do you have any pictures, what was the use of those capacitors?
I have 3 capacitors in parallel and a power supply in a metal case. I will sell the whole thing or I will part it out. I use it just for fun on July 4th. I discharge the cap bank through 6 ft of 1/8" solid steel wire. The wire vaporizes, the Boom sounds like a high powered rifle, the flash is like looking at the sun or 200 arc welders all welding at the same time. I got a free used 5KW flash lamp from the airport and flashed it the whole thing vaporized. Discharge this on a 1/4 mile of electric fence wire it looks and sounds like a 1/4 mile of det cord exploding. I bought 14 of these used sold them all 20 years ago this is the only one I have left.
410 MFD 5000 VDC 18,000. Amp High Energy Storage Capacitors Caster Oil Filled wt about 100 lbs. each cap. These are $1500 each brand new.
5000 Volt DC power supply. This would probably cost $500 brand new.
NL 7171 35,000. amp discharge tubes 3 each. These were $980 each brand new last time I checked 7 years ago.
Make me an offer. This is pick up only in Murfreesboro, TN 37129
They were used by GE to test new electric motors. The engineers said the caps bank was charged to a certain voltage and amp rating then connected to the new motor windings if the motor did not short out and discharge the cap bank then it was a good motor. GE closed and all the equipment in the building was sold at public auction. I had 14 of these units sold them all but one many years ago. I will get some photos.
cool ratings............
please tell cost of it..i like it.
WoW!!! That is too Cool!!!
jer![]()
I have been so busy I forget to take pictures. I will try to remember to do that tomorrow.
So we ever going to get to see these things or what?
How about some prices and estimated shipping weights too?![]()
"Only someone with something to hide has reason to fear open and honest communication."
The scariest thing about where I work is that I am the good employee!
Here are the photos of the capacitors, power supply, rectifiers, discharge tubes.
The Discharge tubes are about $1000 each brand new. Go to this web page for prices. http://www.iclocator.com/NL7171_inventory.html
The capacitors are over $1000 each. I talked to sales they could not give me an accurate price on the spot.
I'm not sure what the power supply is worth, see if you can built it for less than $1000.
Make me a reasonable offer and your the new owner.
Gosh, I was worried about you. I even checked here.
It is good to hear you are still with us, but that is one powerful combination. I hope you don't sell it to just anyone who can scrape together the money.
John
I see there is a typo in the subject line.
Capacitors are 410 MFD 5000 VDC 18,000. Amp High Energy Storage Capacitors Caster Oil Filled......... EACH.
This = 54,000. amps = 270,000,000. Watts.
This is one of the most fun toys I have ever owned. It sure is fun on the 4th of July, I can raddle windows for several blocks and it is LEGAL. Works great for making water explosions discharge into a table spoon of water it sounds like 2 sticks of dynamite exploded. A water explosion will blow a basket ball size hole in a 3/4" sheet of plywood. I know when water turns to steam its volume increases 1800 times.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| HIGH voltage capacitors? | Mishael | Datasheets, Manuals or Parts | 11 | 23rd May 2010, 07:22 PM |
| High Energy Load dump/Voltage Clamp | mrmin | General Electronics Chat | 14 | 16th March 2009, 12:19 AM |
| High gain Low Noise Amp | srineo173 | General Electronics Chat | 2 | 5th January 2005, 07:53 PM |
| Newbie- I want to pulse a low voltage high amp source. | ukmxer | General Electronics Chat | 5 | 30th September 2003, 07:24 PM |
| any bdy having a schematic of a high powered stereo amp | Raheem | Electronic Projects Design/Ideas/Reviews | 0 | 30th July 2003, 05:02 PM |
