12DC Sockets
« First ... 2127282930313233343541 ... Last »
  1. #301
    KeepItSimpleStupid KeepItSimpleStupid is online now
    Breakdown when it say refers to a capacitor is destructive. Capacitors are rated in WV or Working Voltage. When the breakdown is exceeded, a hole gets punched in the dielectric which is unrecoverable.
    In the other case, as long as the current is limited, there will be do damage.
    TVS
    A TVS is designed to control spikes, but it does have a particular time response. Gas discharge tubes are another way to deal with MAJOR surges.
    Rectifiers
    Diodes and rectifiers are the same UNLESS you happen to be in the plating industry. For some dumb reason: http://www.caswellplating.com/kits/rect.htm
    You will learn the hard way when you span multiple industries the terms are not the same. The color red, for instance is always the negative lead of a thermocouple.
    0
  2. #302
    cowboybob cowboybob is offline
    Graham,
    Here's the zener pics I mentioned.
    NOTE the current and voltage numbers. You can see how the zener's current increases (as its resistance decreases) with increased VS1 voltages, "bleeding off" the excess VDC will maintaining (pretty closely) the 5.1 VDC the zener is rated at.
    0
    Semper ubi sub ubi.
  3. #303
    Graham:
    Don't read this unless you want to get confused even more. http://en.wikipedia.org/wiki/Tunnel_diode It's to just remind you that there are lots of diodes out there. There are even varactor diodes such as these: http://en.wikipedia.org/wiki/Varactor_diode. These are diodes in which the capacitance can easily be changed. And the DIAC: http://en.wikipedia.org/wiki/DIAC
    Only casually look this over, but don't even try to understand them at this point.
    0
  4. #304
    Just thought to add this about the zener examples above:
    Most circuits assume a fairly stable power supply. It would be a rare beast that experienced the voltage swings depicted in the examples I gave. As a result, the zener circuit would never be subjected that sort of voltage instability, and would be able to maintain its output very close to the specified level. In this case, 5.1 VDC.
    0
    Semper ubi sub ubi.
  5. #305
    Muttley600 Muttley600 is offline
    Morning CBB
    ok, I have been doing a bit of exploring this morning
    Lets see if my understanding is any better now
    So basically we can use a zener diode to regulate voltage by using & staying within the parameters of it's reverse breakdown min/max, thus giving us a fixed voltage despite changing loads, they can be used as you were saying to operate a transistor to operate a larger current than would be possible still maintaining the required voltage, going even further we can add current limiting into the equation too, meaning that should current be exceeded putting the zenner outside it's parameters, the circuit would simply bypass the zener thus protecting it & shutting down devices, so my understanding now is that zener can be used as a voltage regulator as you explained, but not as a surge/spike protector.
    so this would be a useful addition to my power supply box for my 5V requirement but a TVS diode would still be needed to deal with the spikes.
    How's that?
    0
  6. #306
    Yes.
    Within the confines of the zener's specifications, what you suggest is valid.
    0
    Semper ubi sub ubi.
  7. #307
    Quote Originally Posted by cowboybob View Post
    Yes.
    trying to look at datasheets to get a better understanding it seems 5.1V zeners come at 500mW, which is not enough for 2A is it or have I totally misunderstood, if I'm right it would would have to go through a transistor to provide 2A, if not, I've totally missed what I'm trying to grasp
    Edit: so now I have a datsheet that we can work with to try & understand this better, if I change the diode on the schematic you sent to a IN5231B, I can try & figure out resistors needed for a 2A load & figure out what I'm missing on calculating R1
    so if I work on a 13.7 voltage - 5.1V I need R1 to be equivilent to 70 ohms giving 5.1V across zener, basically after playing I'm talking nuts again aren't I, it can't be done with a 2A load, I would have to reduce R1 to 5.8 to give me load which messes the V up, is this where the transistors come in
    Please forgive me if I'm hard work
    ok, after another look I'm back to your test of IN4733 which looks possible so basically I have learnt a bit more about zener diode but your already 5 million steps in front of me, lesson for today, listen to your tutor
    where were we can we try your test with 13.7V & see where that takes us
    0
  8. #308
    One of the problems with using a zener as a voltage controller is that at the higher current ratings, it takes a greater minimum current through the zener to get it into "steady" or specified VDC output mode. As the load draws additional current away from the zener, the available current for the zener to maintain its "steady state" output voltage is reduced, eventually to the point of no longer working as specified.
    That's why a voltage regulator chip, like what you spec'ed out at the beginning, is a better choice for your needs. It can handle the additional current requirements of the load without losing the ability to maintain the appropriate voltage level(s).
    0
    Semper ubi sub ubi.
  9. #309
    Quote Originally Posted by Muttley600 View Post
    New test:
    8V = 4.52V / 53.61mA
    10V = 4.92V / 78.11mA
    12V = 5.13V / 105.62mA
    18V = 5.46V / 192.98mA
    24V = 5.63 / 282.58mA
    even pushing it to 100V is only 6.42V, that seems sensible & when were talking mA, this is minute really isn't it = 1.44A off 100V
    Which took me to my findings here, although I now understand we have to work within parameters
    0
  10. #310
    ok, being totally nieve has it's advantages here, because I'm guessing I have lots more possibilities until those ideas get shot down in flames
    So I see two possibilities
    I'm thinking along the lines of 2A max current
    greater than what, a chip
    Isn't that why you need a higher working voltage than zener voltage
    failing the zener being the right product, is it possible to make one, it would be a lot more fun afterall, they are about £4, I reckon we could make a schematic, buy parts & build one for about £150 including time edit: ok, I accept at the speed I learn it might be £1500.00
    0
Machined pin sockets and socket strips Screech General Electronics Chat 3 2nd August 2005, 11:19 AM
PIC sockets YAN-1 Microcontrollers 2 27th June 2005, 02:52 PM
Where can i buy these sockets. 2camjohn General Electronics Chat 6 3rd June 2004, 06:23 PM
IC Sockets...why? Easy question... Electric Rain General Electronics Chat 9 10th January 2004, 09:59 PM
Types of sockets Snowman Electronic Projects Design/Ideas/Reviews 2 10th December 2003, 04:03 PM
Page Time: 0.05519 seconds      Memory: 7,382 KB      Queries: 18      Templates: 0
