| G'day Guys, Well a mate has been saying he tried using non polarised caps on the phases of the F&P for a greater output and I did see the results... Very impressive Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | |
| I think you already know what capacitors do in a PSU?, and they don't produce more power - they just store the energy and release it as the input drops below their charge level. If you're using it to charge a battery it should make no difference whatsoever, the battery already does exactly the same function. | |
| Sounds like your current readings were/are distorted by the frequency. As Nigel says you're not generating more power, your meter is just reading it differently now as the capacitors are smoothing things out. The analogue current meter will likely provide a more reliable reading weather or not the capacitors are connected. Even true RMS digital multi meters are only good up to a few hundred hertz. If you were feeding it raw generator power with minimal filtering it was definitely not reading the correct current draw as the generator will produce frequencies way past your meters usable range. Don't think adding more capacitance will increase your power output because once you get past basic ripple filtering the battery doesn't care and you're just wasting power through the ESR of the capacitors you're using.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 30th July 2008 at 01:45 AM. | |
| To get a "measure" of power you could connect a filament lamp(s) of suitable wattage (to obtain similar currents that you observed) to the genny output, connect/disconnect the caps & see if there is a change in brightness. or Place a decent resistor as the load & measure the temperature rise of the resistor relative to the resistors ambient. (shield the ambient probe from resistor IR) Both of the above should indicate power produced regardless of frequency & the load characteristics are resistive, the time constant however of the second method will be much longer. Would be good idea to bench test the F&P gen being driven of a motor. I havent given this much thaught, but if there is more power being generated with the same wind speed it may be that the capacitors are helping to reduce magnetic drag in the rotor. I have observed similar improvements in some DC brushed motor power when fitting a capacitor near the motor with a long / lean wire feed from the power shed about 30m. | |
| hi Bryan, 'Tonigau' has the correct method, measure the power output, rather than just the voltage. The lamp brightness idea will give you a better indication of the rms value of the current/voltage.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| Guy's the caps are placed on each wild AC phase before the rectifer. My mate has done extensive testbench testing on this method using motor run caps and has proven it does work. I suppose with the F&P having 42 poles the caps are just doing some PFC and thats why I'm seeing a better result. We have complete data on all the different F&P motors on a graph ie: speed of the prop against current. Now using the caps those graphs are being re-written. Before I put the caps on the waveform was a distorted sinewave at best after the caps the waveform is damm close to a sinewave. Now i do agree you don't get any extra power out of using caps but by putting them on each wild AC phase it's making a BIG difference. I have looked extensively on PFC to try and explain this but the only thing I could find was using a fixed frequency and the frequency varies with rpm so I haven't been able to find an equation to solve this on paper. Hopefully this weekend we'll have some gale force winds and if so I'll take some pic's of the results on using caps and without caps. Regards Bryan
| Bryan, you are correct about the Power Factor Correction that the capacitors provide. The rectifier/battery load is nonlinear which causes the distortion and power loss. The capacitors simply store the energy from the unused portion of the cycle (when the rectifiers are off) and help supply current near the peak of the waveform when the rectifiers are conducting. A better method would be to use active PFC (A boost converter [followed by a buck if needed]) so that the current is in phase with the voltage. This circuit will also inherently regulate the voltage to the batteries. This will better eliminate the harmonics than the capacitor solution.
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 31st July 2008 at 06:02 AM. Reason: Active PFC | |
| Like any electrical device batteries will last longer with a regulated charge as opposed to a lot of ripple.
| Ripple kills batteries as they're being charged and discharged at 100Hz. They aren't like capacitors which don't have a limited number of cycles.
| Most alternators have a lot of inductance in the windings. The open-circuit voltage of an alternator is often many times the running voltage. That is why load-dump on a car alternator is so severe and why voltage regulators on AC generators are so important. In constant current, variable speed applications, the large inductance is used as a current limit. That applies in car alternators and in directly driven AC lighting like on bicycles and some small motorbikes. The current is largely independent of voltage load at higher speeds. I was able to change my motorbike lighting (1983 Honda CG125) from 30W at 6V to 60W at 12V with no change to the alternator, but it was dim at tickover. On the wind generator, the capacitors in series will form a tuned circuit with the inductance of the windings. The impedance of a series tuned circuit is less than the scalar impedances of the inductor or the capacitor. The lower impedance may increase the current a lot. It isn't breaking any thermodynamic laws, it's just bypassing a current limit. It is quite possible that the generator takes more shaft power and slows the turbine more, so takes more power from the wind. The shaft power is difficult to measure, and it isn't fixed for any particular wind speed. At zero speed, or at zero load, there will be zero power. Maximum power will be at somewhere around half the zero load speed, but it is unlikely that a small wind generator manages to hold the turbine close to maximum power speed all the time, and that is where some improvement can be had. The downsides could be:- The current limit is compromised, so there could be damage to the alternator if it is designed around the natural current limit. The batteries could be charged too fast. The effect will only be at its best at one wind speed, as there is only one frequency that gives best tuning. However, there could be some improvement at all useable wind speeds. I agree that AC currents from wind generators are difficult to measure. Last edited by Diver300; 10th August 2008 at 09:35 AM. | |
| Wind generator | borodin | Electronic Projects Design/Ideas/Reviews | 4 | 18th July 2008 01:59 PM |
| How do wind a transformer | FusionITR | General Electronics Chat | 16 | 31st March 2008 01:47 AM |
| Using Caps on a 3 phase genny | bryan1 | General Electronics Chat | 6 | 9th October 2007 08:20 PM |
| Wind-up LED Torch! | HarveyH42 | General Electronics Chat | 26 | 25th June 2007 01:31 PM |
| electrolytic caps VS. tantalum caps | hardcore misery | General Electronics Chat | 51 | 7th January 2007 11:09 PM |
