- Blog entry posted in 'Uncategorised', September 22, 2009.
I've gotten as far as making a motor move forward and reverse via remote. I got the PWM interpreter to work much more accuratly by using the CCP1 module, and configuring it to set to capture rising edges, then on that event record the time and switch to capture falling edges, then on that event it captures the time, subtracts for the width and switches back. I'll get into the circuitry that controls the motor later, for now, here's my code for PWM capture.
//Basic configureation of chip periferials
#pragma config OSC = INTIO2, WDT = OFF, LVP = OFF
#include <p18f1320.h>
//setup pins for PWM input
#define ReceiverPin PORTBbits.RB3
#define ReceiverTris TRISBbits.TRISB3
//PWM capture variables
unsigned int PWM1RiseTime = 0; //timer value at rising edge capture
unsigned int PWM1Width = 0; //calculated width
char PWM1Edge = 1; //edge currently being monitored 1 = rising, 0 = falling
//set up interrupt
void low_ISR(void);//prototype
#pragma code low_vector = 0x08
void low_interrupt (void){
_asm goto low_ISR _endasm
#pragma code
#pragma interrupt low_ISR
//debug stuff
char test1 = 0;
char test2 = 0;
void main(void)
unsigned int MotorCount = 1;
unsigned char MotorOn;
OSCCON = 0x72; //8MHz clock
while(!OSCCONbits.IOFS); //Wait for OSC to become stable
//configure timer1
OpenTimer1(0b10010101);
PIE1bits.TMR1IE = 1; //periferial interupt register, 1 = timer 1 interupt enabled
PIR1bits.TMR1IF = 0; //clears the timer 1 interupt flag
//configure CCP1
CCP1CON = 0b0000101; //configure CCP1 for capture, rising edge
INTCONbits.PEIE=1; //enable peripheral interrupts
PIE1bits.CCP1IE=1; //enabled CCP1 interrupt
INTCONbits.GIE=1; //enable branching to interrupt
ReceiverTris = 1; //set RB3 for input so the capture can work.
//configure ports
ADCON1 = 0xff; //all digital
INTCON2bits.RBPU = 0; //port b weak pullups on
//configure control bits for output
TRISBbits.TRISB1 = 0;
TRISBbits.TRISB4 = 0;
TRISAbits.TRISA4 = 0;
//enable bit
LATAbits.LATA4 = 1; //Enable bit
while(1)
void low_ISR(void)
test1 = 1;
//ccp interrupt
if(PIR1bits.CCP1IF == 1)
PIR1bits.CCP1IF = 0; //clear the flag
if(PWM1Edge == 1)//if detecting rising
PWM1RiseTime = CCPR1;//save the low timer value for the rise time
CCP1CON = 0b0000100;//switch to detect falling edge
PWM1Edge = 0;//switch to indicate falling edge is next
else //detecting falling
PWM1Width = CCPR1 - PWM1RiseTime;
CCP1CON = 0b0000101;//switch to detect rising edge
PWM1Edge = 1;//switch to indicate rising edge is next
if(PWM1Width > 1800)
LATBbits.LATB4 = 0;
LATBbits.LATB1 = 1;
if(PWM1Width < 1400)
LATBbits.LATB4 = 1;
LATBbits.LATB1 = 0;
if(PWM1Width > 1400 && PWM1Width < 1800)
LATBbits.LATB4 = 0;
LATBbits.LATB1 = 0;
the part at the end with the latches is just to test it out on a small motor controlled through an L298n h-bridge chip, I have B4 and B1 connected to the control pins, and A4 is on the enable pin. The code is currently getting around 1650 for pwm width in the middle position of the controller, and 1200 and 2200 at the ends respectivly.Comments
