Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 30th October 2005, 07:24 PM   (permalink)
Default light question
hi, i was replacing bulbs for my nan before and the maximum wattage for the whole thing was 260W if i loaded it with 300W or 400W would it be dangerous?
I just thaught that the bulbs wouldnt be as bright???
but i only loaded it to 200W anyway, just in case
madmikejt12 is offline   Reply With Quote
Old 30th October 2005, 07:27 PM   (permalink)
The wireing can overheat
Il give you shocking experience.
Someone Electro is offline   Reply With Quote
Old 30th October 2005, 07:30 PM   (permalink)
ah, so could it cause a fire? or just blow a fuse?
Old 30th October 2005, 07:32 PM   (permalink)
It should blow the fuse, but its not something you'd want to try.
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline   Reply With Quote
Old 30th October 2005, 07:34 PM   (permalink)
ok, thanks...
good job i didnt overload it then!!!!
Old 30th October 2005, 07:38 PM   (permalink)
No, it won't blow a fuse, lighting fuses are usually 5A (about 1250W).
The problem generally isn't the wiring, the current difference is really very slight anyway - it's the HEAT generated by the light, it will get too hot for the socket, and it could start discolouring and burning. If there's a shade on the bulb it's even worse, because the shade will get hotter as well.
High wattage bulb holders are usually ceramic, the lower wattage ones are bakelite - and smell horrible when they do over heat!.
Old 30th October 2005, 07:49 PM   (permalink)
but, on the lamp (about 4 bulbs) it has a maximum wattage, does this mean altogether or each one?
my "energy saving" bulb hass gone yellow not the holder, just the bulb.... it starts off dim and then gets quite bright (when i say dim, i mean like just below "normal")
Old 30th October 2005, 07:51 PM   (permalink)
on the main light, there are 2x100w and one 40w (5 bulbs altogether, 1 doesnt work, didnt want to overload it)
