| | #46 |
| If you believe that then feel free, but neither Stanley Meyer (who was a convicted fraudster) or anyone else has ever managed to make his ludicrous schemes work.
| | #47 |
This is the all thing in one diagram. It have a range of 10 to 12khz. Actually the 4046 makes 10 to 100hz signal that is multiplied by the counter i guess not sure. If you know how to come out with some values for resistors and capacitors and opamps is finished. I have to create a ramp or triangle signal that goes from vss to vcc to search the resonant frequency. We need to discover the values of R3, Cf and R4 for the filter section. Its using the 2° Phase comparator. I think maybe the diodes on the feed back could be zeners but i'm not sure. Its possible to use a feed back like this to create 50% square waves? Or was that workings as a sine wave feed back? | |
| | #48 |
| If they were zeners presumably they would be drawn as such?, but if you mean the two back to back diodes, you couldn't do that with zeners anyway (well you could, but there would be no point whatsoever).
| | #49 |
i meant that back to back, you are right there is no point also on the schematics is not indicated as zener i was just guessing what effect it would have. I was thinking about trying a Tl074 because a friend suggested me to use current feedback on the contrary to use voltage feed back and gave me this link a-c current transformer functional ... - Google Patents that show some schematics with it. I'm going to try a shoot in the dark and construct some circuits with the solder less board. I don't know how to calculate the R3 and R4 values, R4 means that there is an off set. R3 should be greater than 500 i think. but i don't know much how it affects the lock range i just don't understand it very well i didn't found much information about it. I found a program by philips that calculate the all pll values i tried out a few but there were some questions i didn't know how to answer and i don't have windows computer here. This is the link for the program EDA Software Center Elektroda.pl information about Phaselock techniques http://lib.semi.ac.cn:8080/tsh/fwzn/...2/contents.pdf Wont this schematic seem with the feed back? Last edited by sebosfato; 23rd May 2009 at 01:38 PM. | |
| | #50 |
Hello I made a test with 555 timer and 7490 counters divided by ten and it real divide the f by 10. but i read about if you put it between the 4 and 3 pin on 4046 it multiply the f is that correct? Just found a great pll datasheet with calculations for the R3 and R4 http://www.physics.wisc.edu/grads/co...f07/ds/PLL.pdf + http://pdfdata.datasheetsite.com/web/82027/AR254.pdf Hi cardac my name is fabio and my email is bringpowertothepeople@gmail.com Last edited by sebosfato; 24th May 2009 at 08:34 AM. | |
| | #51 |
Oh boy i'm studying about this now is a long time and look what i found- The same schematics i'm working on The Water Fuel Cell :: View topic - Phase lock loop circuit schematic I found also this one Stomping in Clown Shoes » WFC PLL - the Oscillation Overthruster Anyway i'm going to finish my design and make improvements. | |
| | #52 | |
Go for it Buckaroo you have an equal chance of traveling through the 8th dimension too. Quote:
| | #53 |
There are many factors that could influence the non functionality he is using 1 phase comparator and not 2 as i'm planning to use is a similar circuit not exactly what it really is any way i'm going to work on it and get the best ideas from it and put it to work i'm sure of that.
| | #54 |
The main factor being the design has no scientific reason to function even if every part of the circuit does exactly what you want.
| | #55 |
Science is science. Electronics is electronics. And what i want is what i want. There is no reason this circuit could not work, it have being designed to work as described, and circuits of any kind are made to let us to do what we need to do to achieve a certain behavior or result. This circuit is not over unity is just simple pll with some control parameters. As soon as it is ready i'll post it here with the right values for all components for it to work as desired.
| | #56 |
My mistake. It's another useless water resonator. Can you tell me what frequency water resonates at? | |
| | #57 |
![]() it will resonate in my case at about 5khz, there will be like 20% variance in the Resonant frequency of the circuit because bubbles and temperature and other factors, type of water ... Meyer said that water 2pp should have something like 10% thats why i decided to built this circuit to track and lock to it automatically. Is almost ready now because i worked since yesterday non stop... on this weekend will probably be ready i hope. Than the next step will be to test my theories to see if its right. or wrong. This circuit will able me to do things i couldn't do with any other circuit and so i think is probably what was missing to me than the rest is all about transformer design ... | |
| | #58 |
Har. Good luck. Bye bye now.
| | #59 |
5khz? The frequencies not high enough to do anything. Even basic over the counter jewlery cleaning machines use 15khz or higher, what're you gonna do with 5khz? I could beat that with an audio power amplifier and a sound generator.
| | #60 |
My next car should work when I hum at 5kHz
| 4046, feedback, pll, resonance, winding |
| 4046 trouble | confounded | General Electronics Chat | 5 | 16th April 2009 09:06 PM |
| Resonance or... | Electronman | General Electronics Chat | 15 | 28th December 2008 08:35 AM |
| PLL question, will a 4046 clocked at 512Hz be able to reliably generate 131,072Hz ? | blueroomelectronics | Electronic Projects Design/Ideas/Reviews | 37 | 25th November 2008 09:30 PM |
| Resonance-help me!! | niga | General Electronics Chat | 11 | 2nd June 2005 02:59 AM |
| VCO 4046 | redhat | General Electronics Chat | 1 | 8th February 2005 12:19 PM |
