Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Renewable Energy > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 1st September 2009, 05:38 PM   #46
Just out of curiosity what supposed law of thermal dynamics is being broken?
And which methods of accounting for the energy exchanges are being used?
And catalysts are known for having interactive properties with chemical reactions yet they dont actually add or consume energy from the system themselves.
I am just curious.
As far as getting the low voltage higher current out of an alternator I already mentioned how to do it earlier in the thread.
Or as mentioned using a switch mode system would work too. Just use a buck converter set up if electrical isolation is not a problem.
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is offline
Old 1st September 2009, 05:46 PM   #47
Nigel He wants 60amps DC you can roll me one of them small transformers that can handle 60 amps. I've not seen any thing small that can put out 60amps. It takes a number 6 wire to handle 60 amps of power
be80be is offline
Old 1st September 2009, 05:54 PM   #48
Try transformers as used in in-car amplifiers - the primary is often far greter than 60A, and the transformer small.
For a hint, you can either use multiple thinner wires, or copper strip rather than wire. You also require only VERY small numbers of turns - for 2V, one turn is probably all that's needed.
Old 1st September 2009, 06:04 PM   #49
I've used multiple thinner wires to keep from burning the transformer up.
I see what your saying
be80be is offline
60a, car, reqd
Help!! Rc Helicopter Tx-2b Circuit Reqd. patkash68 Electronic Projects Design/Ideas/Reviews 1 18th January 2009 10:44 AM
DC motor from 89c51.help reqd puremobi Micro Controllers 11 5th December 2008 11:06 AM
IC TESTER CIRCUIT REQD. sukanya Electronic Projects Design/Ideas/Reviews 2 13th February 2004 02:44 PM
REQD DATASHEET tda7377 palesha Datasheet/Parts Requests 1 16th December 2003 02:16 AM
Site Reqd to D/L ebooks Shantesh General Electronics Chat 0 3rd October 2003 05:22 PM
