Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 26th July 2008, 07:08 AM   (permalink)
Cool Solar Power Generators?
i want to create myself a solar power generator, doesn't matter how much power it generates. basically i just want to design a system which is capable of running 2fans/2lights for my class room
otherwise i want to use the existing solar plates which usually comes with solar lights (which are availbale in market) to produce maxm current/voltage... any help/documents are welcome
nitins60 is offline
Old 26th July 2008, 08:14 AM   (permalink)
What voltage and wattage are the lights and fans?
Are the fan motors AC or DC?
Torben
EDIT: By the way, welcome to the forum!
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Old 26th July 2008, 08:23 AM   (permalink)
this can be everything that produce some sort of power in the sun
please be more specific wath you mean
there are a lot of markets in the world so where are you located
for solar panels in general they produce the maximum of energy when they at an angle of 90 degrees in the sunand the closest to the sun (equater) and the cooler the plates are the better the efficiency is
Robert-Jan
rjvh is offline
Old 26th July 2008, 09:46 AM   (permalink)
Also fill your location, notice that all other posts here have it entered in the profile.
Location is obviously paramount for aolar questions.
Old 26th July 2008, 05:19 PM   (permalink)
Here's a rather nice way.
You need to track the sun, very important. There is a post on that, check it out.
Use a system of dishes to focus your sun to a hot part, which is actually the hot side (chamber) of a Stirling engine.
This can be run nicely, even with slight gearing, to pull a simple genny.
You can choose whether you want AC or DC (type of genny), and electrocute whatever you want.
Stirling engines off the sun is quite fun, but you need to have some savy to build it.
Just advice, nothing more. Hope it gets the gray matter going.
arrie is offline
Old 29th July 2008, 02:47 AM   (permalink)
ok let me clear my view
1. i have done a project which inverts 12v dc to 220v ac supply
now if i am able to generate 12v from solar power and store it into battery, i can achieve my goal....
hopefully this is enough information
nitins60 is offline
Old 29th July 2008, 03:14 AM   (permalink)
Hi nitins60
you will be able to achieve your goal
the only thing that you need is solar panels a charger and batterys
india does make solar panels so i asume they are the chaepest option for you, so check your local yellow pages
probably india also makes deep cycle batterys so again check yellow pages and/or internet
charger that you need i will post a schematic that works (build 2 of them already and they work happely also a lot of schematics are availible on internet
next time if you have a question it's better to give to much info than to less
Robert-Jan
rjvh is offline
Old 29th July 2008, 03:17 AM   (permalink)
to quick in pushing the button (I forget the atachment)
Robert-Jan
rjvh is offline
Old 29th July 2008, 03:42 PM   (permalink)
if you can, please post the full details regarding circuit and how to use it. i have gone through circuit and couldn't get the way it's used. anyway thanks for yr help
nitins60 is offline
Old 30th July 2008, 01:51 AM   (permalink)
the full details is not that much of a use for you unless you can read and understand Dutch
if you point out where you have a problem with understanding it than we can help you with that
what is your experiance level on electronics ???
Robert-Jan
rjvh is offline
Old 30th July 2008, 02:41 AM   (permalink)
i am newbie to electronics, doing engineering in elecronics and communication... that too i am 2nd yr student. so please help me to achieve this... if possible, provide full circuit details. thanks
nitins60 is offline
Old 30th July 2008, 08:05 AM   (permalink)
Hi if you a second year student than i asume you can read the schematic and reconize some comon practice of electronics setup/building
A1 is used to control the Fet which you can see as a electrical controled resistor in this shematic
A3 is just a signaling if the voltage is above a set level (not critical for the charger function)
A2 is a discharge controler as soon the voltage drops under a level it will disconect the user in order to save the battery
A4 is a electronic fuse if the current is to high (setting is adjustible) it will shut off the load to protect the battery and/or user
if you have more questions be more specific of what you don't understand after all all these sections of the circuit are just variations on basic switch/control techniques with a opamp
it would be defenetly in your electronics schoolbooks
Robert-Jan
rjvh is offline
Old 30th July 2008, 02:08 PM   (permalink)
thanks for information. wish me to get succeeded n this project
nitins60 is offline
Old 30th July 2008, 03:41 PM   (permalink)
I wish you sucsess in your project
Sucsess
Robert-Jan
rjvh is offline
Old 11th August 2008, 12:32 PM   (permalink)
hi ! am new member, i want to design a circuit which could detect smoke/gas and then responding by sound alarm which could alert anyone nearby that there is a danger of fire or harmful gas, could you help with my design?
Jewson is offline
solar power supply + backup power mabauti Alternative Energy 9 21st March 2008 06:22 PM
help with solar power source diddy5584 Alternative Energy 4 28th October 2007 03:51 AM
Solar Power Management ultimatekiller General Electronics Chat 3 14th October 2007 06:22 PM
Want to power a GPS with solar, need help! Grandpapabi Electronic Projects Design/Ideas/Reviews 14 14th August 2006 12:10 PM
Solar power regulator??? drrogla Electronic Projects Design/Ideas/Reviews 7 2nd April 2005 11:22 AM
