| Chit-Chat Relax for a bit and have a general conversation (off topic is allowed!) with other members. Please be polite and respect your fellow members. |
| Experienced Member | Quote:
If you have a seperate oil and fuel tank then it could be a 2-stroke with an automatic oil pre-mixer?, very much like most chainsaws. If you are referring to an oil tank on the engine then it may be the crankcase of a 4 stroke that you are referring to? It may be helpfull to all of us if you were to take a pic, give its model and brand numbers or ask a friend to have a look for you. If non of that is available then a google image search of "lawnmower" may show up the one you have. If you decide to buy a new lawnmower, can i suggest this type, you will never have to worry about it starting | |
| Experienced Member | [quote="chiba"] Quote:
That is bad advice first of all you don't even no what a magneto is and you do not want to mess the coil until you know that a business card can fit under the magneto. You do not need a feeler guage. You do not use a feeler guage to see if the magneto is alined!!. What go's through your head? Plus you need to work on your jokes
__________________ Robotics is heaven in my book. | |
| Experienced Member | I managed to make the coil and the flywheel so close together, that only two sheets of lined paper can go through. at a time without a problem. I'm thinking now it is the gas pump because when I was working on the carberator pump, I used a soldering iron to expand the rubber. the rubber didnt break! but my soldering iron accidently went on the plastic which is part of the gas pump. I also saw a small metal ball where the hole is. Is it normal to have a small hole there, or no hole at all? Maybe this is the reason why it doesn't start.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
| | (permalink) | ||
| Experienced Member | [quote="Roboticinfo"] Quote:
Well Roboticinfo as business cards can either be paper or plastic the thickness will vary from 10 thou to over 25 thou depending on quality and material. Feeler guages are used by tradesmen, business cards are used by backwood hillbillies who think they are god. For christ sake respect a fellows comments instead of implying U are the almighty on every subject that comes up in this forum. Anyway as far as the joke goes I might have to call one of my goats roboticinfo. If you like I'll take a snap shot for ya's all End of Rant
__________________ " The only way to avoid human error is to avoid the use of humans" | ||
| Super Moderator | Quote:
It would be an outrage to burden a poor caprid like that, don't you have any rats that need a name ? :wink:
__________________ I need a memory upgrade ... My head is full ! | |
| | (permalink) | ||
I like to hear what other people think of me. Thanks for the back up though
__________________ Robotics is heaven in my book. | ||
lol, I'm definately calling this one robotinfo: ![]() | |
How often does he make you vacum potting machine? You guys must [EDIT] Anyway I called you a newbie because you were bad mouthing my friend Digitan and you wouldn't leave him alone. [EDIT] EDITED by MOD, Jay.slovak Please by polite to your fellow members!
