the BIOS to the latest version and the computer works smoothly! | |
| Electronic system to stop sleeping problems - help with design of system | ZackSmith | Electronic Projects Design/Ideas/Reviews | 1 | 29th October 2006 10:43 AM |
| Electric firing system - Fireworks (again) | iamcat | Electronic Projects Design/Ideas/Reviews | 3 | 17th June 2006 03:27 PM |
| Car battery charging system | Barwick | Electronic Projects Design/Ideas/Reviews | 1 | 17th June 2006 12:49 PM |
| Consulting on Switch system. | GOMBO | General Electronics Chat | 1 | 26th September 2004 10:28 AM |
| i need a schematic of pic based alarm system..help me please | BurhanUnalmis | Electronic Projects Design/Ideas/Reviews | 0 | 26th April 2003 03:43 PM |
