| Exactly, why hasn't it been done yet? We have to do it ourselves. There's some people over on youtube posting tests and experimentation and I don't think they're all scammers wanting you to buy their BS mason jars producing HHO. Some of these guys are serious electronic hobbyists. Check out a guy named zerofossilfuel. His work is inspirational. | |
| Because nobody wants worse fuel economy, which is what the result would be. Torben
__________________ Curiosity was framed. Ignorance killed the cat. Last edited by Torben; 19th July 2008 at 12:47 AM. Reason: Grammar fix. | |
| If real testing has already been done and the concept has been debunked, then the debunkers would already be out their with their own scientific information and numbers. As for the naysayers with just opinions, I guess they're just as bad as me. No info, no numbers, no testing as of yet. Just hypothesi. Don't get me wrong, when I start testing I will post on a new thread and I may start debunking if it turns out to be BS. I'm done on this thread now... | |
It takes a lot of proof to overturn well-established rules. I hope you do your tests, and while I do not believe that you will find that the idea works, it would be nice to see physics turned on its ear--that's how the greatest advances in our understanding of the universe have been made. The problem here is that there is no great mystery to the maths involved, and for the proposed system to work, the Laws of Thermodynamics must first be proven wrong. Despite mighty efforts over the years, that has yet to happen. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
| This video just came up on Instructables.com, kind of made me wonder about this thread... http://www.instructables.com/id/Wate...-volt-battery/ Not really detailed, and considering some of the hoax videos I've seen, hard to tell if this is real. It makes the Browns gas, using a 9 volt battery, which I wouldn't think it would last long enough to produce much gas. When the guy flipped the switch, sort of a fog started to form, few seconds later he opened a valve and lit it up. Not a huge explosive flame, like in chemistry class electrolysis. Even as a 'naysayer', must admit to being a little impressed. Maybe a quart container, a 9 volt battery, and only a few seconds before a burnable amount of gas is produced. I can see how so many people get hooked on this crap... | |
Just a guess Edit: Did you ever HV that rat ?
__________________ Truthiness Monkeys : Obedience, Ignorance, Fear. Last edited by killivolt; 20th July 2008 at 04:01 AM. | ||
Rats, never got even one on any of the homemade gadgets. Did get zapped changing batteries on one of the traps I bought. Unpleasant, but didn't feel life threatening. Fortunately just through my hand. | ||
Aslo in the video (the begging) it says "After 678 Differnts Endehavors" I have no idea what a "endehavors" is | ||
| agreed why is every other thread on this section about making hydrogen in-car to run the car more efficiently
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | |
Don't for get the Global Warming crowd either. I'm mean we have to do something, can we really afford to not even try? I do agree that there should be some way to separate the fringe topics, from the proven. Perhaps a 'experimental' Alternative Energy forum for the Joe-Cells and Stearon machines, leave this one to stuff already in use like wind, solar, and hydro. | ||
| One aspect often forgotten by advocates of HHO is its (namely hydrogen's) deleterious effects on the environment. It seems most of the advocates focus on what happens when one burns hydrogen and gets only water. Water is good is all that is considered, but that doesn't mean hydrogen itself is a non-pollutant. By analogy, consider ordinary table salt (NaCl), which is essential for life, but chlorine gas itself is a poison. In fact research reported from Stanford shows that hydrogen increases the effects of greenhouse gases and can lead to destruction of ozone in the upper atmosphere. Thus, the hydrogen you are producing may be as bad for the environment as outlawed aerosol propellants and greenhouse gases. Quote:
So, those of you making hydrogen need to carefully consider how much you are polluting the atmosphere, increasing global warming, and contributing to increased cancer rates by increasing the ozone hole. John | ||
| here are the simple facts.... FACT: we are using oil from the earth that took millions of years to produce. FACT: it will not be replaced once used so we will expend all the earths oil eventually. (what will oil companies sell when the oil reserves end ?) * oil insurance? (which insurance is a legalized scam). FACT: Global warming is a real threat, and will be experienced in our lifetime. FACT: Hydrogen or HHO makes the engine run cooler, cleaner more efficent. FACT: I.C.E (internal combustion engine) run dirty on carbon based fuels, diesel and gasoline. * look up ethanol, most gas is sold with 10 % so out out the 9/10ths of a gallon you pay for ... your only getting 7.73% of actual gasoline. hydrogen can increase the burn rate of ethanol and gas so there is less heat and less loss of usable power eliminating the use of cat converters. FACT: water has an electrical resonance of the oxygen and hydrogen electrons, if you cause a breakdown of the covalent bonded electrons they will separate or release the their shared magnetic attraction because the shared electrons are replaced by induced electrons from electrolysis. simple example is three magnets, the opposite poles attract two of the three but as soon as you add a third it changes the magnetic "hold" and attraction of opposite poles and the magnets break apart , so if you add electrons to the H2o molecule at the breakdown freq. it will separate. TRUTH: hydrogen is the most abundance renewable resource in the universe, our sun uses it as its "MAIN" fuel and in that process it causes nuclear reactions or fission which regenerates a portion of the energy that is lost as heat. what we should be researching is a way to chemicaly break down water into its atomic parts and burn the hho as fuel, and then the byproduct is H20 all over again. my two cents. | |
| see this thread http://www.electro-tech-online.com/a...tml#post328524 ( page 6 and after, the pages before it are interesting but I think you'll see why i said page 6 onwards | |
What the .............. I've never seen this before. Edit: I think I'm in the Matrix. kv
__________________ Truthiness Monkeys : Obedience, Ignorance, Fear. Last edited by killivolt; 22nd July 2008 at 10:58 PM. Reason: Looking for Cats | ||
| | (permalink) | ||||||
Prove that hydrogen can increase the burn rate. Changing the burn rate reduces the heat? Less heat means less expansion of gas, which means lower cylinder pressures, which means less power output. The catalytic converter used platinum and other elements to reduce CO, VOC and nitrogen oxide emissions… Burning fuel with hydrogen won’t reduce these emissions, since there is still fuel being burned. Quote:
Yes but the sun doesn’t need to use energy to split water molecules to burn it… Last edited by Conrad_Turbo; 22nd July 2008 at 11:04 PM. | |||||||
| Hex Generator? | AceOfHearts | Micro Controllers | 10 | 16th July 2007 11:07 PM |
| Ac Generator | earjun | Electronic Projects Design/Ideas/Reviews | 3 | 25th January 2007 05:16 PM |
| generator | triple_access | Electronic Projects Design/Ideas/Reviews | 7 | 27th June 2006 01:58 PM |
| generator cct | tim0611 | Electronic Projects Design/Ideas/Reviews | 33 | 29th September 2005 06:46 PM |
| ELF generator | koton666 | Electronic Projects Design/Ideas/Reviews | 9 | 15th October 2003 11:52 AM |
