| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
does anyone know why i cannot make any ftp connection from my house i have 3 computers which i have tryed this on i checked that my ftp site was working fine. and tryed a ftp.redhat.com but still no luck any ideas
thanks, dan ps: it says "a conection with the server could not be established"
when you post that reply, im just kidding. |
Meaby an antivirus program or an firewall is blocking the conection.
i disable windows firewall and zone alarm(my antivirus, spyware and firewall software) and still no luck
i did alot of googleing but didn't return much results
Did you laso try an difrent browser?
yes and a ftp program
Thats wierd.
I dont know what this cod be. Just download it from an nother PC that works and then transfer it to your PC.
i think that is what i am goin to have to do thank for the reply.
You shury have an USB memory stick or an black CD laying around.Or even beter if its in a LAN.
this is the problem though all the computers in my house will not ftp. i can do it at school but they don't let you use cds or memory sticks
Then ask your ISP.
i think i will have to, but there is a bad language barrier on the helpline
each of them has dialup connection or you have router or you are using one of them to run proxy server? |
this may not help, depending on the program you are using to FTP, but here goes anyways...
Many FTP programs have a small window that shows the actual list of commands being sent back and forth between you and the FTP server ( like a listing of DOS command line entries ) . During the exchange, you should see where things are going wrong. Maybe something like login failed, user name rejected, time-out, etc. Most commands are given as a number, followed by a very short description of the command, and then a response. Any error should show up as a " failed to .... whatever" From this you should be able to sort out where the communication is breaking down. here is a link to the program I use alot, WS-FTP, including a screenshot showing the info I refer to : http://www.york.ac.uk/depts/biol/help/basic/wsftp.html |
i use cute ftp 7 it is very good complete controll over everything, and yes you can see the command window. i have a screen shot.
i have used the username, ip and password before. it saves them.
Hi, what I was hoping to see was the debug window,( right behind the File Transfer Log Window in your screenshot.
If you can get a log of the connections debug output, you should have a good chance of determining why the connection fails. Try running CuteFTP in debug mode, with all connection settings to "automatic", this may help get the settings right. here is a listing of some of the numbers infront of the debug output: 1yz Positive Preliminary reply. The request action has been initiated,but another reply is to be expected before the client issues another command 2yz Positive Completion reply. The requested action has successfully completed, and the client may issue another command 3yz Positive Intermediate reply. The command has been accepted, but more information is required. The client should send another command in reply. 4yz Transient Negative reply. The command failed, but it can be retried 5yz Permanent Negative Completion reply. The command failed, and should not be repeated. The yz of each number above will be 2 digits that define the exact code, ie, 550 nonexistentdir: The system cannot find the file specified. 230 User xxxxx logged in. |
