I think there headed in the right way I been playing with this Ideal to. I was thinking of battery powered DC motors ![]() Hydrogen powered generator I would like to see your ideals | |
What would be your source of hydrogen?
Typically it's natural gas or propane that is run through a converter in real time. I've seen some put an actual hydrogen tank on them. This company has been one of the leaders in hydrogen fuel cells for well over a decade now. Just been having trouble getting people to adopt them, and trying to fight all the frivolous lawsuits being brought against them by oil companies. Hydrogen Fuel Cell Technology, Hydrogen Power in Buses | Ballard Power Another huge use of these is in Japan. They are small, and produce enough heat for electricity for a small apartment/house. Put a natural gas converter in front of it and you have a constant flow of hydrogen with very little waste. | |
| | #5 | |
As for Japan... No... just not at all... or come here to show me. I'd be happy to be shown wrong. I know, saying "in japan they..." is the usual thread winner with the undefeated barrier language making any kind of verification impossible. Japan is excessively loud mouthed aboot environnement. But do really little. They are at least 30 to 40 years behind for energy management in the house. (isolation is still unknown science). And everytime they start doing something in the good direction -with the 40 years lag i mean- they brag aboot being on top and how everybody should copy them. They are awefull in the research dept. They are good for copy and production optimisation. Then hopefully we have the chinese to bring the cost down. | ||
| | #6 |
Simple google search got too many hits to post. Here's one stating Ballard was pulling out of the Japanese co-generation market. 2009-06-03 Fortnightly Newsletter - Fuel Cell Today If you were to read all of the press releases from Ballard in the 90s, there were plenty about patent lawsuits being brought up by the oil companies. I don't make shit up, although I am wrong at times. This is not one of those times. To state something is a certain way without knowing is ignorance. To state something is a certain way by proving it is diligence. Last edited by smanches; 11th September 2009 at 06:27 PM. | |
| | #7 |
When the fuel cell vehicles can pull a 12000# trailer at interstate speeds for 300 - 400 miles between fills and be filled in 10 minutes or lees at a common station then I will be interested in the technology. Until then runty clown cars that have the same or less lifetime costs per mile equivalents to a properly designed and built standard vehicle that costs half as much doesn't appeal to me one bit. ![]() When the size and power is there and the cost outlay for a life expectancy of 15 -20 years while traveling some 200 - 250 thousand miles works out to be cheaper than a standard vehicle of equal comparison thats when I will take far more serious interests! ![]() Sorry but they just dont fit my life at this point. I am sticking with my 4+ ton propane burner for now.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
| | #8 |
What ever happened to propane cars? A fair amount of (stinky exhaust) taxis had them here in Toronto several years ago. All gone now. | |
| | #9 | |
Just did a quick google - it's called LPG (Liquefied Petroleum Gas) - and there are still a number of vehicles available either built with it, and conversions available. I just ran my car through this site The Greenfuel Company - About LPG - LPG - The Established Alternative Fuel and it claims it would save me £478 per year on fuel costs. | ||
| | #10 |
Problem with LPG is what happens when you run out of gas? Can't use a Jerrycan as it's non pressurized. | |
| | #11 | |
Diesel-electric pulls hundred's of tons Power is not the thing to worry about. What I been looking for is how much power a hydrogen fueled generator can put out. I found this not really any thing I didn't no I'll quote it any ways Quote:
Tmc I don't need to pull 6 tons 300miles would be nice most of my work is done with my brain so all my car needs to haul is 300 pounds of me and 1ton of car lol | ||
| | #12 | |
![]() How often do you run out of fuel any way. The last time I did was many years ago when a fuel line split and dumped the last off my fuel on the way to town. ![]() Modern dual fuel systems typically have the propane tank gauge wired into the dash so when you switch from one fuel to the other the gauge reads the right tank. And a 20# propane cylinder and a hose with the right fittings make a nice 5 gallon propane Jerry can! Also propane does not just run out like gasoline does. When the liquid is used up you still have the tank full of pressurized vapor. When you do run out of liquid the engine will loose power at first and simply bog when the peddle is stepped on. You will just keep loosing power as the vapor pressure drops. When the first bog occurs and with a conservative driving approach I can get 15+ miles more out of my vapor alone. Or I just flip the switch and run on gasoline then. ![]() The propane exhaust smell comes from poorly tuned or weak engines with low compression. The early emissions compliant engines from the late 70's to the late 80's had low compression and mild cam profiles that contributed to incomplete combustion of the propane and thats why they had the strong smell. Any modern engine that is properly tuned and set up propane or dual fuel vehicle has no different exhaust smell than gasoline and even less than typical diesels if everything is working properly. ![]() Non of the three pickups I have ran on propane had any exhaust smell once tuned properly.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | ||
| | #13 |
I thought the bad exhaust smell was from the smelly stuff (forget what it is) they put in propane so you can smell it? Forklifts were the only things I've driven which ran on propane. I doubt I could get to town and back with one of those. :P | |
| | #14 |
The smelly stuff is Ethyl Mircaptane. It takes higher combustion pressures to properly burn it to the point it looses its smell in an engine application. Pure propane has no smell same as pure hydrogen and pure natural gas.
| | #15 |
No that not what makes a stink it's ethyl mercaptan leave the E off
| car, fuelcel, looked |
| Car Fuel and Temp Meter | VictorPS | General Electronics Chat | 6 | 26th March 2008 12:01 PM |
| fuel batteries | Thunderchild | Alternative Energy | 66 | 27th April 2007 05:05 PM |
| automotive fuel sender unit / fuel gauge | drage | General Electronics Chat | 6 | 20th October 2006 07:37 PM |
| Card Edge Connector; please help! (I've looked everywhere!) | Electric Rain | Datasheet/Parts Requests | 1 | 14th April 2006 02:13 PM |
| RC car fuel sensor (fm or am transmitter/reciever | nitrofan | Electronic Projects Design/Ideas/Reviews | 7 | 24th November 2005 07:29 AM |
