- Blog entry posted in 'Colour Maximite', November 30, 2012.
I have taken Geoff's project, and had a really good play with it...
The project's pages are here.. http://geoffg.net/maximite.html
I first saw this when Bryan posted the original system in the forum... I thought " If only it were colour".... Guess what!!!! He has done just that.
It has 8 colours available, which does give a reasonable palette... He has made four modes... 1 through 4... Mode 1 is the original mode black and white 480x432 pixels... Mode 2 has the same size screen resolution but a choice of 4 colour palettes... Mode 3 is the main mode with 480x432 and all 8 colours... Whilst a gaming mode Mode 4 has half the resolution and all 8 colours .
I purchased a UBW32 ( bitwacker ) from proto pic. http://proto-pic.co.uk/usb-32-bit-whacker-pic32mx795-development-board/
I bought a SD module http://proto-pic.co.uk/breakout-board-for-sd-mmc-cards/
And all the other little devices from Farnell ( Elements ) VGA connector, B/Backed clock circuitry, connectors etc...
All together I think I've spent around £50... Its not bad for a prototype system...
First off I need to put some headers on the UBW32 board.
69558
And a pickit3 header on the top.
69559
The next exercise is to take a piece of stripboad and "try" and mount all the gubbins I need to run this thing...
I had to sacrifice several connections near the SD card so I could route the relevant pins to where they needed to go..
( They weren't where they needed to be ) After pulling around 10 connectors out of the headers I managed to wire it up.
I placed a good deal of connections UNDER the UBW32 as to make it look nicer... My end result was this..
69560
As you can see... Not brilliant, but functional...
Before I went any farther, I connected the device up to pickit3... Downloaded the firmware ( You import the hex file into MPLAB )
REMEMBER to set the pickit3 power to 3.3v in the config page in MPLAB... Otherwise, MPLAB won't see it... Once pugged in, I uploaded the firmware onto the UBW32 board...
Reconnected via USB ( install the driver from Geoff's site )... You can now converse with the Maximite basic interface...
I place the UBW32 in its socket on my new prototype board... Powered it up.. I saw the SD card LED flicker... WOW!!! It worked straight off
Here's the setup as it sits on my desk.
69561
The PSU (wallwart for you Americans) is 12V DC but the little 5V reg on board got a little hot... So I placed the little LM2490T-8 in circuit to help dissipate the voltage drop.
As you can see I have a 4 way KVM switch with an opening free... The monitor and keyboard plugged in..
69562
I had also downloaded all the examples from the web... I put them on my SD card....
I wrote a small program using the little knowledge I had and saved it as "myprog.bas".. I know.. Original isn't it.
Saved it to the SD card.. To run the program you type.... "run".
69553
Here's my little program running... A couple of sprites, a couple of texts and an analogue pin read.
69554
To see what files are on the SD card you just type "files" and it will list the root directory..
69555
You can manipulate the SD card just as easy as MSDOS... I played with most of the commands to see how things worked. On the whole, it worked as expected, it was a joy to play with..
We are playing at the moment with dithering, so we can display pictures and make the look as good as we can.
Here's a photo of the "Chuckle brothers".... It came out pretty good.
69557
I'm going to play more and update this blog... I think its a little winner ( to say this is software generated 8 colour VGA signals )
Cheers Geoff... Thanks for sorting the little bug out...
Ian Rogers, December 28, 2012
I will upload the pictures again when I get back to work.
