| I saw one of those funky news filler bits a couple of weeks ago that got me thinking. The guy had put one of those gizmos for separating the hydrogen and oxygen from water in his car and, voila! Increased his fuel mileage by 30%. Of course the first reaction to such a scheme is that it wont work because it takes more energy to crack the water than you get back when you burn the hydrogen and oxygen to turn it back into water again. But, are there other forces at work? Certainly, if one were to "enrich" gasoline by infusing it with additional hydrogen and oxygen, you'd get more energy from it. So, the question is: Does enriching the gasoline this way change it's characteristics such that you can get a net increase in the efficiency of the fuel? I'm just not enough of a chemist or chemical engineer to know. But, it doesn't sound unreasonable that there might be some combination in which the enrichment might allow a net improvement in the efficiency of the fuel. Does anyone here have any experience or expertise in this area? | |
| As opposed to the last several time it came up ?
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| Some how I doubt it works, if anything it reduces the fuel economy.
| Do you get a huge increase in economy, if you change from regular to premium? How about all those liquids they sell to dump in your tank, when filling up? The engine itself isn't very efficient, we hardly use petroleum to its full potential as it is, how is adding stuff to it going to change the mechanical nature? Your driving habits have a huge impact on mileage, it's tough for the average 'Joe' to know if it's the modifications to fuel or engine, or a change in driving habits that improved the mileage. I don't think we've seen the end to the rising fuel costs, this slight decrease is just a marketing ploy, a few months and we'll be back on the rise. We can expect to so see many more amazing schemes to boost economy, probably a few forgotten gems from the past. You'll spend more money on these schemes, then you'll ever save at the pump. And of course there will be thousands who claim great results, admitting you fell for one of the schemes, is difficult for most, impossible for many... | |
| I surely have my serious doubts that something as obvious and simple as merely "supercharging" gasoline with raw hydrogen and oxygen which has surely been tested in the labs, is the answer. But, that doesn't mean that there isn't a process or technique that might be yet undiscovered. I'll bet there would have been a fair amount of guffaws in the vacuum tube community, a hundred years ago, about the notion of building "tubes" out of solid material (which some dreamer may have dubbed with the ridiculous moniker, "solid-state electronics"). Actually, I'm somewhat surprized (in this computerized age) that some water injection system, such as has been used on aircraft for decades, isn't used routinely in cars to replace some of the gas from the carburetor or injector's accelerator pump with water. Certainly, a hydrogen enrichment scheme has the smell of snake oil about it. Hey, maybe snake oil is a viable additive to improve mileage..... | |
| | (permalink) | ||
The solution is to drive smaller cars with smaller engines. I used to think that the "Mad Max" movies were silly with people driving big cars during a severe fuel shortage. North America's love of the SUV has changed my mind.
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 19th August 2008 at 02:45 AM. | |||
| I thought a modern car would adjust the fuel/air ratio by using the oxygen sensor in the exhaust and therefore you would get better mileage from higher octane fuel. As for the OP's question, it's nonsense. Mike. | |
| More efficiency for your liter of petrol is easyer to get in your drive train and all related to it make sure your tires are on the right pressure is one of them make sure you change your oil on time (engine and transmision) wash your car (sounds funny but a clean smooth car has less drag) use LED lights for your city lights (the small bulp in the headlight assembely) if you have to stop for more than 30 sec shut the motor off (some trafick lights have count down timers) when you cruising and you want to overtake some other car swich of the aircon and switch it back on when the manouver is made acselaration is the biggest consumer of petrol so try to keep one speed for a long time (verry hard to do in city traffic) Robert-Jan | |
| I find it ironic that people come up with all these ways to save gas but forget the simplest - drive less. Oh No! I couldn't possibly stop driving so much, it's a violation of my human rights. | |
Higher octane without a higher compression ratio has almost no effect. | ||
| If you're lucky, and the crap in the bottle burns as well as gasoline, then you just found a way to pay $50 a gallon for fuel. | |
When burning premium in a lower compression engine, it makes sense that not all the fuel will burn in time and some will go out the tailpipe. Trying to compensate by adjusting the mixture wont work since the effects are counterproductive (ie: leaning the mixture doesn't make the gasoline burn any faster...it just provides less fuel to give the engine power). Now, I know that's not strictly true since there are many variables in the cylinders. But, you don't see many people who warn against using premium when not needed. Maybe they know something I don't? (very possible). | ||
| Bad language deleted, such language isn't tolerated here - moderator. Last edited by Nigel Goodwin; 19th August 2008 at 09:40 PM. | |
| The slower burn rate of high octane fuel isn't slow enough to cause incomplete combustion, it's just enough to prevent detonation. | |
| Need Major Help | HelloDearFello | Electronic Projects Design/Ideas/Reviews | 0 | 21st May 2008 05:07 AM |
| automotive fuel sender unit / fuel gauge | drage | General Electronics Chat | 6 | 20th October 2006 07:37 PM |
| HELP ME choosing my Major!! | sonaiko | General Electronics Chat | 6 | 18th January 2006 12:35 AM |
| Am I going into the right major? | jrz126 | General Electronics Chat | 6 | 27th October 2004 02:22 AM |
| URG: need help for my major project | dug | General Electronics Chat | 1 | 26th August 2004 08:01 PM |
