Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 28th September 2008, 05:08 PM   (permalink)
Default Measure Daily Output of a Solar Panel
Hello,
I am trying to measure and compare the total daily output of two identical solar panels: one is stationary and the other tracks the sun. I know how to measure the voltage acorss a load and determine the power but what is the best way to measure the total power produced, from sunrise till sunset, on these panels?
Thanks.
Moneer81 is offline
Old 28th September 2008, 11:22 PM   (permalink)
Originally Posted by Moneer81 View Post
. . .total power. . .
Total energy. . .?
Assuming a resistive load:
.....you could make an amp-hour meter from an IC Voltage-Frequency Convertor
http://www.national.com/mpf/LM/LM331.html
and a shunt resistor. The Freq. increments a counter. Total count + total time = total amp-hours.
.....You also need a voltmeter that displays average voltage. Use another V-F convertor and counter and divide the voltage count by the hours.
.....Then you have average V and total amp-hours, and so total watt-hours.
Willbe is offline
Old 30th September 2008, 08:07 AM   (permalink)
Hello,
Thanks.
Are you planning to record every day or just a day or so.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 7th October 2008, 07:53 PM   (permalink)
Sorry for the late reply. I am just planning to record a day or so. Any suggestions?
Willbe - thanks for your suggestion. Is that the only method to do so?
Thanks.
Moneer81 is offline
Old 7th October 2008, 10:08 PM   (permalink)
Do you have an 'identical' charger and storage battery for each solar panel? Just charge both batteries and then discharge each one under identical conditions (Same inverter powering the same load. Inverter should have a low-battery cutoff. Measure time to cutoff for each battery. Swap batteries and repeat the next day.)
mneary is online now
Old 7th October 2008, 11:09 PM   (permalink)
Well if you are only going to compare a couple of days differences you might consider the following lower cost but more math solution.
If you wire both panels to identical load resistors and place each resistor in identical size oil baths you could trend the temperature rise of both baths over time. After you acquire the raw data you can use excel to calculate the power generated by each panel over time. I'm sure a little searching could find the proper temp/BTU/Calories/watts relationship. Again this would require more math but the hardware cost should be lower.
Lefty
Measurement changes behavior
Leftyretro is online now
Old 8th October 2008, 02:45 AM   (permalink)
I guess you could add charge in chunks to two capacitors using sampling and the final "volt-hours" and amp-hours would correspond to the capacitor voltages. Then you multiply once.
Exactly how to do this with rising and falling voltages doesn't exactly jump out at me. One of these, maybe. . .?
http://en.wikipedia.org/wiki/Charge_pump
but I've never designed one.
Or
a voltage controlled current source (an FET or vacuum tube) feeding the cap, with ΔV across the cap = IΔT/C. 1v cell voltage means 1 mA into the cap, 10v means 10 mA, and for a 1000 ”F cap you apply the 1 mA current for 10 mS and you get 10 mV.
Adjust the current and its duration to avoid voltages higher than the cap's rating by the end of the day.
You'll need low-leakage caps.
Willbe is offline
Old 8th October 2008, 04:28 AM   (permalink)
for watts:
put some resistance on the output of each panel, and measure the voltage across the resistor.
P = VČ/R
power = voltageČ/resistance
leedude is offline
Old 8th October 2008, 09:31 AM   (permalink)
Thanks.
As its only a few days I would suggest the following.
Interface a MCP3204 , 4 channel 12bit ADC to the parallel port of a PC.
Use two of the channels to monitor panel voltage and the other two channels for current.
This would give W1 = V1*I1 and W2 = V2*I2 which could be plotted on the PC.
If you decide on this method I could help out with the PC interface details and a simple log program.
Eric
PIC tutorials:
Old 9th October 2008, 12:17 AM   (permalink)
Originally Posted by leedude View Post
for watts:
P = VČ/R
I am aware of that. The question is how do you keep track of the power through out the day, and how do you record it and add it up?
Moneer81 is offline
Old 9th October 2008, 08:08 AM   (permalink)
Was my suggestion of any use.?
Eric
PIC tutorials:
Old 2nd December 2008, 05:26 PM   (permalink)
Default Logging solar irradiance data
Hello,
Another approach would be to log the solar irradiance from sensors placed next to each panel. Assuming the panels are identical, this would tell you how much energy you are getting for each configuration. The comparison will vary depending on the cloud conditions and angle of the sun and panels. A clear day would be a good starting point for comparison.
You can check out the following link for a "solar data logger" kit that logs solar irradiance and cummulative incident energy.
Micro Circuit Labs SDL-1
The kit manual describes how to compute cumulative solar energy in kWh from logged irradiance data as well as some other background on solar power.
Hope that helps.
Jeff Fedison
Micro Circuit Labs
jfedison is offline
solar panel DC current ravaka General Electronics Chat 34 15th October 2008 05:51 AM
BP270 solar panel vinke Alternative Energy 3 12th March 2008 01:27 AM
Solar panel LED - How does this work? johankj Electronic Projects Design/Ideas/Reviews 8 8th October 2007 01:32 PM
Solar Panel km General Electronics Chat 2 28th January 2005 01:02 PM
Solar Panel km Electronic Projects Design/Ideas/Reviews 0 25th January 2005 03:52 PM
