1. Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
    Dismiss Notice
jrz126
High Power H-Bridge
I just built a high power H-Bridge for my inverted pendulum project and I thought I would share it.
  1. jrz126
    I was running it at 45VDC into a 12 ohm, 200W resistor with no problems (thats over 150W). I was alittle over ambitious with this H-Bridge, it turns out my servo motor for the pendulum draws <50W when running. The motor itself is capable of 200W.
    There's a few things that need to be noted:
    1. High voltage is lethal. attempt at your own risk.
    2. This circuit generates alot of electrical noise. Opto-isolation of all logic inputs is definitly recommended. Add additional stiffening/bypass capacitors across all voltage supplies.
    I'm thinking about making up a PCB for this circuit over winter break. I'll be sure to post it if I do.
