| | #1 (permalink) |
| New Member Join Date: Apr 2008
| I am building this circuit (12DC to 12VAC) and I am having problems, first of all for the VPULSE, what should I use, a 555 timer or ua741 opamp to create a square wave.... the bigger problem is how many independant vpulse should i have....two are still managable but four are very difficult to syncronize im pretty much late (for my project) here so dont post any more complicated inverter designs.. i removed the protection diodes for the time being.... |
| | #2 (permalink) |
| Experienced Member | Welcome to the site. C47. It would be better to use 555 followed by buffers to get more outputs of the same signal. If you want complimentary outputs , you may use 55 at double the frequency, divide it by2 and use the "Q" and "/Q" outputs. By the division method, you achieve 1:1 pulse ratio.
__________________ Regards, Sarma. Last edited by mvs sarma; 21st April 2008 at 08:02 AM. |
| | #3 (permalink) |
| thankyou sarma, tha complimentary idea is billiant if it is in the chip itself.... the problem with the 555 timer is also that is starts with 48Hz and climbs upto 52Hz , ie for some reason its not stable Im using the NE555P and its doesnt have the Q'...please help Last edited by C47; 21st April 2008 at 08:11 AM. |
| | #4 (permalink) | |
| Experienced Member Join Date: Jan 2007 Location: U.K.
Its not just the Vx drive pulse generator thats the problem. V4/5 are in opposite phase as are V2/3. Alternating.! V2 and V5 need to be ON at the same time, with V3 and V4 OFF, then on the next cycle, V2/5 OFF and V3/4 ON. The problem arises using 555 is the level shifting for the V2 and V3 pulses as they are not referenced to 0V. Summary: Only two phases, but V2 and V3 need level shifting. Do you follow.? EDIT: I am assuming that you require the 12Vac across the inductor.??? With ref to the 555 osc frequency drift, please post your circuit, what R,C type components are you using.?
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs; 21st April 2008 at 08:18 AM. | |
| | #5 (permalink) | |
what you mean by level shifting and if i manage to do that what should i do with the GNDS of V2 and V3? where should i put them....at the emitters of the top BJTs? also are you suggesting to use one 555 timer? coz thats not possible becoz of gnd connections... | |
| | #6 (permalink) |
| ericgibbs thankyou for helping..... as for your reply to the edit: well the capacitor and inductor were kind of loads...filters sort of things....please excuse my ignorance....i can run the circuit in PSpice with R as a load only too....but the problem is implementing it in real life |
| | #7 (permalink) | |
See edit to my last post.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ | |
| | #8 (permalink) |
| the 555 circuit: Ra = 1kohm Rb = 51K+91K C = 0.1uF and the 0.01uF is the same as in my circuit ericgibbs please suggest how many 555 should i use? DUTY Ratio = 49% EDIT: I didnt use Pspice for the 555 i just tested it manually and changed RB with a potentiometer when i got 50Hz i put in a fixed resistor Last edited by C47; 21st April 2008 at 08:31 AM. |
| | #9 (permalink) |
| hi C47, The original circuit, must you follow that design using those types of transistors. The top two are connected as emitter followers and the bottom two as common emitter. The top two should be pnp transistors. Is it permitted to change the original design.?
| | #10 (permalink) | |
| | #11 (permalink) | |
| | #12 (permalink) |
| hi C47, This is a very basic circuit in order to demonstrate the idea. As its a 'project' it would best if you calculated the required values. Do you follow it OK.?
| | #13 (permalink) |
| well what are those empty boxes and where did the 12V go? and whats the red transistor for? and where are the drives for the top two? is this a half bridge rectifier? EDIT : is this supposed to get rid of syuncronization issues Last edited by C47; 21st April 2008 at 09:10 AM. |
| | #14 (permalink) | |
What college year is this project for.?
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:49 PM |
| Button Debounce Coding help | Suraj143 | Micro Controllers | 25 | 4th August 2007 09:49 AM |
| Define Linear Devices & Switch Mode Power Supplies? | Suraj143 | General Electronics Chat | 17 | 9th July 2007 02:15 AM |
| Square wave AC? | grrr_arrghh | General Electronics Chat | 9 | 19th February 2004 09:27 PM |
| some asembly coding help needed 1000hz square wave ? | waqar | Micro Controllers | 10 | 13th April 2003 08:52 AM |
