Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 11th March 2007, 04:14 PM   (permalink)
Experienced Member
Marks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of light
Default Alternative computer cooling
My computer is just TOO loud. I have 6 fans in my computer;
1) PSU
2) Case
3) Case
4) Case
5) CPU
6) Video Card
Why all the fans? My computer runs HOT. It may not be hot to others, but it is the middle of the winter here, and we have the thermostat for our heater set at 68°F. My computer can heat my room to about 80°F!
In the summer my room is usually 20°F warmer than out side.
Oh yeah, AND THAT IS JUST ON IDLE!!!!!!!!
When i game, my computer is pushing 100+°F!
Like i said, i know that is not very hot for a computer, but i do not like heat. I wear shorts all year 'round (in the house that is )
So, anyways. What are some alternatives to fans? Liquid cooling is out of the question because i go to LAN parties fairly often, and liquid cooling needs to be drained before transportation...
I was thinking of an X-CLIO case (only one fan for the whole computer), but my friend already has one, and that would just not be cool...
Does anyone else know of anything that will save my hearing?
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is online now   Reply With Quote
Old 11th March 2007, 04:55 PM   (permalink)
Experienced Member
Put your computer in a fridge?
There's no way of simply getting rid of the heat, it can only be moved from one place to another, if you cool your PC down your room will heat up; it's thermodynamics.
Old 11th March 2007, 06:32 PM   (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
Get earplug-earphones. Take the cover off of your case. You can move your computer to the basement where it is usually much colder (I wear gloves sometimes in my basement).
Old 11th March 2007, 07:25 PM   (permalink)
Experienced Member
Well, yes, i don't much mind the heat (i can always crack a window), but the noise get rather anoying. Heat and noise don't really mix... at least for me...
What alternatives are there to fans (and liquid)?
Old 11th March 2007, 07:31 PM   (permalink)
Super Moderator
As suggested there are no real alternatives for what you want, and what you currently do - fans are making your room HOTTER, not colder, it's just transfering heat from the computer to the room. The only solution is to transfer the heat OUTSIDE your room, you could do this by ducting the PC fan through your wall and outside - plastic flexible pipe as used on tumble dryers (and a venting kit from one) would be all you need, and construct a suitable mount for your PC.
Old 11th March 2007, 07:33 PM   (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Yeah, learn a little bit about air flow, just tossing fans inside a PC case doesn't make it run cool. Proper air flow across the parts inside that heat up is more important.
Just adding fans will cause caotic airflow inside the case and that is NOT what you want, you want a nice even flow through the case. It's not easy plotting the airflow inside a PC case though, they're usually pretty crowded.
The single largest determining factor of the PC's temperature is the ambient temperature. If you want to cool the PC cool the room it's in, even the biggest heat sink in the known universe can't cool the PC internals bellow ambient temperature. The only other alternative to air conditioning the entire room is sealing the case air tight and using a massive peltier cooler to just aircondition the inside of the case, that would be expensive though as big peltiers aren't cheap. If the air flow inside the case is good and the ambient temperature is stays in the 65-70F range you shouldn't need any auxilary cooling fans. If you can't lower the ambient case temperature to the 65-70 range there is going to be no way to keep the machine cool.
Curiosity killed the cat; That's why they have nine lives.
Old 11th March 2007, 07:34 PM   (permalink)
Experienced Member
A peltier junction would solve the noise problem though it won't be as efficient as the fans so it'll make the heat problem worse.
Old 11th March 2007, 07:50 PM   (permalink)
Experienced Member
Some people use DC blowers inside their PC's instead of fans, because they can be quieter and they can produce a significant pressure buildup in the case as opposed to a fan which are designed to move air not produce real pressure. A single brushless blower card sucking air into the case and then relying on the power supply fan to exaust air out of it should be plenty. A good blower can be very quiet.
Old 11th March 2007, 08:45 PM   (permalink)
Experienced Member
hjames will become famous soon enough
Personally I have 2 fans in my machine - the power supply fan, and a processor fan - both of them low speed and barely audible. Mind you it's a low-end dual core AMD with a nice efficient heatsink, and a passive video card, but it does what I need it to do. At idle the CPU is about 15C over ambient, and at load, probably 30C.
www.silentpcreview.com's forums are the place to look, but the easy fixes are:
1) get a video card that is reasonable (something in the midrange of NVIDIA's line), and swap out the heatsink on if if you need to.
2) get rid of that dinky little 40mm fan on the motherboard chipset and replace it with something passive, and direct some airflow from a bigger fan over it.
3) replace the CPU heatsink with something like the Scythe "Ninja" or one of its cousins - these are big heatsinks which look like an air conditioning tech designed them, with lots of aluminum fins, and they cool very well with low speed airflow.
4) get an efficient power supply, and it'll naturally be quieter than the usual $10 special.
Low speed, high volume is the way to keep things quiet...
hjames is offline   Reply With Quote
Old 11th March 2007, 09:15 PM   (permalink)
Experienced Member
Bigger fans are more efficient and move more air at slower speeds = less noise.
Old 11th March 2007, 10:19 PM   (permalink)
Experienced Member
Yes, i know what heat transfer is. I was simply stating a fact that my computer runs hot. The only thing i wanted was advice on how to silence the beast.
"Yeah", obviously.
That i know. This is why i was thinking of getting an Xclio case (http://www.xclio.com/).
They are very expensive, but they look nice, and they get the job done with a single fan.
Old 11th March 2007, 10:45 PM   (permalink)
Experienced Member
Why don't you just get a new computer? Get a cooler running one with a better case. Perhaps you should get a more efficient processor and not such an overblown video card?
(lol those look like windtunnels) Those giant fans certainyl create more efficient airflow at quieter volumes...but have you thought about how they might create so much airflow, that their noise exceeds what you have now (albight, you are getting more cooling per dB of noise?)?
If I were you, Id' just get a pair of 99 cent earplugs, and some headphones.
Old 11th March 2007, 10:51 PM   (permalink)
Super Moderator
Simple answer, don't have so many stupid fans in it!.
Old 11th March 2007, 11:29 PM   (permalink)
Experienced Member
Dr.EM is on a distinguished road
Send a message via MSN to Dr.EM
I silenced my PC a few months back. Just changed the CPU cooler, GPU cooler, case fans and PSU for quiet models. Running the case fans from 7v. MUCH quieter altogether
http://www.overclockers.co.uk/showpr...id=123&subcat=
http://www.overclockers.co.uk/showpr...=57&subcat=787
http://www.quietpc.com/gb-en-gbp/pro...ns/nf-s12-1200
CPU cooler was from ebay. Thinking of modding it to use a 120mm case fan actually.
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline   Reply With Quote
Old 11th March 2007, 11:42 PM   (permalink)
Experienced Member
I can't afford a new one...
The case was actually made for the fans... It would look kinda ugly without them... I think i am going to invest in a new case.
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 27th August 2007 11:05 PM
Using a computer power supply WITHOUT a computer? grrr_arrghh General Electronics Chat 13 4th April 2007 12:15 AM
Thorn in my flesh: computer ? zachtheterrible General Electronics Chat 10 5th September 2004 09:26 PM
Bizzare computer zachtheterrible General Electronics Chat 14 31st May 2004 06:07 AM
Voltage transformer for computer cooling fan lk23 General Electronics Chat 2 19th June 2003 01:52 PM
