+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 18
Thread: controlling with voice
  1. #1
    Abagtha Newbie
    Join Date
    Sep 2005
    Posts
    2
    Default controlling with voice
    Hey friends...
    I am an Electrical and Electronic Engg. student. My friend and I have to make our final year project.
    I would like to know if anyone can help me with a circuit on controlling with voice.....say...the tubelight or radio or any small gadget with voice. May be something like...when i say "on" the tubelight gets switched "on" and when i say "off" the tubelight gets switched "off".
    This is just some idea i have in mind. Do you have any other better or feasible ideas..?
    Thanks....
    Abagtha
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Are you allowed to cheat a little?
    Say, "Turn on." and it turns on.
    Say, "Off. (or Stop.)" and it turns off or stops.
    Hint: It counts the bursts of sound for each word. Two bursts turns it on, one burst turns it off or stops it.
    Don't let your teacher see a dog controlling it. :lol:
  3. #3
    Someone Electro Newbie
    Join Date
    Sep 2003
    Location
    A boring village in Europe (slovene)
    Posts
    2,601
    Yea.
    Even real speach reconition is NOT reliabe even on a PC.I once tryed one of those apps that you can control your PC whith.It constantly mistakes noises for comands and reconises a word wrong.You have to speak realy slow and reay realy realy clear.
    Not a good project to go on.
    Il give you shocking experience.
  4. #4
    Roboticinfo Newbie
    Join Date
    Jan 2005
    Location
    USA, California
    Posts
    1,042
    Well, if you only need to things Bernie it is quite accurate and company's use one chip that is at the top of the line right now.
    Go to this website and see which one you want
    http://www.sensoryinc.com/
    Bernie you most likely have not tried the new dragon naturally speaking or you have never used a kit from sensory inc.
    They mostly never mess up now it is like a 95% to 98% accuracy now.
    I have used the kit maybe 4 times and it has never let me down yet well maybe twice or so but that is it.
    Robotics is heaven in my book.
  5. #5
    mstechca Bad
    Join Date
    Mar 2003
    Location
    Why do you care?
    Posts
    1,598
    the two things you can detect from voice (if done electronically), is the duration of a syllable and the volume. Other than that, sophisticated circuitry is required. I don't do speech processing circuits, so I can't help you any further.
    -=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
  6. #6
    roboticmisinfo Newbie
    Join Date
    Jun 2005
    Posts
    118
    I imagine if you are doing this for a Uni project, then it will be getting the principles right, rather than making something that is 100% reliable. I have never built voice recognition circuits myself, but I imagine it would be very difficult designing your own. I reckon Audiogurus suggestion was pretty good. If you could design something similar to a VU meter on a Hi-fi, then have it triggering at a set Voltage. You could use a LM3915 and have one of the higher level outputs as the trigger. I'm not sure if this is the right advice, as I am only a beginner (someone please tell me if I am wrong!!!)
    Take a look here:
    http://sound.westhost.com/project60.htm
    By the way. If you are just turning a tube light on and off, why not just have it triggering on one syllable for both on and off. You can't turn a light on, and then turn it on again without turning it off can you? Unless you are doing anything more complexed, I don't see why you can't do something similar to one of those "clap" lights where you clap your hands to turn it on, and then clap them again to turn it off.
    Sorry if my ideas are stupid. I'm still learning,
    Kind regards,
    Mike
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Hi Mike,
    The LM3915 contains 10 comparators and a bunch of other un-neccessary stuff, for a fairly high price. To detect a voice a circuit needs only a single cheap comparator, or just a rectifier charging a capacitor. :lol:
  8. #8
    Join Date
    Jun 2005
    Posts
    118
    OK, sorry about that, I realise now it was a pretty daft idea. So you mean just an op-amp comparing the signal to the signal you want it to switch at? e.g. having a set voltage of say 0.8V, comparing it to say a 0-1V signal from the mic, and then having the op-amp output going high when the input voltage goes above 0.8V? Sorry,
    Kind regards,
    Mike
  9. #9
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by roboticmisinfo
    Yes, but a comparator switches its output much quicker than an opamp, if it matters. :lol:
  10. #10
    Join Date
    Jun 2005
    Posts
    118
    OK ops: - Could you then just have the output of the op-amp / comparator switching a transistor/relay on & off for your lighting circuit? Like I say, I am sorry, I've just started learning ops:
    Mike
  11. #11
    Abagtha Newbie
    Join Date
    Sep 2005
    Posts
    2
    Default Thanks
    Hey all...
    Thank you very much for all the ideas and suggestions.
    I am still deciding upon the project. My friend (with whom Im supposed to do the project), is quite interested in doing something with radio wave communications. So...we are tryin to see if we can do anything in that line as well.
    Pl do help me out with ideas and suggestions. Thank you all
    Regards
    Abagtha
  12. #12
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Actually, the output of a mic preamp is AC, so an opamp/comparator would switch for every half-cycle of the audio. The audio would need to be rectified and filtered to drive the input of an opamp/comparator selected for low DC input voltages.
    Then the relay would be activated only while the sound is louder than the circuit's threshold, so the opamp/comparator would need to drive a flip-flop circuit.
    It is a big difference from voice recognition:
    One bark and the thingy turns on.
    Two barks or another bark turns it off. Hee, hee. :lol: :lol:
  13. #13
    Join Date
    Sep 2003
    Location
    Posts
    2,601
    Just kill all the dogs in the area.(A shot gun shod work)
  14. #14
    Join Date
    Jun 2005
    Posts
    118
    Good idea. I never liked dogs anyway!! :lol: :twisted:
  15. #15
    Join Date
    Jun 2005
    Posts
    118
    So how would you make your own "voice recognition" circuit (rather than "sound activated") I thought you would have to have a lot of components/PIC's etc.
+ Reply to Thread
Page 1 of 2
1 2 Last
Tags for this Thread
