Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Chit-Chat
Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members.
Old 24th June 2005, 09:13 AM   (permalink)
Experienced Member
chiba is on a distinguished road
Originally Posted by mstechca
I saw sparks from the spark plug itself when I pulled the cord.
Given you have a spark already there is probably no need to concentrate on that side of things, But for the record a gap of 5-15 thou is good enough, losen the coil mounting screws, put a feeler gauge of the right thickness between the coil and flywheel magnet and let the magnet hold the coil up against the feeler, then tighten the coil and remove the feeler gauge.
If you have a seperate oil and fuel tank then it could be a 2-stroke with an automatic oil pre-mixer?, very much like most chainsaws.
If you are referring to an oil tank on the engine then it may be the crankcase of a 4 stroke that you are referring to?
It may be helpfull to all of us if you were to take a pic, give its model and brand numbers or ask a friend to have a look for you. If non of that is available then a google image search of "lawnmower" may show up the one you have.
If you decide to buy a new lawnmower, can i suggest this type, you will never have to worry about it starting
chiba is offline   Reply With Quote
Old 24th June 2005, 09:19 AM   (permalink)
Experienced Member
Roboticinfo is on a distinguished road
Send a message via AIM to Roboticinfo
[quote="chiba"]
That is bad advice
first of all you don't even no what a magneto is
and you do not want to mess the coil until you know that a business card can fit under the magneto. You do not need a feeler guage. You do not use a feeler guage to see if the magneto is alined!!.
What go's through your head?
Plus you need to work on your jokes
Robotics is heaven in my book.
Roboticinfo is offline   Reply With Quote
Old 24th June 2005, 01:01 PM   (permalink)
Experienced Member
mstechca can only hope to improve
I managed to make the coil and the flywheel so close together, that only two sheets of lined paper can go through. at a time without a problem.
I'm thinking now it is the gas pump because when I was working on the carberator pump, I used a soldering iron to expand the rubber. the rubber didnt break!
but my soldering iron accidently went on the plastic which is part of the gas pump. I also saw a small metal ball where the hole is.
Is it normal to have a small hole there, or no hole at all?
Maybe this is the reason why it doesn't start.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline   Reply With Quote
Old 24th June 2005, 01:24 PM   (permalink)
Experienced Member
bryan1 is just really nicebryan1 is just really nicebryan1 is just really nice
[quote="Roboticinfo"]
Given you have a spark already there is probably no need to concentrate on that side of things, But for the record a gap of 5-15 thou is good enough, losen the coil mounting screws, put a feeler gauges of the right thickness between the coil and flywheel magnet and let the magnet hold the coil up against the feeler, then tighten the coil and remove the feeler gauge.
That is bad advice
Well I've spent over 20 years working in the mechanical field and as far as I'm concerned where a bloke recommends to use a feeler gauge he knows what he's talking about, However, where another bloke ridicules the previous quote saying he knows nothing and recommending a business card :shock: !
Well Roboticinfo as business cards can either be paper or plastic the thickness will vary from 10 thou to over 25 thou depending on quality and material. Feeler guages are used by tradesmen, business cards are used by backwood hillbillies who think they are god. For christ sake respect a fellows comments instead of implying U are the almighty on every subject that comes up in this forum.
Anyway as far as the joke goes I might have to call one of my goats roboticinfo. If you like I'll take a snap shot for ya's all
End of Rant
bryan1 is offline   Reply With Quote
Old 24th June 2005, 01:27 PM   (permalink)
Experienced Member
Old 24th June 2005, 04:29 PM   (permalink)
Super Moderator
mechie is a jewel in the roughmechie is a jewel in the rough
Default Surey not ?
I think that is totally uncalled for and hope you have the humanity to see the error in your ways.
It would be an outrage to burden a poor caprid like that, don't you have any rats that need a name ? :wink:
I need a memory upgrade ...
My head is full !
mechie is offline   Reply With Quote
Old 24th June 2005, 07:50 PM   (permalink)
Experienced Member
Default Re: Surey not ?
I find his comments amusing
I like to hear what other people think of me.
Thanks for the back up though
Old 24th June 2005, 09:03 PM   (permalink)
Experienced Member
Originally Posted by Roboticinfo
...first of all you don't even no what a magneto is......
Actually, the term magneto was first coined to describe the use of "magnets" to generate the power in an ignition circuit instead of a battery. Nowadays, modern small engines can have cdi, hei and various other types of ignition systems that on the outside appear to be very much the same in looks as a coil in a "magneto" sytem. It's not uncomon to find a diode(s), capacitor(s), SCR (inplace of points) a trigger winding for the SCR, an energiser coil as part of the "magneto winding", the primary HT winding and the secondary HT winding to the sparkplug. I have modified a few so called "magneto" sytems to remove the rev-limiters for racing purposes to allow many more rpm's, it's basicly a low pass filter also hidden inside the coil of a "magneto" ignition. The tricky part is getting the epoxy off and vacuum potting it together again to remove all the air bubbles. I mentioned in another thread, the one where you referred to me as a newbie! that my mate built me a vacuum potting machine so we can build our own "magneto" and HV coils.
lol, I'm definately calling this one robotinfo:
Old 25th June 2005, 04:03 AM   (permalink)
Experienced Member
Ohh so how is your [EDIT]
How often does he make you vacum potting machine?
You guys must [EDIT]
Anyway I called you a newbie because you were bad mouthing my friend Digitan and you wouldn't leave him alone. [EDIT]
EDITED by MOD, Jay.slovak
Please by polite to your fellow members!
