Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 12th May 2008, 09:59 AM   (permalink)
Originally Posted by j_mchattie
I have a solar panel which provides 12-22v, 2.4W.
I also have a 4.8v 0.9W pond pump, and I would like to put the two together.
I need to get a frog spitting!
Looking at the application.! I would think the cheapest is the best.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 12th May 2008, 10:25 AM   (permalink)
The question here is if the solar panel can source enough current for the pump. What I am not sure if 2.4W corresponds to 12V output (which is 0.2A) or 22V (which is only 0.1A). The pump needs almost 0.2A. So if it is 2.4W at 12V output a linear regulator could be used but in the second case there is not enough current (and power to waste in as heat the linear regulator) and the buck regulator is necessary.
petrv is offline   Reply With Quote
Old 12th May 2008, 11:42 AM   (permalink)
Solar panels are usually rated at 12V, so 2.4W should give 200mA, enough to make the frog spitting into the pond motor work.
I dont think the is too bothered about wasted energy, just the lowest cost.
Eric
PIC tutorials:
Old 12th May 2008, 01:31 PM   (permalink)
Originally Posted by ericgibbs
Perhaps this circuit will help.
Thanks for the circuit diagram - that does help. I'm just no good with things I can't see! (electricity).
speakerguy79 - I don't mind $14 dollars here and there - I just want something that will work. Thanks for looking that up for me.
petrv - I have had a look and the panel will provide 2.4w at 17.5v
j_mchattie is offline   Reply With Quote
Old 12th May 2008, 01:52 PM   (permalink)
you can try the linear regulator like 7805 - it is cheap and simple and check how it will work. If the performance is not satisfying (check also different light conditions, measure the current flowing to the pump) you can decide to try the buck controller which should give you better results. Either the simple solution for $14 from TI or the cheaper controller from National (but more complicated circuit). The circuit for the TI buck controller was already posted here, the one with the National chip is in the datasheet:
http://www.national.com/pf/LM/LM25007.html
Petr
Old 13th May 2008, 01:18 PM   (permalink)
It sounds like the 7805 will use a lot of the energy the panel is providing.
I can buy a pack of 10 0.5v solar panels on eBay - they each provide 250ma in strong sunlight. If I got them, and strung them all together, I could easily power the motor at 5v. But if the sun got really strong and the volatage went higher, could I kill the motor? My guess is yes (even though its underwater and wont get hot).
Is there a way of turning the extra energy into heat if the sun gets too strong?
I just want a pretty constant 5v for as long as the sun will allow. If there is an energy shortage I dont want a 7805 sucking it all up, and if there is an energy surplus I dont want the motor burning out!
To recap - I can get/have got:
10x 0.5v 250ma solar cells (monocrystalline)
pond pump 4.8v 200ma (ish)
James
Old 13th May 2008, 01:48 PM   (permalink)
The 7805 reg dosn't suck any energy, it drops the voltage over a range of inputs from 8V coming from the panel thru to 22V.
The lower the voltage from the panel [down to about 8V] the lower the energy dissipated as heat in the 7805.
James
The 7805 dosn't use energy it dissipates the excess voltage/current as heat.
If you are in doubt, try it, the power levels you are talking of are not going to cause a fire.!
Eric
PIC tutorials:
Old 13th May 2008, 05:29 PM   (permalink)
One of the posts said that it would only be 40 odd percent efficient. So I thought the panel might not provide enough power to run the motor. I wll give it a go though and see.
Thanks for your help Eric
Old 14th May 2008, 11:43 AM   (permalink)
The efficiency of an ideal linear regulator in percents is (V-out/V-in)*100 for example V-in=12V V-out=5V gives little over 41%. The bigger is the difference (V-in - V-out) and lower V-out the worse is the efficiency. As Eric said in the previous post, the excess energy gets dissipated by heat in the linear regulator.
The input current is always the same as the output current (I am ignoring here thq quiescent current of the regulator as it is usually very small) so 0.2A at 5V is your 1W output but the same 0.2A at 12V is 2.4W (the excess 1.4W gets dissipated as heat on the linear regulator). So if your solar cell is able to supply the needed current (0.2A) at the voltage it outputs it should be OK.
Old 14th May 2008, 01:41 PM   (permalink)
I have had a bit of an idea. I went to Maplin and they guy was pretty unhelpful. He said I should buy a £25 12v SLA battery, and a £7.99 circuit kit to make a 12v to 5v transformer.
He then said I should get a charge controller for the battery (£11.99) and power the pump from that.
So I went!
Anywaym on a walk round Tesco (its air-conditioned) I saw an in-car mobile charger which runs between 12 and 24v.
I have an incar charger which I dont use - so I put it across the solar panel (21.3v at the time) - and the charger gave 5.5v
I then did the same across a 12v battery and the charger gave 5.5v again.
I think the problem is solved!
Thanks for all your suggestions - I think I will pull apart my in-car charger and put the bits in a project box.
Old 16th May 2008, 04:26 PM   (permalink)
Oh bum.
I juat had an email from the people who make the original solar panel and motor - they say the motor actually runs between 4.8 and 8.5v.
Obviously I want to run at around the maximum output of the pump because it's so small anyway - so I am aiming for about 8v here.
I can buy a solar panel on eBay which can supply 9-11v 3-4w
It is actually listed as a 6v 3-4w panel - but says in the description that the actual output is 9-11v
Is there a way of getting this nearer to 8v?
Sorry to start it all up again - blame SmartSolar!
Old 16th May 2008, 05:20 PM   (permalink)
Originally Posted by j_mchattie View Post
Oh bum.
Instead of a 7805 you can buy a 7808 thats a +8V reg.
Or if you have already bought a 7805, you can make it output +8V by adding two resistors... what would you like to do.?
Eric
PIC tutorials:
Old 16th May 2008, 05:23 PM   (permalink)
I was blinded by looking too hard!
Thanks for that - 7808 will do nicely
Again - thanks!
Boost converter help. yngndrw Electronic Projects Design/Ideas/Reviews 12 11th September 2007 05:37 PM
USB - TTL Converter samltd Electronic Projects Design/Ideas/Reviews 5 7th July 2006 09:46 PM
Monitor Converter: NTSC/PAL to VGA/SVGA scan converter NOSREME Electronic Projects Design/Ideas/Reviews 0 21st June 2005 02:46 AM
Cuk converter PWM controllers? Schneibster Electronic Projects Design/Ideas/Reviews 30 2nd May 2005 09:03 AM
help with my project 5vdc signal to control(interrupt)power vanko Electronic Projects Design/Ideas/Reviews 0 25th June 2003 01:23 AM
