| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
| I tried to build a circuit which would randomely flash an LED. I guess it works, at least it looks random, of course its not really. But I was thinking about the criteria for something to be truly random. For instance, this device will flash the LED only, so the LED operates in only 2 states, on or off. To be of total randomness, it needs to be able to operate in an infinite number of states (bright, dim etc). Also, the LED will always change state at least once every 2 seconds. To be random, it could be off for a billion years and on for just a second. So I was thinking, these are dimensions, ie. time. There are supposedly numerous dimensions, some say 9, some say 11, some more. So, surely, for something to be completely random, it has to perform an action which is outputted in any of these dimensions, or multiple ones. Hmm, this is hard to explain, but imagine an equation where everything is X :lol: . As an example, something may happen in a dimension or multiple dimensions, under the rules of every other dimension, yet that something is undesigned.
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
| I don't get it... :lol: Solve this: X=Infinite+1
__________________ "I share, thus I am" Jay.slovak Read this! ICD2 Clone Best PIC/DsPIC Bootloader Read my Inchworm ICD2 review! | |
| All you need is some white noise. and drive it in a PIC and you shod get random 1 or 0 and than tralsate that on the LEDs
| Trying to solve : X = infinite + 1 ... ... ERROR 30563. Overflow at at adress $23 (variable X)
__________________ "I share, thus I am" Jay.slovak Read this! ICD2 Clone Best PIC/DsPIC Bootloader Read my Inchworm ICD2 review! | ||
| Yay!!! Etlest thats how a computer wod solve it. On paper well: 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 9999999999999999999999999999999999999999999....... .....................
| Code: X=inifinity+1
X= {1/0} +1
X=infinity
| I ran out of paper I think i got the 1000 sheet pack a few days ago
Get a radio, convert the output to light pulses. That will make random flashes, because you never know what frequency is coming out of the radio at any given time. And add some noise to the station, and the whole thing will be 100% random.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | ||
| Unforcenetly you cant see 1000 Hz blinking
| What I actually did was have 2 555 oscillators, completely independant of each other, thier outputs going to a AND gate. The frequecy of one of these is varied by a triangle wave oscillator, the frequency of the other by a mixture of square and triangle waves. Its not technically random, but it looks like it is, its never the same pattern. I intentianally used cheap timing capacitors :lol: When I put it up to audio frequency, there was a definate "noise" to it, but also some pretty obvious repeating petterns.
| Yea but he wants it totaly random. You cod do realy precice 0,1ms timing for you to hit a button.It will be random for shure
| Then train a rat to do it for you.
| Noise idea seems possible. You could use amplitude of the peaks to control brightness. and frequency of each peak over a certain height to control duty cycle of LED. Plus if you were to amplify the noise to feed it into a controller you get additional noise and randomness. Wait how random is white noise anyway? This is like trying to read RAM registers at random and trying too truly randomize the process....What ever happened to that idea? Was it random? | |
