| | #16 |
Yes in the UK it must be approved i.e. G83 certified. I have checked with my supplier Atlantic Electric (Scottish div) and they will supply and fit an export meter free of charge as long as the GTI is G83approved. | |
| | #17 | |
building from a validated design/kit will not neccesarily make the home made one validated as the operator will not be deemed to be reliable, in a company making them there is more control over build quality as stuff is checked regularly by QC which maintain the standards set by the original validation on the design
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! Last edited by Thunderchild; 30th March 2009 at 12:58 PM. | ||
| | #18 |
I think the phrase: "what they don't know won't hurt them" comes to mind. Besides I don't think that *everyone* will try making one, there are fuses in the house, power line etc. and these systems will produce small amounts of energy in comparison with power stations. So individuals cannot affect the grid very much.
| | #19 |
I still think this discussion will be relevant - I am looking to use a 250W GTI for my PV array and because the output is so low I will not export it back only use it locally. I would say that as long as you are not exporting back then the G83 spec would not come in to it - thats my interpretation - thoughts anybody. | |
| | #20 |
Exactly - how would the power company know that you were generating electricity if your meter never ran backwards (newer meters cannot run backwards). All the power company would see is a decreased consumption of electricity, although if you generated 100% of your usage, they may send an engineer to check your not cheating.
| | #21 |
| I would imagine it would be very many times the cost, UK approval for anything is an EXTREMELY expensive process.
| | #22 |
All valid points, but again how many things can you find on the internet that you are not suposed to have yet can build yourself? How many things are on THIS WEBSITE that could kill the user or someone else if not properly built or used? ALSO there are many companies building and selling plug and play units already. YOU do not need a permit from the power company to use one of them! If your worried about saftey DONT BUILD ONE! If you do build one or buy one the power company will not know you have one unless you tell them! If you start producing enough power to make your monthly electric bill go negative then yes they will probibly want to know why. Otherwise how do they know what you are doing? If you go on an extended vaction and shut the power off to your place they dont come an investigate you because your electric bill is zero KWH that month. If your electric bill drops a fare amount, as far as they know you just got more efficient in how you use electricity! I know a few people that did a very critical look at their power usage and were able to cut their electric bill by almost half in one months time just by being more diligent and efficient in what they were using. The power company did not send engineers out to see why. IN my country Grid tieing is legal. As long as you have the right saftey precautions dont worry so much. If your that worried DONT build one!
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
| | #23 |
I agree I have no problem in using one to reduce my usage and would only consider the approved unit if I felt that I had alot of spare power to export for credit to the grid. Depending on the spare capacity and the payback from the supplier would determine if it was worth while investing in a G83 unit. | |
| | #24 | ||
| | #25 |
| This GTI build up Thread is intended for residants of the united states only! Should you decide to build and use such a device as this you may be breaking laws and can face possible fines, and or jail and prison time for it. Should you chose to build such a device as this and intend to use it for saving energy in your home or dwelling you are still breaking the law. Beware you are considerd a pirate Grid tie operation, which is considered illegal in many countries! ![]() ---------------------------------------------------------------------------------------------------------------------------------------------------- THE CONTROL SYSTEM. How simple or elaborate you get here depends entirely upon you. I do strongly recommend at least a basic control system that has both input and output voltage monitoring. Ideally you will want the whole GTI to be off until a minimum input voltage level is reached. There is a input voltage point that will be the sweet spot were the GTI goes from power use to a power return. Every unit will have its own break even level due to the variations in components and the overall efficiency of the design. That’s why the adjustable control setup is recommended. What I use is a multi level control. As the input voltage rises the control system comes on and starts running the main power transformer. As it gets higher it will reach the break even point and only then will it connect to the grid. The grid voltage and frequency are also monitored. It the correct line voltage is not available or if the line frequency is not right it won’t connect. This may sound complicated but it really is not. There are only two main types of comparator circuits needed and one frequency to voltage converter which is optional. SINGLE STAGE VOLTAGE COMPARITOR. This one is a basic voltage comparator. It just sends an on/off signal based on the voltage set point. If the input voltage is below the set point its output is off. If its input voltage is above the set point the output is on. This circuit is used for the stage change functions and for the basic line voltage and part of the frequency monitoring circuit. I have chosen the LM324 quad op amp for its simplicity and easiness to find. (See Spec sheet below) (Any other voltage comparator can be substituted if you wish. Just makes sure it has suitable voltage and output current capacity ratings.) TWO STAGE WINDOW COMPARITOR. The second comparator is a window or dead band type. It has to go above a high level set point before its output will change from off to on. But it then can drop below that level without turning the output off. It uses a second lower level comparator that controls the second set point to reset the output to off. Once it has turned the output off it can not turn on until it passes the high level set point again. This dead band allows for monitoring voltages that tend to fluctuate during operation. Being able to set independent high and low points will keep it from oscillating during load changes or power fluctuations. FREQUENCY TO VOLTAGE CONVERTER. This circuit is used only on the line side of the GTI. Its only function is to watch the AC line frequency to make sure it’s in the right