Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Renewable Energy > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 26th May 2009, 03:38 PM   #16
Well this design is set up specifically so that if the line voltage is not there it cannot run.
If you wanted to make a regular inverter and not at grid tie the circuit is considerably different.
Look around on this forum for things like push pull oscillator. I have posted some schematic for very basic ones in several threads.
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is online now
Old 7th June 2009, 01:45 AM   #17
Default grid-tie connection
I am new to Electro-Tech. Just got my NABCEP badge. How do you do your connection? There are specs on how long the grid goes down until you must anti-island. Xantrex used to make a block (for $450) that did this. I have 24/7access to dip solder pot about 8x10", washing machine, and lead cutting machine. Use mild acid solution flux. Orcad or Protel layouts. Could check or help layouts and if sent kits do the boards.
Alan Dedier is offline
Old 18th August 2009, 04:01 AM   #18
Looks like it's been awhile since anyone posted on this. Any improvements/progress since the last post?
ignisuti is offline
Old 18th August 2009, 04:35 AM   #19
Summer time for me. No time to play.
I work longer hours in the summer so I dont have to when its winter.
I did make a better working version of it a while back though. I just haven't got around to doing a proper schematic for it. I will need to take it apart now to remember what went where and to get the right components values.
And it does fit inside a standard computer power supply case too!
grid, inverter, tie, tiny, unit
Grid Tie Inverter Schematic Burnt Alternative Energy 225 10th November 2009 02:23 PM
250 watt grid tie inverter build Robby Alternative Energy 113 13th August 2009 07:19 PM
Cheap Grid Tie Inverter Manufacturer zicmama Alternative Energy 4 2nd May 2009 08:09 PM
LED Grid Display project Peepsalot Micro Controllers 21 25th March 2006 08:12 PM
Power Distribution Unit 0 Unit? shermaine General Electronics Chat 4 15th June 2005 07:59 AM
