hello all, I would appreciate any help/schematics for a simple circuit I would like to make - my aim is to have a red LED constantly flash by using a solar panel and rechargable battery. I need the solar panel to charge/keep the battery topped up so I dont have to tend to it/keep it charged via a normal battery charger. I have a small solar panel (one from a LED garden light), a 9v flashing led (one with the resistor built in), and a 280mah pp3 rechargable battery. Any help would be much appreciated as I have connected the panel & led straight to the battery and it doesnt work. Thanks, Lionalcook. | |
| | #2 | |
Is the battery fully charged? Does the solar panel have a voltage at its connections when measured with a dvm...? What level is it? You will need more than 9.0v to maintain the charge in the battery... To charge the battery, you will need a constant current charger with a charge current set to 1/10 of the Ah rating of the battery...28mA in this case...You can do this simply with an led, a transistor and a couple of resistors.... Come back when you have answers for the above....
__________________ Eccentric millionaire financed by 'er indoors | ||
hello, yes the LED does flash when connected to the battery. yes the battery is charged. I dont know the voltage of the panel - i will know in a couple of hours as im waiting for my friend to get home from work so that i can borrow his multimeter - i will let you know then, but in the meantime it is the small type that charges a AA 1.2v 600mah battery, from a solar garden light (dusk to dawn type)Thanks for your help | |
| | #4 | |
ok thanks, have you got a diagram for this please? thanks, Lional. | |
| | #6 |
See the attached sketch.... Assume the output voltage from each cell is 3volts...4 in series will give approx 12volts... To charge a PP3 battery you will need around 13v...So adjust the number of cells accordingly...If the cell output is more than 3v then reduce the number in series, if the output is less then add more... The solar cells need to feed the current regulator that is charging the battery and needs an isolating diode to prevent the bettery back feeding into the cells....
| | #7 |
excellent - thanks mate! ![]() I have just found a 6v 280mah ni-cd battery that i could use instead of the pp3- would i be able to use just the one solar panel for it or would i need 2? or is there a lower voltage flashing led i could use? the ones i have got only work from about 6volts and upwards. also could you please tell me what the bd140 and 1n4148 components are in ur schematic please, i assume the other 2 components are resistors? thanks - im still a newbie LOL. thanks again. Last edited by lionalcook; 24th June 2009 at 02:24 PM. | |
| | #8 | ||
Whatever voltage Nicd you use, the supply for a charger needs to be at least 3-4 volts higher... But you said your led is 9v..Now you want to use a 6v battery?.. It may flash, mebbe slower and not as bright..
__________________ Eccentric millionaire financed by 'er indoors | |||
| | #9 |
when i bought the flashing led's they were advertised as 9v - so i assumed they would only work with 9v but i've just been testing it and using various batterys with the flashing led and these are my results = 1.5v - no flash 3v - flash - not as bright 6v - flash 9v - flash | |
| | #10 |
No problem then....You could use the 6v nicd and use less solar cells for charging..
| | #11 |
thanks mate, could you please tell me what the bd140 and 1n4148 components are in ur schematic please, i assume the other 2 components are resistors? thanks | |
| | #12 |
BD140 is a PNP power transistor and the 1N4148 is a general purpose silicon diode....
| | #13 |
If it comes to it, there are lower voltage flashing LEDs available. You might try allelectronics.com or bgmicro.com (I forget which I got mine from) ... good luck!
__________________ Michael Shimniok http://bot-thoughts.blogspot.com/ Microcontrollers can solve world hunger, too! | |
| | #14 |
maybe im thinking too simplistic. get ahold of rechargeable garden light, replace the led with one with a built-in flasher, and off you go
| | #15 |
I made a solar flasher recently, using a super capacitor: ZZTools: Simple, Battery-Free, LED Flasher This keeps flashing for many hours after charging in the sun. Certainly enough to keep going over night. Super capacitors cannot store as much energy as a rechargeable battery (currently) but they last much, much longer. | |
| battery, flashing, led, rechargable, schematic, solar |
| [Help] MPPT Solar Controller schematic | Elecholic | Datasheet/Parts Requests | 12 | 26th April 2009 01:07 PM |
| Battery and Solar Stuff | Dancin David | Electronic Projects Design/Ideas/Reviews | 39 | 3rd August 2008 11:21 AM |
| Discharging Mathematical Function of Rechargable Battery | odense | Robotics Chat | 4 | 19th April 2006 07:33 PM |
| Solar Battery Charger | Space Man | General Electronics Chat | 2 | 20th May 2004 01:15 PM |
| solar battery charger | induction1 | General Electronics Chat | 4 | 22nd May 2003 07:58 PM |
