Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Notices
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 16th June 2006, 02:39 AM   (permalink (permalink))
Default Odd LED question
I'm trying to put water-clear LED's inside of a ping-pong ball to create little balls of light. Unfortunately the clear RGB LED's I got don't diffuse as much as I'd like. Any tips to maybe etch the surface of the LED's epoxy lens consistently to turn a clear LED to a more opaque dispursement? I'd just order replacements, but the RGB leds I got aren't exactly cheap.
Thanks in advance!!!
PDubya is offline
Old 16th June 2006, 02:52 AM   (permalink (permalink))
This maybe a silly suggestion. Try wetting the end and dipping it into some small crystals. Sugar may work, as I believe it is clear but appears white the same way as crushed ice looks white i.e. lots of internal reflection. A further thought, as no one can touch it, ground glass may work. I'd try it with a cheap red LED first.
Pommie is offline
Maybe try using a fine grain sand paper to roughen the surface (like the type used to tweak plastic models)? That is the first thing that comes to my mind, but if they aren't usable afterwards, please don't come running to me lol.
freeskier89 is offline
Old 16th June 2006, 03:36 AM   (permalink (permalink))
How fine? I tried some steel wool and it didn't really do much of anything but scuff the lens - the dispursement didn't change that much . I like the sugar/salt idea. I might try some superglue and salt. Great idea!
PDubya is offline
Old 16th June 2006, 06:52 AM   (permalink (permalink))
Grind of its lens so the top of the LED is flat then it will have like a 120 agnle.
You can also get the flat LEDs that have 4 pins they spread the light very far a aprt very bright too.2 of then and the whole ball sould light up.
Il give you shocking experience.
Someone Electro is offline
Old 16th June 2006, 09:52 PM   (permalink (permalink))
Last time I tried grinding off the end of a T 1 1/2 Led to get a flat faced one, all I ended up with was a LED that gave light as a tiny point. Many flat faced LED either have a fresnel type lens or the plastic body is a semi-opaque material that diffuses the light.
I like the idea of using crystals or something similar to diffract the light. What if you tried aiming the light into the edge of the ping pong ball material, and let the plastic ball act as a light guide. I have no idea if this would work or not, just throwing out suggestions.
zevon8 is offline
Old 16th June 2006, 11:11 PM   (permalink (permalink))
I use a very fine (240 grit) sandpaper. Have done it many times with good results for increasing viewing angle of water-clear LEDs. Try it on one and see if it works out for you.
Jack Luminous is offline
Old 17th June 2006, 02:57 AM   (permalink (permalink))
Regular old table salt & superglue worked perfectly!!! Thanks Pommie!
PDubya is offline
Old 17th June 2006, 04:45 AM   (permalink (permalink))
The most difusing LED would be if you carve a V shape insted of its lens.Meaby this if posible my putting the LED in a vice and using a tabletop drill.Then the led would be basicly 180 degre
Old 17th June 2006, 12:05 PM   (permalink (permalink))
I like it when a crazy idea works.
Pommie is offline
