| how would I determine the power output of an unknown solar panel ? if i just measure the voltage its going to be higher than normal but when measuring current the voltage will drop to nout ! so what do I do ? one clue may be that I can count the number of "junctions" in the panel or cells
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | |
If its a 12V panel, do you have a 120R 2Watt resistor [ thats 100mA] or a 12V cycle lamp, say 3Watt, thats about 250mA. Problem today is the lack of Sun.
| yes on this particular day sun is hard to come by well i have many resistors I'm assuming I'm dealing with 6 V panels
It should be easy to see if its a 6V or 12V nominal panel. Choose a resistor that will pass about 100mA for starters and measure the output voltage at the same time.
| ok I'll do that I have 2 panels with 15 strips/junctions rated at 7 volts and these have 10 junctions so i presume I'm looking at about 5 volts and I think the output is approximately 100 mA I'll give them all a go when the sun comes out
| Corrected.
Do you remember the robot school olympics programme that used to be on TV?, and how massive the lights were for the solar car event. | ||
I was suggesting a way on how to determine if they are 6V or 12V panels, the OP isnt sure. Of course I agree, ref the high intensity of artificial light versus current output.
| well eric its more of a case that they are "custom" panels they come from equipment like i said one is probably 6 volts but the other compared to that must be 5 ! :-(
| corrected again we are having some sun here (just a bit don't blink or you will miss it)
| ". . . determine the power output. . ." You measure the open circuit panel voltage and call it Voc. You put a load resistor, Rload, onto the panel with a resistance low enough to drop the voltage 10% to 50%, and you measure the voltage, Vload, across the resistor. Then, Iload = Vload/Rload. Then, the internal cell resistance, Rint, = (Voc-Vload)/Iload. Then, the maximum power obtainable from the cell is achieved when it is loaded down by a load resistor of value equal to Rint. (Voc and Rint equals the Thevenin equivalent voltage & Thevenin equivalent resistance). If the panel doesn't mind being shorted, just measure the Voc and short circuit current Isc, then Rint = Voc/Isc. Rint will probably vary with incident sunlight intensity; for sure Voc will. Last edited by Willbe; 24th August 2008 at 11:26 PM. | |
| well then Rint is 87.5 ohms for the smaller panels and 115 for the slightly bigger ones but I'm not sure i can calculate Rint as Voc/Isc I think I'd best go the longer way round thanks for the calculations
So with Voc = 6v and a 100 Ω load resistor you'd get (3^2)/100 = 90 mW, enough to power an LED. | ||
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk Last edited by Thunderchild; 25th August 2008 at 02:50 PM. | ||
| free solar panels | simoin | Alternative Energy | 63 | 14th December 2008 02:20 AM |
| Different solar panels | kalaman | Alternative Energy | 4 | 7th February 2008 04:27 PM |
| Self tracking Solar Power Panels | pidu_rak | Electronic Projects Design/Ideas/Reviews | 3 | 7th September 2005 02:38 AM |
| Solar panels | juan123 | Electronic Projects Design/Ideas/Reviews | 3 | 10th January 2005 09:16 PM |
| Solar Panels | thebigbasicq | General Electronics Chat | 4 | 24th April 2003 01:05 PM |
