| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
Im staring here at two #0 screwdriver from two sets bought in North America, and third #0 phillips driver from Germany...and the #0 from Germany has a tip that looks to be the same size as the #1 tip from the North American sets....????
Are you confusing Philips and Posidrive?.
Don't think so, because I know these German ones are Phillips. The only way that would happen is if all the cross-head jeweler sized drivers I have just all happen to be Pozi-Drive.
sounds odd... not much purpose in numbering them if they're going to be different sizes then, right? That's like stamping a 10mm socket with 3 different values yet it still measures 10mm..... or three 10mm stamped sockets that have various internal dimensions!!!
Don't make me reach through this monitor to slap you a good one! |
There's also a 'Reed Prince' that looks like a phillips..
gerty |
It may be a JIS standard ( Japanese ) driver. They are slightly larger, and blunter , not actually a philips, but a similar cross-drive design. Actually a better one BTW, if you have the right tools for them.
Doing service work on Japanese electronics, mechanical parts, etc, you really need the JIS drivers unless you want to ruin the recess on the fastener. |
Bought in the USA, doesn't mean manufactured in the USA. We tend to import a bunch of crap tools and such... For me, I figure as long as it gets the job done.
miles are different gallons are different wire gauge is different (SWG versus AWG) a size 10 dress is different (not that I still wear them - honest !) football is different English is different rounders is the same but you call it baseball ? just teasing ...
I need a memory upgrade ... My head is full ! |
I'm in Canada so no offense taken
But, yeah, Wiha told me they made their drivers to phillips standard. |
A Posidriv screwdriver is much squarer ended than a Philips, and a 0 point Posidrive is considerably larger than a 0 point Philips - it still sounds to me that you're confusing the two?. Last edited by Nigel Goodwin; 20th July 2006 at 08:48 AM. |
Phillips screws may be very rare in your shires but here in the states they abound by the bazillions! The butterfly and Torx heads seem popular in the auto industry these days. Anymore, an American automotive mechanic needs a full complement of tools to interface slotted, Phillips, Torx, Butterfly, Square-drive and of course, hex head. That can add up to a costly set of tools and one large-azz chest to store them in.
Hmmm...I don't think I've ever seen a pozi-drive screw or driver unless which I was looking for one (which I never have).
Pozi-drives screws have cross etchings around the slot right? I've never seen those on any screw I've had. Unless you are implying that every screwdriver and/or screw around me is Pozi-drive without me knowing it. I believe you can interchange either pozi-drive or phillips drivers with the other kinds of screws, but it's one way only...I forget which driver is interchangeable with which screw. How can you identify a pozi-drive driver from a phillips driver? And how do you differentiate screws? I believe pozi-drive has some extra ethings or markings around the slot while phillips has none. Last edited by dknguyen; 20th July 2006 at 06:50 PM. |
Neither fit each other very well, Philips were mainly used in the 70's and 80's, then Posidriv took over - easy to tell from the screwdrivers, Philips have a fairly sharp point, and Posidriv have a fairly flattened point.
Interesting webpage at http://www.theautoist.com/posidrives.htm which give the impression that the USA lagged behind again, and perhaps continued to use Philips screws? - Philips themselves actually switched to Torx, probably because Posidriv won the cross-head battle?. |
We have Posidrive too but Phillips is still very popular here.... perhaps because Chinese goods are loaded with them and we import more goods from them than all the grains of sand on all of the world's beaches!!
