- Blog entry posted in 'Uncategorised', June 13, 2009.
Sometimes we think, "it is just an innocent relay", why add a freewheeling diode or some other snubber circuitry?
Well, take a look. I took those pics of a common 12V relay and a mechanical switch to toggle it.
I used a VC-6545, to measure. Storage mode and Norm. triggering.
This is the pure circuit, without any snubber:
Behold that you have a lot of spikes, the peak voltage is 284V, and the total "spiking" time, is about 150 µs.
Now just imagine a BC548 with those spikes across the collector (Vceo = 30V).
Or worst... A low voltage MOSFET would have its gate's oxide destroyed, if there was a series of relay switching events.
It is important to say that I was using a mechanical switch, so I'd have power loss on the contacts. With a transistor the spiking would have much more power. And more power means more voltage.
When I add a snubber capacitor (I used a 100nF ceramic), this is what it looks like:
Much more well behaved. The peak value is 160V.
The capacitor amortized the high frequency spikes, leaving a clean signal.
But still, we have a high voltage peak. That would not be a problem to a 200V rated device, but it is pretty high for a general purpose transistor/mosfet.
That's why in kettering ignition system there is a snubber capacitor with the contact breaker, to prevent contact erosion and capacitors can withstand high power spikes.
This is what happens when there is a freewheeling diode (used a 1N4148):
It is beaultiful, just a 12V step. No spikes. Of course if there was a high power application, a low power diode would fry. But for 12V relays that drains 100 mA, they are good.
There is lots of theory why that happens. But grossly speaking:
When you cut the voltage across a inductor, the stored EMF generates a flyback current with the same direction as the feeding current. (If the current flowed from A to B, the flyback still flows from A to B), therefore, a opposing voltage will build up.
That's why a freewheeling diode works well. In a normal operation, it is reverse biased, when there is flyback currents, the diode is direct biased, so that the power supply sinks the high voltage spikes.
Conclusions:
- No snubber: High voltage spikes.
- Capacitor snubbing: We still have a bit of high voltage, but the signal becomes well behaved. For high power application the capaciotor is one option.
- Freewheeling diode: The best results, but if the flyback current is too high, a high power diode would be required.
- Another snubber option would be MOVs (Metal Oxide Varistors).
edeca, June 13, 2009
Excellent post Hayato, thanks very much.
smanches, June 17, 2009
Are you sure about the direction of the current when an inductor powers off? It should be flowing in the same direction as the normal current flow. The reason for the freewheel is to give the current a path to flow. Since the switch that was powering it is now off, there is no loop back to the source. The diode gives it a loop for the current to flow through. It just keeps looping through the coil and diode until it dissipates.
Hayato, June 17, 2009
[QUOTE=smanches;bt152]Are you sure about the direction of the current when an inductor powers off? It should be flowing in the same direction as the normal current flow. The reason for the freewheel is to give the current a path to flow. Since the switch that was powering it is now off, there is no loop back to the source. The diode gives it a loop for the current to flow through. It just keeps looping through the coil and diode until it dissipates.[/QUOTE] Indeed. Thanks for the warning, I'll correct that. Same flow, opposing voltage (within a source current always flow from - to +).
alphacat, February 27, 2010
I really enjoyed reading this article. I wish you will write more articles about other subjects.
