| | #1 (permalink) |
| New Member Join Date: Mar 2008 Location: Pune, India
| Hello, This is my first post over here. I have an 85W (12V) solar panel to which an 84 W (7A) DC motor is connected. The armature resistance is arround 0.76 ohms. Hence the starting current for this DC Motor is 16A (i.e. (12V - 0V)/0.75ohms). Could anybody guide me about building a current booster for this motor? The limitation is I can not add another panel to this system. It will increase the cost heavily. Please let me know if any additional information is desired. Warm regards, Amitraj |
| | #2 (permalink) |
| Experienced Member Join Date: May 2006 Location: Alberta, Canada
| Use a capacitor to supply the peak current during the transient period. That's what they;re used for even on motor drivers with mains or battery sources. But make note about whether the wattage (and hence current rating) of your solar panels are for peak conditiosn and so your motor may still not operate unless in direct, full sunlight. It seems like a fairly heavy continuous load to run off of solar panels though... Last edited by dknguyen; 24th March 2008 at 07:02 AM. |
| | #4 (permalink) |
| Experienced Member Join Date: Aug 2004 Location: Adelaide Hills Sth Oz
| Hiya Amitraj, A good unit to use to drive pumps, motors etc directly off a solar panel is a device called a maxi-maximizer. I did notice in a renew magazine they sell a kit for them or you could try and find the schematic on the net. Here is link to the mini-maximiser and by simply upgrading some of the parts should give you the required current draw. http://www.voltscommissar.net/minimax/minimax.htm Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" Last edited by bryan1; 29th March 2008 at 10:22 AM. |
| | #6 (permalink) | |
Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | |
| | #8 (permalink) |
| Experienced Member | I'm not sure that Maximizer makes any sense at all. PWM'ing the stalled motor will only lower the current which will not assist in starting it AFAIK. Starting the motor with a capacitor may require a very large capacitor. It is difficult to say what is required since it depends on the inertia of the rotor and many other factors. Let's say it's very fast and requires 16 amps for only 0.2 sec, and the solar panel produces 7 amps out of that so we only need 9 amps from the cap. But if the capacitor voltage drops below 8v before 0.2 sec then the motor will not start. I get 0.45 Farads for that hypothetical spec. There are stereo system "boost" capacitors readily available in that range in the US, but elsewhere finding that much capacitance in this range may be difficult. It would make more sense to install a battery on your solar panel. Not only does this solve your starting problem but you can better utilize your panel. For example there are going to be many hours where the panel produces electricity but it is too little current to run the pump so it is useless. If you charge a battery for 1 hour in weak sun you can run the pump off the battery+panel for 30 min you get output you otherwise could not use.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
| | #9 (permalink) | |
| Experienced Member | Quote:
It's really a simple switching regulator, with feedback tailored to the purpose. Maybe you should re-read the article. | |
| | #10 (permalink) |
| Experienced Member Join Date: Apr 2006 Location: England
| I agree, I don't see how PMing a motor can help start a motor, if anything, it'll only make it worse. For the capacitor idea to work, you need to give the capacitor time to charge before the motor is switched on. Last edited by Hero999; 1st April 2008 at 01:19 AM. |
| | #12 (permalink) |
| Hello all, Thanks for the reply. After studying the Maximiser, I also come to a doubt whether this spiking approach will suffice the motor requirements or not (interms of starting current and corresponding time). With respect to the battery... thing is my whole concern is about a cheap solar powered pump. Not only cheap but easy to maintain. I am trying to support a small Drip Irrigation system with this assembly. In Indian scenario, farmers will not be happy with system where in they have to maintain a battery.. reason being they are used to traditional AC system, secondly the extreme poverty. I think I need to lower down the pump specifications (in terms of input watts), so that without increasing the panel and without having a battery I can go on. Any suggestions/objections? Warm regards, Amitraj |
| | #13 (permalink) |
| That maximiser circuit is sold over here in Oz as a kit and it's been around for donkeys ages AND WORKS. although I haven't made on as yet as I haven't had the need I do know many people who use it on a daily basis including several people who I put them onto it. The circuit is designed for the public domain by a guy from selectronic ( the mob who make sinewave inverters). As Amitraj has stated his need is for drip irrigation and this circuit would be perfect for the application. Below is the link to buy the mini-maximiser kit from ATA. http://shop.ata.org.au/cart.php?targ...ategory_id=251 Cheers Bryan
| Current source | GagoX | Electronic Projects Design/Ideas/Reviews | 13 | 12th January 2008 06:32 PM |
| H-Bridge: Current Sensor Placement | dknguyen | Robotics Chat | 16 | 7th December 2007 11:52 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 12:50 PM |
| Bridge Rectifier Current Rating -- How much is enough? | hamfiles | General Electronics Chat | 6 | 6th August 2003 06:15 AM |
