+ Reply to Thread
Results 1 to 8 of 8
Thread: Parallel bicycle dynamo..
  1. #1
    bianchi77 Newbie
    Join Date
    Aug 2008
    Posts
    1
    Default Parallel bicycle dynamo..
    Anyone know how to parallel the bicycle dinamo ?
    I want to have a power around 300 W....
    Or may be I can use different dinamo ?
    Reference :
    http://shop.miniscience.com/navigati...l.asp?id=BGEN1
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    I'm not at all sure this isn't just spam?, and the advertising has been removed.
    But to parallel bycycle dynamos rated at 3W would require 100 of them to get 300W, which is more than a cyclist could generate.
  3. #3
    Boomslang Good Boomslang Good
    Join Date
    Mar 2007
    Location
    South Africa
    Posts
    253
    Make a coal fire with steam engine on your bicycle to drive the dynamos... problem solved.. As Nigal say, you would need legs stronger than Miguel Indurain.
  4. #4
    Join Date
    Mar 2007
    Location
    South Africa
    Posts
    253
    Well maybe I was wrong:
    "A completely inexperienced rider, for long periods of time, can output 50 or 100 watts of leg power; whereas a Tour de France racer is said to be able to generate 500 watts or more of continuous power—still not up to a horse, but mighty impressive, none the less!"
    copied from: Cycle Maths
    but with the losses added in converting the power you will still battle to get 100W...
  5. #5
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    The figure to work with is 100W maximum, you can't really consider Clark Kent's stronger brothers!
  6. #6
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,120
    Dynamos are really alternators so when you parallel them you need to make sure they're in phase or they'll overheat.
    if I know the answer.
  7. #7
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by Hero999 View Post
    Rectifiers!
  8. #8
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Much more fun to try and make them run in phase!
    As a kid I hated just using ONE of these dynamos as they added a lot of drag. But they made good brakes when riding down hill though. If you want more power, a large PM DC motor would act as a generator if belt driven off the wheel. Or maybe get one of those hub generators:
    http://www.sheldonbrown.com/harris/l...g/shimano.html
+ Reply to Thread
  1. bicycle dynamo
    By raviram87 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th January 2008, 02:21 PM
  2. Bicycle POV
    By Macka in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th August 2007, 02:19 PM
  3. bicycle dynamo powered soldering iron
    By wisdumb in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th July 2006, 08:50 AM
  4. Dynamo Characteristics
    By fzn10 in forum General Electronics Chat
    Latest: 17th March 2006, 08:18 PM
  5. Bike dynamo
    By hantto in forum General Electronics Chat
    Latest: 5th November 2003, 07:42 PM
Tags for this Thread
