| | #16 (permalink) | |
| Experienced Member Join Date: Jan 2007 Location: U.K.
| [quote=C47]well for q3 i will use an opamp inverter, is that okay? Thats OK, something better than a 741 if possible. im sorry i didnt understand the linking resistor part? No problem, its easier to draw a rectangular box than a zigzag resistor. is the red 5V suuposed to be 12V On your drawing you show a 555 with a 5V supply, I was just trying to keep the drive transistor the same. or is it part of the BJT inverter that you meant to use? It just powers the invertor.[/QUOTE] Quote:
If its easier the 555 can run at 12V, as can the BJT invertor, just calculate the appropiate resistor values.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs; 21st April 2008 at 09:33 AM. | |
| | #19 (permalink) | |
What value of resistors do you have in the 555 output to the transistor and opa invertor.? EDIT: post a drawing with the component values on.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ Last edited by ericgibbs; 21st April 2008 at 10:28 AM. | |
| | #20 (permalink) |
| hi, Double checked my circuit, OK If you have popped the 555 you have connected something incorrectly. Check the supply to the 555 timer make sure its not greater than 15V or so volts, also the connections to the 555, especially pin #3.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ |
| | #22 (permalink) | |
Are you saying that connecting as the attached circuit, popped an 555.? If yes, you must be doing something wrong...Have you checked the 14V with a meter.?
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ | |
| | #24 (permalink) |
| New Member Join Date: Apr 2008
| sorry mate, must have made a mistake somewhere....i managed to invert the signal from the 555 using the inverting buffer (bjt)...also the two signals are 176 degrees out of phase instead of 180, which means that during the run (at a certain point and time) all four switches are open.... |
| | #25 (permalink) | |
Pleased to hear you are making progress. Its the transistor invertor thats causing that 176deg problem, a comparator, used an invertor could could be set to give a switch over near 0Volts, in order to give 180deg.
| | #26 (permalink) |
| ok we made this really big circuit....with three 555 timers - one of them providing the clock for the other two with the other two we can vary the duty cycle and make it work.....this is still in progress as one timer give 70% (as we want) and the other is giving 1% (we want 20-25%) - i tried changing the values of the resistors and capacitors .... anyway this problem is being worked on.... your idea of having two pnps...i have tried it in pspice... i will post it soon Last edited by C47; 28th April 2008 at 04:28 PM. |
| | #29 (permalink) | |
I agree, I would have thought his simulation program would have burped and thrown up a warning... the 'base' voltages, wrt 0V, on the reversed transistors should have been an indication. Check it out C47..
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:49 PM |
| Button Debounce Coding help | Suraj143 | Micro Controllers | 25 | 4th August 2007 09:49 AM |
| Define Linear Devices & Switch Mode Power Supplies? | Suraj143 | General Electronics Chat | 17 | 9th July 2007 02:15 AM |
| Square wave AC? | grrr_arrghh | General Electronics Chat | 9 | 19th February 2004 09:27 PM |
| some asembly coding help needed 1000hz square wave ? | waqar | Micro Controllers | 10 | 13th April 2003 08:52 AM |