range. Typically using a plus or minus 10% limit is acceptable. The circuit is based on an LM2907 frequency to voltage converter IC. (See Spec sheet below) (Any other frequency to voltage circuit or IC will also work here: just make sure it has the correct voltage and output characteristics to make it compatible with the rest of the circuit) OUTPUT STATE CHANGE DELAY TIMER. These are just for added precaution. They go on the output of each monitoring comparator. They are purely a second back up to further prevent unnecessary on/off cycling do to input power dips or spikes and line side dips and spikes. This is purely and optional function. This is a simple 555 based timer circuit. It has an adjustable time delay of .5 to 5 seconds. (See Spec sheet below) (Any other type of time delay circuit or IC will work here also; just make sure it has the proper voltage and output current capacity) If its input state changes from off to on, its output state won’t change unless the input has stayed on until the time delay has been reached. Only then will its actual output turn on. Then it does the reverse of that after the input signal turns off. The input state must stay off for the time it has been set to or it won’t reset the output to off. This is purely a glitch filter to keep the control system from false triggering and turning the GTI on or off or changing stages when it was not actually necessary. Again it’s purely optional, but still recommended. CIRCUIT LAYOUT. Each of these circuits can be made individually or preferably on a one circuit board. By combining several comparator circuits on one board you can use single IC’s like the LM324 to do multiple comparator functions. Also if you are going to be using several output glitch filter timers you may want to integrate them into LM556 dual timers or other multi timer ICs as well Basic circuit diagrams and IC spec sheets are below.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech Last edited by tcmtech; 6th April 2009 at 05:02 AM. | |
| | #26 |
Well when you guys get tired of being kicked around by the corporate utilitys come on over! ![]() We dont have the same rules you do I know that. Over here anything from the customers side of the meter box is ours. And what we do with it or to it is our business. We do have to use safe practices to ensure what we do does not cause harm to anyone or anything up line from us. But here we are alowed to backfeed up to 50kw an hour legally. Sorry your utility law system does not work that way. ![]() I guess I will have to add this disclamer: ![]() This GTI build up Thread is intended for residants of the united states only! Should you decide to build and use such a device as this you may be breaking laws and can face possible fines, and or jail and prison time for it. Should you chose to build such a device as this and intend to use it for saving energy in your home or dwelling you are still breaking the law. Beware you are considerd a pirate Grid tie operation, which is considered illegal in many countries!
| | #27 |
well its pretty plain on here who is dreaming and who knows the practicalities of things, the situation we are talking about requires much more than theoretical considerations. this thread reminds me of a joke I was told the other night: whats the difference between the maths of a physicist, a mathematician and an engineer ? To a mathematician 1+1 = 2 To a pysicist 1+1 = something between 1.5 ad 2.5 To an engineer 1+1 = erm.... about 9
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| | #28 |
All I can say is check out as many web sites as you can related to companies that sell Grid tie inverter sytems in the United states and read them carefully. Please find me some honest liturature about hook up rules and post it. Check out eBay and see if you can find one Seller that says you need permission to hook up there product in the United states. ![]() I may very well may be wrong on some things but until it is honestly proven that I am wrong I have no other alternative but to believe what I have read and understand is right. ![]() If you need further information check out the National Electrical Code rules Related to; ![]() Interconnected Electric Power Production sources. ARTICAL 705 THIS IS WHAT I HAVE TO COMPLY WITH IN THE UNITED STATES! and I do! ![]() Everywhere else in the world has to follow the code rules and laws that relate to their own country.
| | #29 | |
![]() My last time around at college for my electrical engineering degree showed me otherwise! The math classes I had to take tried to tell me 1+1 = 9 ![]() Calculus was the dumbest thing I have ever seen that was even remotely related to mathematics. ![]() My Calculus instructor spent a week on how claculus based formulas can change any number to be equal to any other number. ![]() One day in the middle of class I asked him; Can you use this in real life situations? He said; Definitly! I then asked; Are you doing anything after class? He said; No, Why? I said; Then will you come with me and prove that what your are saying is true and can be used in real life? He said confidently; Sure! Where would you like me to prove it? ![]() I said with a big grin; Lets go to my bank and you can prove that your equations are real and do work in real life situations by making the $40 in my checking acount equal to $40 million. AND I will give you $38 million of it in cash if you do it! ![]() The whole class cracked up! He then said; Thats not how it works. These formulas are only good for when you have mathematical problem and the answer you keep getting does not match what you need to make the equation work. I said; But how I want to live does not add up with what my checking account says. The number I need in my finacial formula does not match what I have in my checking account. ![]() The class though my argument was good. It did meet all the requirements of what he was saying, and it did fit in the formula on the board perfectly! But after much debate I still only had $40 in the checking acount the next day.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | ||
| | #30 |
| quite and in the UK there ARE rules about this.
| 250, build, grid, inverter, tie, watt |
| Grid Tie Inverter Schematic | Burnt | Alternative Energy | 225 | 10th November 2009 02:23 PM |
| inverter anyone know how to build one | bubbat | Electronic Projects Design/Ideas/Reviews | 27 | 29th December 2008 03:18 PM |
| need to build an inverter | mexzy | Electronic Projects Design/Ideas/Reviews | 3 | 29th December 2008 01:39 PM |
| Prue Sine wave 3000 watt RMS inverter | pwd666 | Electronic Projects Design/Ideas/Reviews | 5 | 30th March 2008 04:17 PM |
| Need help to build a 24V DC to 220V AC Inverter | gulzar | General Electronics Chat | 11 | 29th October 2006 08:12 PM |
