Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Renewable Energy > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 17th July 2009, 04:24 AM   #211
Smile Pure Sine Wave Inverter
hello, im a student, i have been looking for a most advance Pure Sine Wave Inverter, from 12Vdc to 240Vac inverter. Please send me a full circuit diagram with it full explanation to my email- jeffrey_5097@yahoo.com or here.
Thanks.........
jeffreywong is offline
Old 19th July 2009, 02:27 PM   #212
Default chokchai
Please scan and post.
thank you
kwdaye is offline
Old 27th July 2009, 11:53 PM   #213
I have read all the pages of this forum as well as the one that started for the 250watt specific unit. I am starting to produce a circuit design similar to the ones described here hoping that the power company will work with me.
I was looking to use a wind design and live in the middle of a city, but the city requirements for a tower is that it has to be less then 100 ft tall (I don't plan on making mine anywhere near that), but I was looking for monitoring software that I could tie some type of tach unit to and stick up at various heights to test which elevation would work best.
Any ideas what and where I could find this, I have been looking around, but haven't found anything that fits the bill.
Saran01 is offline
Old 1st August 2009, 05:19 PM   #214
Hi there,
First thing you should check with your local power company.
You have to at least find out if they allow grid tie inverters in your area.
Second, you have to find out what the required spec's are for something
that is tied to the line like that, such as what is the maximum level of
the harmonic distortion allowed and maybe even how often you can allow
your unit to tie and untie from the line in any given day. There may be
other spec's that they demand so you better check first.
MrAl is offline
Old 3rd August 2009, 06:57 AM   #215
Maybe I missed it, but has anyone here talked about PFC for a Grid Tie Inverter? I'm trying to figure out how it would be done, since you are trying generate a voltage waveform to closely match the grid, how would you regulate the current to track the voltage?
(First time post)
thanks,
Omer
opeleg is offline
Old 3rd August 2009, 01:49 PM   #216
Actually, if you set the voltage to match the line before contact, then switch
to current generator mode, you turn the inverter into a current generator and
then you just regulate the current. The voltage goes to whatever it has to
be to match the line...that's how a current generator works.
MrAl is offline
Old 3rd August 2009, 06:02 PM   #217
It depends on how you build the GTI for the most part. I prefer simple and rugged and use a simple LC tank setup on the line side both for filtering and for power factor correction.
Without knowing what you are working with its impossible to say exactly. Still to correct possible line hash or harmonics issues a filtering system is needed. And if the filter capacitors are of the correct size the power factor will say fairly close to 1.
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is online now
Old 27th August 2009, 02:32 PM   #218
A couple of things to keep in mind.
1) the mains waveform, when loaded, may not be a perfect sine wave - if you use it as a reference, you only make it worse. Best to create your own.
2) reactive loads will cause back-emf - ie, the load will produce a possibly quite high voltage and you need to absorb it somehow.
jonroger is offline
Old 27th August 2009, 08:08 PM   #219
How to filter the inverter output?
I have 250V pk at the MOSFETS.
10 volts pk at the output of the first LC filter.
0.4 volts pk at the output of the second LC filter.
I am 25db over FCC specs.
I can see that a simple LC filter will never work.
Any ideas?
thanks
ronsimpson is offline
Old 6th November 2009, 01:19 PM   #220
Default Question for Val
Hi Val, nice elegant line waveform tracker with digital adjustable attenuator for power point tracking via microcontroller. But how will you mitigate the feedback coupling when HVDC and both "240 VAC" line connections are hooked up together? Won't the circuit behave differently since it will then be sensing its own output?
toptriode is offline
Old 9th November 2009, 11:37 AM   #221
Hi i am from India, I have developed a 2000W permanent magnet alternator which is designed to perform in very low wind speeds and have designs for a 25kw permament magnet alternator model, my idea is to provide a GTI so that the load can be supplied directly from the Permanent Magnet Alternator without storage batteries
coimbatorean is offline
Old 10th November 2009, 01:39 AM   #222
That sounds good, in principle anyway. What's going to power your load when the wind stops? Or when the wind is going up and down every coupld of minutes?
Mr RB is offline
Old 10th November 2009, 01:48 AM   #223
coimbatorean: you are just a dreamer. You have developed the generator in your MIND.
Stop wasting our time with your DREAMS.
colin55 is offline
Old 10th November 2009, 03:59 AM   #224
I wouldn't go that far as to dismiss it so entirely.
His concept is feasible but would prove it self most likely impractical and at times very limited as to what it could actually power by itself.
Being that he mentions grid tyeing it he wouldn't need a battery because the grid will work as the battery. That would allow the varying output of the generator to work while still keeping that loads supplied with a reasonably stable power source.
Old 10th November 2009, 01:18 PM   #225
I agree. He also said it was suitable for very low wind speeds. A generator with a very low cut-in speed might be able to provide many hours of continuous power, although that would requires a much larger windmill so it may not be as cost effective as a setup optimised for higher wind speeds.
Mr RB is offline
grid, inverter, schematic, tie
PSPICE schematic (full-bridge inverter) MsStateDawg Electronic Projects Design/Ideas/Reviews 5 20th July 2009 01:20 AM
Laser Security Grid russianbadboylb Electronic Projects Design/Ideas/Reviews 5 28th April 2008 08:05 PM
Running My Room Off-The-Grid ParkingLotLust Alternative Energy 29 1st July 2007 09:37 PM
LED Grid Display project Peepsalot Micro Controllers 21 25th March 2006 08:12 PM
Does any have a Schematic diagram for an AC/DC inverter? guillermo Electronic Projects Design/Ideas/Reviews 7 7th April 2005 08:35 PM
