Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 25th June 2005, 01:38 AM   (permalink)
Experienced Member
mstechca can only hope to improve
Default lawnmower almost fixed (maybe)
This is interesting.
I did an electricity test on my lawnmower with the following scenarios:
I connected the spark plug socket to a vice grip that conducts electricity. then I connected it to the gas tank. when I pulled the cord on the lawnmower, I saw sparks fly off the gas tank about every 1/2 a second. This makes me think that the magneto circuit is working properly.
When I replaced the vice grip with the spark plug and left the other end of the spark plug hanging, and I tried starting the engine, no sparks came out. Do I need to connect the other end of the spark plug to something to test it?
I don't have a spark plug tester. Is there any way I can make a say a 6 or 9V circuit that tests spark plugs?
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline   Reply With Quote
Old 25th June 2005, 03:14 AM   (permalink)
Experienced Member
chiba is on a distinguished road
Probably not a good idea to induce a spark around your petrol tank :roll:
You have the plug removed from the engine and still attached to the ht lead right? then just rest the threaded part of the plug against the engine or somewhere free of paint. You should notice a spark between the plugs end electrodes. Didn't you say it was a new plug? it should be ok providing you have not dropped it on the ground and not opened the gap too much, about .025" should suffice. Why did you start a new thread?
chiba is offline   Reply With Quote
Old 25th June 2005, 04:06 PM   (permalink)
Experienced Member
ante is on a distinguished road
Sorry for jumping in here but I like to know was the spark white/light blue or red/orange coloured?
ante is offline   Reply With Quote
Old 25th June 2005, 10:42 PM   (permalink)
Experienced Member
The spark was light blue.
After checking everything I can think of, the stupid lawnmower doesn't work! When I pull the cord hard, It sounds as if the engine wants to run, but it dies down instantly.
The best I can get when I tried starting it is one or if I am lucky, two pops.
Why doesn't it just give me several pops, and turn on like it used to?
Old 25th June 2005, 11:32 PM   (permalink)
Experienced Member
plot is on a distinguished road
Lawnmowers are stupid simple.
Did you drain all the gas out of it before you let it sit in the garage all winter? Or did you let it sit in there basically turning to turpintine and ruining the carbrator and what not?
the choke broken? (if there is one), and is the primer working properly? (if there is one... normally says "push 3 times before starting mower")
plot is offline   Reply With Quote
Old 26th June 2005, 12:51 AM   (permalink)
Experienced Member
The gas tank was if anything, 1/4 full throughout winter.
If that was the case, then why does my lawnmower almost start now, and it worked well one week ago?
Old 26th June 2005, 01:08 AM   (permalink)
Experienced Member
eh, does it take straight gasoline, or do you gotta mix something in with it? maybe you put to high of octane gas in it and blew a seal or something...
Old 26th June 2005, 01:27 AM   (permalink)
Experienced Member
It takes gas and oil, but they are not supposed to be mixed. Oil goes in one section, gas goes in another.
Old 26th June 2005, 01:32 AM   (permalink)
Experienced Member
My suggestions: new carborator... and pull harder
Old 26th June 2005, 02:48 AM   (permalink)
Experienced Member
I still think he'd be better off with a goat
Old 26th June 2005, 03:51 AM   (permalink)
Experienced Member
Phasor is on a distinguished road
If goats unavailable, alpacas work just as well.
Phasor is offline   Reply With Quote
Old 26th June 2005, 08:42 AM   (permalink)
Experienced Member
bryan1 is just really nicebryan1 is just really nicebryan1 is just really nice
Eh Chiba,
I've got 5 goats and those ****** things eat everything but grass. If the bloke I rang last week doesn't come and pick em up then they'll be eatin a bullet for dinner. By the way if your in SA do you want them ????
Cheers Bryan
bryan1 is offline   Reply With Quote
Old 26th June 2005, 09:42 AM   (permalink)
Experienced Member
Try some of this, remove the air cleaner and give it a small dose!
Old 26th June 2005, 10:40 AM   (permalink)
Experienced Member
Originally Posted by bryan1
Eh Chiba,
Cheers Bryan
Lol, ok then, get a couple of sheep to do the lawn and let the goats prune the trees, garden and clothesline
ante, sorry mate, couldn't resist
Old 26th June 2005, 05:05 PM   (permalink)
Experienced Member
I have a gut feeling that I over-flooded my lawnmower interior in its entirety.
I will have to consistently pull the cord unless there is a better solution.
