Hi guys ![]() I am new here, (Hi!) far from an electronics fundi, and in need of advice! ![]() I would like to a car's electrical system, as input, to get an output of between 1.4 & 2 Volts and around 60 Amps. One option would be to rewind the stator of an alternator and regulat volage via the regulator somehow, but this solution is a little far from plug and play. ![]() I then went in search of buck regulators that might be used for this: How does a buck regulator work? - Ask Charlie - Blog on Control Engineering http://designtools.analog.com/dtPowe...fA%3D%3D%22%7D Linear Technology - LTM4605 - High Efficiency Buck-Boost DC/DC µModule LTM4605 LTM4605EV#PBF LTM4605IV#PBF MIC2159 SYNCHRONOUS-itty Step-Down Converter IC 2 or 3 of these in parallel will work! Micrel's Switching Regulators So far it seems that buck regulators are suited to low amperage output by the very nature of their design. If anyone has any ideas or input, it would be greatly apreciated. | |
It's unlikely that there's a cheap or simple option - switch-mode of some kind is the only way. However, I suspect this is probably for some kind of hydrogen generating scheme, and is completely pointless as they don't work. | |
PS Generating HHO requires 2.5x the power it will produce.
As above. The only time I've ever seen something needing that low a voltage and a reasonable current (still less than 10A though) was on a Lambda Oxygen sensor that required preheating so I assume you're after generating oxygen with that high a current. | |
| | #6 |
He is adding HHO to a gasoline engine to fool the ECM into making the mixture too lean so the engine burns its valves and pistons. Then less gasoline is burned. But the nitrogen pollutant will be way too high.
| | #7 |
Yes; It is for a HHO generator.Which means that it's going to be almost impossible to stick to the subject, get some help, and avoid an arguefight. ![]() "ROUND # 1!" Imagine that you had come up with an idea for using the wasted energy from an inefficient engine to produce hydrogen, rather than the obvious. Imagine that you needed a nutter electrolysis cell to test required ignition and fueling changes as you only had one car and needed it to get to work! ![]() Imagine that you did not have to tell the whole world the above and thus stood a tiny chance of making living out of your idea, with time to come up with other good ideas! Your turn. | |
| | #8 |
Do you want real answers based on real science or wishful thinking? How will an inefficient process improve an inefficient motor? There is a site called overunity.com which has lots of HHO people all beating the same dead horse. Here's proof it doesn't work, well worth a read. Scientific proof debunking the "run your car on water" scams | |
| | #9 | |
If you used an electrothermal generator to generate the electricity to produce HHO then you might actually make a small fuel saving but I doubt it would be worth it.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #10 |
PS is fundi a South African word for "expert in a particular field"
| | #11 |
In the US it means "Bible-thumper". Religious fundamentalism and belief in overunity schemes seem to go hand-in-hand.
| | #12 |
Bible basher is the term we often use for zealots in the UK.
| | #13 |
Remember there are no experts in the overunity field.
| | #14 |
Is a Bible Basher different from a God Botherer?
| | #15 |
They there are, they're expert con-artists, liars and thieves.
| 60a, car, reqd |
| Help!! Rc Helicopter Tx-2b Circuit Reqd. | patkash68 | Electronic Projects Design/Ideas/Reviews | 1 | 18th January 2009 10:44 AM |
| DC motor from 89c51.help reqd | puremobi | Micro Controllers | 11 | 5th December 2008 11:06 AM |
| IC TESTER CIRCUIT REQD. | sukanya | Electronic Projects Design/Ideas/Reviews | 2 | 13th February 2004 02:44 PM |
| REQD DATASHEET tda7377 | palesha | Datasheet/Parts Requests | 1 | 16th December 2003 02:16 AM |
| Site Reqd to D/L ebooks | Shantesh | General Electronics Chat | 0 | 3rd October 2003 05:22 PM |
